Old Jul 16, 2012, 12:22 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Question
Who wants stuff?
Meet the M140 and C140 concept models. The C140 is still in development. These are pictures or information that I really do not want to release, but I want to expand our boating hobby. If I can get enough interest, then I might have enough of a footing to try and get what we need/want. Yes, I focus on racing and not scale, but the same rules apply, therefore everyone will get piece of the action.
We need basic kits at least. Hulls and props ARE the most desired things I've seen in this forum. Who wants to see something happen?
What do you want to see?
M140 Specs:
- 140mm length, 156mm with rudder
- 40mm beam
- Fully Adjustable Stinger Drive
- trim tab capable
- adjustable trim tab angles
- easily interchangeable parts
- Fiberglass Hull
- specialized hardware
C140 Specs:
- 140mm length, ?mm with rudder
- 52mm beam
- possible twin setup
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 16, 2012, 12:23 AM
Joined Nov 2007
reserved
Old Jul 16, 2012, 07:38 AM
idocdave01 is offline
Find More Posts by idocdave01
Joined Mar 2010
I like the M140 but either one would be great
Dave
idocdave01 is offline Find More Posts by idocdave01
Old Jul 16, 2012, 02:04 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Hi bim,
I'm much more interested in sail but I haven't been able to force myself to get a toe hold on any 3D software.
I'm thinking around 7.5" to 10" with a pager motor in the keel, which would be narrow, deep and placed with the LE about mid-hull. The hull and keel slot together so a variety of keels could be tried.
I've got a slightly unusual hull in mind, not radical but leaving convention a little to the rear.
Would love to add a very small Shapeways metal folding prop. Metal so it would be just a bit heavy. When spun backwards Centrefugal force would hold the blades open so you could back up. Just a nice, weird additional touch. If I'm going to get into 3D, why not?
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jul 16, 2012, 04:48 PM
Joined Nov 2007
Thanks idoc.
Pete, check out some of the stuff I have here. The thinnest parts here go down to 0.35mm. You can't get that with metals. The minimum thickness for SS is 3mm. The folding prop is definitely an interesting idea and can easily be done. My props (below) are 12mm in diameter. I can scale them up, cut the blades and modify the blades and hub. If you are interested let me know.
Old Jul 16, 2012, 05:18 PM
PeteSchug's Avatar
Joined Apr 2004
Originally Posted by boredom.is.me View Post
Thanks idoc.
Right now I have a bunch of 10mm props, maybe a lifetime supply, considering I'm seventy-four.
Sorry to hear that 3 mm is the thinnest for SS. I'd be more interested in brass, bronze or even silver if it could be made small enough. I'm thinking no bigger than the 10 mm I have now, but with a folding prop a large diameter not only wouldn't hurt, it might actually be more efficient. After all, low drag is why you fold the prop and once folded the diff in drag between various sizes doesn't matter.
Will look at the picture some more and try to figure out what's what.
Pete
Old Jul 18, 2012, 07:46 PM
Joined Nov 2007
http://www.rcgroups.com/forums/showt...9#post22202274 ...Giggity
Old Jul 23, 2012, 01:35 AM
Akura2 is online now
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
I would like the cat... Cats are my preference...
Have you thought about 3D printing these... www.shapeways.com
Akura2 is online now Find More Posts by Akura2
Old Jul 23, 2012, 07:23 AM
Joined Nov 2007
I like cats too, but the vee (Scorpion) is inspired by the HPR Mono, which happens to be one of the two only vee hulls I like so it's a toss up. The vee come first though as that's what I should have in my hand later today.
Ya I kind of brought shapeways to the forum... 3D printing isn't really the solution to much though.
Old Jul 29, 2012, 09:43 PM
Akura2's Avatar
Joined Sep 2003
.OK.. well I figured that since people have been talking about doing things with Shapeways since 2008 that it might be a viable solution to printing a 3D hollow hull without having to go through the steps of making a buck and glassing it.... especially since you already have the 3D model...
Old Jul 29, 2012, 09:45 PM
Joined Nov 2007
It's not that easy though and the result is a very heavy hull that still needs quite a bit of work to be seaworthy.
Old Jul 29, 2012, 09:48 PM
Akura2's Avatar
Joined Sep 2003
Heavy? even with 1mm wall thickness?
I'm just asking... I don't know since I've never made anything hollow or for water through them... and I know the minimum wall thickness on SW is 1mm
Old Jul 29, 2012, 10:26 PM
Joined Nov 2007
Actually it's .7mm. The issue is making the actual model uniformly hollow. Then after you make it, you have to seal it because it's porous. I guess if you are doing a scale model, then it would be the easiest option, but not for a race boat.
Old Jul 29, 2012, 10:53 PM
PeteSchug's Avatar
Joined Apr 2004
What about using Shapeways to make a form for a mold?
Pete
Old Jul 29, 2012, 11:19 PM
Joined Nov 2007
It is really hard to sand and properly smooth. You would have to make it thicker to deal with the natural stress of molding too. If you want detail, then you will definitely pay a hefty price. My mono would have been around $80 to get done, in good detail, for the three plugs.
For Sale wanting to sell or trade large collection of rc buggy and truck stuff for cox stuff horse1972 Cars - Cars and Parts (FS/W) 0 Jun 12, 2012 08:43 PM
Wanted Starter FPV setup, tx/rx/cam. Who wants to get rid of their HK 900/5.8hz stuff? templton89 FPV Equipment (FS/W) 2 Feb 28, 2012 04:57 PM
Who wants free stuff ????? Littlescreamers Parkflyers 273 Aug 04, 2005 09:48 PM
