Joined Jul 2012
Easystar 2 setup with stock propeller?
Hello,
This is my first thread on this forum and I am building my first plane. In other words I am completely new in this hobby so please have patience with me. I have bought an Easystar 2 from the Swedish webside RC Flight (http://www.rcflight.se/visaprodukt.aspx?id=1934). Since I did not know much I asked the site manager what setup I should use. I bought the equipment he recommended: ESC: HobbyWing Flyfun 18A 4 servos: EMax ES08A 8.5 g 1.5 Kg Battery: Gravity 2200 mAh 3S 30-40 C LiPo Turnigy SK 2826 1240kv I also asked if I could use the stock propeller that comes with the Easystar 2 - a 7"x6" folding propeller (18cm x 15cm) - and he said yes. Now to my question: Can I really use this propeller? If the answer is no, which propeller should I get? I plan to try FPV with this plane in the future if all works out, so it would be great if the propeller could work even with some extra weight. Kind regards, Marcus --------------------------------------- Specs of engine: Brand: Turnigy SK Kv: 1240 Max Volt: 11.1 V. Max Amp: 16 A. Watt: about 150 W. Length: 28 mm Weight: 45 g Shaft: 3 mm Specs of ESC: Brand: HobbyWing Series: Flyfun (Pentium). Max Amp: 18 A (Burst 22 A). Weight: 19 g Size: 24 x 45 x 11 mm Capacity (celler): 2-4 Max A BEC: 2 A (5V) Specs of plane: Wing span: 1366 mm. Body length: 977 mm Flight weight: 700 g. Wing Area: 28 dm2 Load per wing area: 25 g/dm2 |
Space Coast
Joined Oct 2000
The 7x6 is on the high side but may be OK.
The stock motor is an 1100 kv and your motor is a 1240kv so you are trying to spin the prop faster which draws more current. It's always best to check the amp draw when a new prop size is used. One of these would do the trick. http://www.headsuprc.com/servlet/the...TER/Categories If you don't want to invest in one at this time, ask another RC'er to make the measurement for you. Too few amps and you are not getting the power you need, too many amps and you'll fry the motor and/or ESC and/or battery. The prop size determines the amp draw by the motor. Based on the original motor and your new motor's specs, I'd go with a 7x4 to start with. Of course you can always use the finger test. Fly for a couple on minutes and land. Can you hold the motor in your fingers for 10 sec? If not, drop down the prop size. If it's cool, increase the prop size. Warm to very warm is OK as long as you can hold it in your fingers for 10sec or more. |
Beaumont, TX
Joined Feb 2007
And you could also do some reading and ask here:
http://www.rcgroups.com/forums/showthread.php?t=1525403 |
| Thread Tools | |
| Question Can find a thorough tutorial on aileron setup for easystar | easystarfpv4 | Electric Plane Talk | 2 | Jun 28, 2012 10:50 PM |
| Discussion Genius cp brushless motor with stock tail setup | cjh586 | Micro Helis | 1 | Apr 02, 2012 07:58 PM |
| Video GWS A-10 Stock Brushed setup with 1 ESC on pavement 2 videos | modfly | Electric Plane Talk | 8 | Apr 21, 2008 08:48 PM |
| Discussion Problem with stock gunther prop for Easystar | RC Robby | Beginner Training Area (Aircraft-Electric) | 2 | Jan 21, 2007 03:04 PM |
| Question EasyStar Stock Propeller Equivalent | ShadowXT | Foamies (Kits) | 29 | Dec 31, 2005 09:35 PM |
