Old Jul 16, 2012, 01:18 PM
whowhatwhere is offline
Find More Posts by whowhatwhere
CA...gimme the CA...
whowhatwhere's Avatar
United States, GA, Savannah
Joined Jun 2005
Homemade CNC from DVD Laser
Hey folks,
My cousin the physicist sent me this article on making a laser cutter with a diode from a scrap DVD player. Doesn't seem to have a lotta power...the article says 150mW from a DVD burner, but they say it's strong enough to melt plastic and burn paper. Would most likely cut balsa....but they say a Blu-Ray player yields around 1W....so that would be the ticket.
Sounds interesting, but complicated? Doesn't look *terribly* convoluted...somewhat time consuming, but folks here don't mind that...!
Apparently one can use a piece of software called "Grbl", which is a hacked version of G-code....but I'll betcha there are others.
The author says "With free G-code generator extensions to various drawing programs, sending a page to an engraver is only slightly more complex than sending it to a regular laser printer."
One problem I can see would be the axis length. Some parts require a good stretch, so you'd have to come up with a way to lengthen at least one of the axis.
Still....an interesting concept.
whowhatwhere is offline Find More Posts by whowhatwhere
Old Jul 17, 2012, 03:38 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Can you copy the thread to the -
The Builders Workshop forum
and the-
CAD/CAM forum
As they may be able to determine the feasibility of the idea for model use.
eflightray is offline Find More Posts by eflightray
Old Jul 17, 2012, 07:27 AM
Joined Jun 2005
Sounds good...I'll take a crack at moving it.
Old Jul 17, 2012, 07:32 AM
Joined Jun 2005
Thread moved to suggested locations and closed.
Build Log Somewhat Different Homemade CNC Miller vtdiy CAD/CAM 22 Jul 29, 2012 09:04 PM
Sold Secrets of Thermal Soaring DVD from RCA artasb Aircraft - Sailplanes (FS/W) 1 May 28, 2012 03:24 PM
Sold 2.4 Radio Clinic DVD from RCA artasb Aircraft - Sailplanes (FS/W) 2 May 28, 2012 02:45 PM
Sold 2.4 Radio Clinic DVD from RCA artasb Aircraft - General - Radio Equipment (FS/W) 0 May 28, 2012 01:12 PM
Discussion OT - Laser from an old DVD player Malc C DIY Electronics 3 Mar 16, 2006 04:15 AM
