Old Jul 16, 2012, 10:54 AM
sfc is offline
sfc
Find More Posts by sfc
sfc's Avatar
United States, CA, Sacramento
Joined Jul 2012
New Product
Fully Protected Propellers by SFC - Quad/Tri/Hexa
########## UPDATE 11/14/2013 ############
This frame pictured below did not go into production -- please refer to the new thread or http://safeflightcopters.com for current production quad airframe
As a long-time lurker on these rcgroups multi-rotor forums, I'd like to introduce myself: My name is Erik and I represent Safeflight Copters, a new venture that aims to promote multicopter/multirotor safety as its #1 goal.
Some background: After injuring myself on numerous occasions over the years while testing and flying my tri's/quads/hexas, I started trying to re-think propeller protection on these machines. I wanted something that fully protected the propellers from the outside world while still being lightweight, nimble, and having little reduction in flight time (as compared to a machine with bumpers). My only goal - which became an obsession - was to create a propeller guard template for almost any multi-rotor configuration that one can fly anywhere (especially in close quarters) without fear of risk of injury to oneself or others. That goal has been met. My only fear is that the propeller manufacturers will disown me because I never have to replace and balance propellers with these machines, even after crashing.
Some technical info:
For simplicity and ease of assembly, our Quadcopter kit is based around the rcexplorer.se tricopter electronics and motors. Props are 10x4.7
Current specs (approximate and subject to change):
All Up Weight with battery: 1050g (37oz)
Frame weight empty (no electronics, motors, or battery): 400g (14oz)
Flight time with 3s 2200mah lipo: 8 minutes
We are currently taking pre-orders and - based on interest - will aim to launch a limited production run of 1000 QuadCopter kits Sept 1st, 2012.
Please don't hesitate to comment and ask questions or submit questions through the site. http://safeflightcopters.com
sfc is offline Find More Posts by sfc
Site Sponsor
Old Jul 16, 2012, 11:28 AM
newmanhyde is offline
Find More Posts by newmanhyde
Singapore, Singapore
Joined May 2012
is this modular ? would be interested to see it fit into some common frame.
newmanhyde is offline Find More Posts by newmanhyde
Old Jul 16, 2012, 11:38 AM
BH flyer is offline
Find More Posts by BH flyer
Joined Jul 2012
As a long time lurker myself, and after reading about and seeing the results of multi-rotors gone wild, safety has always been a major concern for me. I really like this design. I watched the videos, and now I want to build one. Well done.
Safeflight Copters Quadcopter Summer Fun Flying (1 min 3 sec)
Safeflight Copters Prototype Montage (1 min 35 sec)
BH flyer is offline Find More Posts by BH flyer
Old Jul 16, 2012, 11:42 AM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
I like it, I would like to try that...
very cool..
G-unit is offline Find More Posts by G-unit
Old Jul 16, 2012, 11:44 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
I would be interested in seeing a few crash tests. The frame doesn't look very strong to me. I'd also be interested in seeing some gyro vibration data. A less stiff frame will transmit lower frequencies much better, leading to more gyro noise.
MOAR DATA!
TS00 is offline Find More Posts by TS00
Old Jul 16, 2012, 12:04 PM
rolin is offline
Find More Posts by rolin
Joined Jul 2011
Really like the idea and the design. Looking forward to see the tricopter. For me it makes more sense to make versions for smaller props, because they are more likely to be flown in limited space and closer to people.
rolin is offline Find More Posts by rolin
Old Jul 16, 2012, 12:13 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Looks good.
I would buy a set of the prop guards to out on my gear if you ever sold them separate and for other sized props
Looks like a good idea
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 16, 2012, 12:15 PM
sfc is offline
sfc
sfc's Avatar
Joined Jul 2012
Glad you guys are liking it!
@newmanhyde: I originally designed this to be modular where folks can order the prop guard and screen kits and mount them directly to their own scratch-built machines. Stay tuned on this as it's on the roadmap!
@bh flyer: Thanks for posting the vids!
@ts00: The rings are designed to "break free" at their mounts upon a modest crash. They snap back on. The ring's thrust angles are also adjustable for yaw authority. The frame has isolator bushings in which the battery, receiver and flight controller are mounted together one unit isolated from the rest of the frame. I don't currently have a data logger to log vibrations. However, when I mount a GoPro to the isolated section via a standoff mount the quality is great without visible vibrations. Sorry no pics of this because we're still finishing up the gopro fuselage housing, which is elongated to offset gopro and battery weights. We will include that housing and hardware in the kit.
Site Sponsor
Old Jul 16, 2012, 12:19 PM
BH flyer is offline
Joined Jul 2012
Pre ordered! Sep. 1 seems like a long way off.
Old Jul 16, 2012, 12:42 PM
BH flyer is offline
Joined Jul 2012
Definitely interested in the professional design for AP work.
Old Jul 16, 2012, 01:59 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi SFC,
Nice mission You've got to like any project that makes multicopter's a bit safer.
Your recommended list for motors only mentions the DT750. Will your design fit Pulso, Tiger, RCTimer ~2830 , ~50g sized motors as well?
Will you be making replacement parts available?
How does one gain access the FCB for setup?
Where are the ESCs mounted?
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Jul 16, 2012, 02:20 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Looks great, very interested in buying if it will retro fit to my existing quad electronics, naza fc, esc's etc.
ripmax is offline Find More Posts by ripmax
Old Jul 16, 2012, 02:23 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
what is the efficiency loss due to the top/bottom cover?
also the prop upgradability? ( when you want more payload.. you will need to change motor/prop.. the frame might limit the max possible payload.. how do you solve it? (also you didnt specify the size)
also for the material.. is there any way to reduce? 400g seems a bit heavier for mini size quad.. any plan for cf?
jy0933 is offline Find More Posts by jy0933
Old Jul 16, 2012, 02:59 PM
sfc is offline
sfc
sfc's Avatar
Joined Jul 2012
@jesolins: Jim, thanks for your questions and positive response. I like your headline about focusing on safety in 2012! To keep prototyping costs low, the motor mounts are currently designed around the DT750, however, production models will feature universal mounts that allow the height of the motor to be adjusted, featuring a simple clamping system to accept most popular motor mounts. I am currently in the prototyping process of these universal mounts and once finished testing I will provide a list of motors that are confirmed mount-able. The limitation is the area where the motor passes through the bottom screen mount, but can be trimmed based on motor diameter. Replacement parts will be available as soon as we release. The FCB is accessible for tuning, etc through a slip-on hatch cover in the top of the fuse, and the mounting area available for the FCB on the airframe is large enough for the KK-based controller board which allows the others to fit. (I fly with the KK and the DJI Naza controllers). The larger FPV fuselage (under development) has plenty of room for more gear. The ESCs are mounted along the sides of the airframe body, with cooling coming through slits in the body. I hope that covers your questions, and please don't hesitate to ask more. The website is a work in progress and we'll be updating it with more pertinent info as questions come in.
@ripmax: See above!
@jy0933: The efficiency losses were measured at 10% average loss in thrust with the 10x4.7...Any more than that I would have scrapped the project As you pointed out, the limitation to protecting the props, of course, is that it limits what props you can run. The 10x4.7 APC's do great with the non-FPV weight or the addition of the GoPro and 900mhz 500w transmitter. Our design is easily scalable and we plan to release smaller kits down for 8" props up to 12"-15" props, based on demand. While I can't promise anything, our final target weight for the empty 10" prop quad airframe is more in the 300 gram range as we are experimenting with lighter plastics and injection molded screen material. I'm well aware of the trade-offs with this design vs. open props but I believe they are worth it!
edit: Forgot to mention that there are no plans for CF at this time due to high costs
Site Sponsor
Old Jul 16, 2012, 03:32 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
how about replaceable cage.. so it wil be easier to replace with different size props? (according to duct fan, if the cage is close fit with prop, you might reduce the tip loss.. so the over efficiency loss can be minimized)
radial upper/bottom cover might reduce the efficiency lose.
Poll What Motors do you use on your tri/quad/hexa/octal etc? Multiples Allowed :) bob4432 Multirotor Talk 10 Nov 24, 2010 08:53 AM
Discussion Most stable, Tri, quad or hexa? godislamm Multirotor Talk 13 Oct 26, 2010 06:05 AM
Poll What Motors do you use on your tri/quad/hexa/octal etc? bob4432 Multirotor Talk 4 Aug 29, 2010 07:10 PM
Discussion Folding frame for AP - tri, quad, Hexa, Okto danielpetrescu Multirotor Talk 9 May 10, 2010 12:25 AM
Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand Arthur P. VTOLs 2 May 20, 2007 03:02 PM
