A-6 Intruder 50mm w/PLANS, "i12flyrc" maidened 40" 70mm version W/VIDEO
UPDATE: plans added on page #8, maiden video on page #6
UPDATE: "i12flyrc" Mike has maidened his 40" span 70mm version! post #265 to read the flight report ![]() hi all, I picked up two of these fans http://www.hobbyking.com/hobbyking/s..._Version_.html and was planning on a twin project, then a single, then a twin,.....I decided to go with a single. I have test run these fans and I am impressed, very smooth and really push. I have the plans penciled out and have a good idea on how I want to build it. I wont ink anything till it flies in case I change something but I think it will be as drawn. this is not an exact scale build but should look pretty close when done. I "think" I can do this airframe at 4oz's maybe a tad less, but that is my target. I want to be at 10oz's or less AUW, if it hits 11 or 12 thats fine too but I am going to try for lite as possible. I will be using depapered $tree foamboard. specs: WS.........................26" LNGTH...................28" FAN........................HK 50mm Alloy EDF 4800kv (3s Version) ESC.......................HK Red Brick 20A ESC SERVOS...............2 x 9gm BATT.....................SKY LIPO 1000mah 3s 30c AUW......................10-12oz's RATED THRUST..16oz's (from some testing I think this is accurate) MAX AMPS............18 so there it is, and I hope to start cutting tonight ![]() ![]() ![]() couple plans pics to tease you with Joe |
| Thread Tools | |
| Discussion A-6 Intruder Profile, Kf-2 PLANS | sugas182 | Foamies (Scratchbuilt) | 9 | Jul 19, 2012 03:31 PM |
| Wanted A-6 Intruder | Orion Pax | Aircraft - Electric - Jets (FS/W) | 2 | Apr 30, 2012 07:26 PM |
| For Sale A-6 Intruder EDF | Angelo | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 21, 2012 08:10 PM |
| For Sale A-6 Intruder | Angelo | Aircraft - Electric - Jets (FS/W) | 0 | Mar 21, 2012 06:15 PM |
| For Sale Kyosho A-6 Intruder, Chicago area | Angelo | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 26, 2012 11:04 AM |
