Old Nov 15, 2003, 03:00 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Brisk 280 - fully aerobatic ARTF parkflyer
Test flew my Brisk 280 today - what a blast! ROG from soccer pitch grass, flew 17 mins till it was too dark to see it properly ... still doing vertical climbouts at that point. 3S E-tech 1200 pack was at 11.06V after landing so a fair bit of duration left I think.
I am using a Hacker B20 26S 4:1 with APC-E 8x6. Hacker Master 8A ESC, 3 x Waypoint W-060 servos.
Here's the manufacturer's site:
http://www.hacker-model.cz/news/brisk280.htm
And an earlier thread on this model:
http://www.rcgroups.com/forums/showt...hreadid=124823
I got mine from Cambrian Direct in the UK:
http://www.cambriandirect.com/
Plane is fully aerobatic, huge ailerons give a hilarious roll rate (I'm using 40% expo) and all-flying V tail halves for pitch and yaw. Fully symmetrical wing section. My AUW is 317 grams or 11.1 oz, wing loading is 8.4 oz ft sq. Very docile at low speed, nice model.
I have made a few mods from stock, will post details & pics later.
Bill Glover is online now Find More Posts by Bill Glover
Old Nov 15, 2003, 03:02 PM
Joined Nov 2000
Quite a long tail moment
Old Nov 15, 2003, 03:04 PM
Joined Nov 2000
Stock motor mount is attached to the firewall, neat (sets side and down thrust) but no motor cooling whatsoever since the motor is inside the plastic moulding! The cowl is just cosmetic and is taped on (as stock).
Old Nov 15, 2003, 03:07 PM
Joined Nov 2000
The cowl is a pretty substantial moulding, I decided to mount my motor directly to that instead (and cut the supplied mount off the firewall). Glued a mounting disk inside the front face and opened up the air intake below it (this is upside down).
Old Nov 15, 2003, 03:08 PM
Joined Nov 2000
I made up a duct from thin plastic sheet, this diverts the air up over the motor can.
Old Nov 15, 2003, 03:12 PM
Joined Nov 2000
Glueing the cowl on, I used Araldite for this (24 hr epoxy) for max strength and to give plenty of time to get everything lined up! The 12" prop is just to check the sidethrust ... bit big for a B20
Old Nov 15, 2003, 03:13 PM
Joined Nov 2000
Stock u/c is intended for use with a Gunther prop, bit small for me!
Old Nov 15, 2003, 03:53 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
We had one of these fly at an indoor meet last month flew pretty good with a GWS IPS and Nimh's; still very fast though and eventually bit the dust.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Nov 15, 2003, 04:11 PM
Joined Nov 2000
Not my idea of a good indoor model really!
Stock u/c clips into an ABS moulding on the front of the fus. former, I cut this away and used a py plate and bolt to clamp and epoxy 3mm carbon legs there instead.
Old Nov 15, 2003, 04:13 PM
Joined Nov 2000
Tack glued a length of 2mm carbon rod across to make the axles
Old Nov 15, 2003, 04:15 PM
Joined Nov 2000
Bind the axle/leg joints with carbon tows, soak with thin cyano, cut the centre part of the axle free when dry
Old Nov 15, 2003, 04:16 PM
Joined Nov 2000
Finish off with a pair of the superb ultra-light wheels from Air Craft
Old Nov 15, 2003, 04:19 PM
Joined Nov 2000
V tail is supposed to have 1 servo (elevator only), plastic tubes are fitted to take wire rods. Mine looked like it was going to be nose-heavy so I decided to mount the servos in the tail and drive the surfaces directly. Here's the 2-servo 'brick' I made up, before installing.
Old Nov 15, 2003, 04:20 PM
Joined Nov 2000
Finished tail section. The metallic blue trim was the nearest match I had to the covering
Old Nov 15, 2003, 04:23 PM
Joined Nov 2000
Speaking of the tail. The wire pivot rods were not properly fixed on my tailplanes - they just pulled straight out! So I replaced with carbon rod (saving some weight).
Original wire pivots at top, carbon rod below (before cutting to size).
Sukhoi SU 31 Aerobatic ARF parkflyer from Simprop Cayman Electric Plane Talk 9 Jul 25, 2009 04:39 PM
Hacker Brisk 280, anyone tried it? Philip Thulin Parkflyers 54 Apr 05, 2004 06:11 PM
brisk 280 motor selection thesnapper Parkflyers 1 Feb 23, 2004 04:56 PM
Good 280 size aerobatic fun fly airplane Superman Parkflyers 2 Jan 26, 2003 04:33 PM
aerobatic/durable parkflyer wanted. I FO nut Parkflyers 21 Jul 31, 2002 09:31 PM
