View Poll Results: We need a: 3ch, 2ch, nothing
Yes, we need a 3ch receiver. 6 46.15%
Yes, we need a 2ch receiver. 3 23.08%
No, we don't need a micro receiver that might make our lives easier. 4 30.77%
Voters: 13. You may not vote on this poll
Old Jul 15, 2012, 03:48 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Alert
Would you like to see a 2ch/3ch receiver made for our boats?
The electronics we in our micro boats are often out of place. Meaning, they were never designed to have any consideration for our boats. Yet we still take bricks and giant receivers to control and power our boats.
Do you guys think we need a dedicated 2ch or 3ch micro receiver designed for our purpose?
Please post why you chose what you chose. Also please post what you would pay for such.
I think so. Therefore, I'll throw a few ideas out.
- pins, not plugs
- onboard brushed esc
Pin, not Plugs:
- It is hard to properly grip some of the plugs we encounter. As a result, some of us risk damaging our boats trying to unplug the servos or speed controllers from the receiver. Vertical pins would be ideal, just not as big as the standard servo pins. 1.27mm pitch connectors (found on most micro brushed motors) would be ideal.
Onboard Brushed ESC
- A single drive boat will only need so much current. A 3-5amp esc would be nice.
- For twin setups, such as scale ships, either a larger esc or dual escs would be ideal.
Kev
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 15, 2012, 07:58 PM
Joined Nov 2007
Ok don't post, but at least put a vote up on the board.
Old Jul 15, 2012, 11:07 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Specially designed RC gear just for boats is a brand new idea.
I think people need time to digest the idea and think about what they would like to have. Maybe just a thread rather than a poll where people vote on things they never considered and haven't had time to think about.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jul 15, 2012, 11:56 PM
Joined Nov 2007
I see where you are coming from, but this is only a receiver with less channels. If there was anything to introduce the movement, this is it.
Kev
Old Jul 16, 2012, 02:08 PM
PeteSchug's Avatar
Joined Apr 2004
You can never be too rich, too thin, or have too many channels.
Pete
Old Jul 16, 2012, 04:32 PM
Joined Nov 2007
I bet I can prove each of those wrong.
rich - you start to get stupid with everything including life
thin - anorexia will eventually kill you
channels - the extra pins take up too much space and won't allow the receiver to fit in the desired location.
- David (Deltang) said he would be willing to change out the FET on the the boards for a higher amp rating, but this would only send the price of the receiver sky high due to custom work.
- Plantraco gave me a rude response. (I've never had anything positive to do with them. At this point, I honestly wouldn't care if they went under.)
I figured that we may never get something like this, so I'll just adapt...which is nothing new. I designed a "marine" case that waterproofs the receiver and puts the pins where I want them: on top. I made a 2ch version and a 3ch version, but I can add one more channel slot without making it bigger.
I made it for the Rx31.
- 14.9mm length
- 12.3mm width
- 4.4mm high w/o pins
- looking to be 9mm high with full length (3mm) pins and hounsing
Old Jul 16, 2012, 05:07 PM
PeteSchug's Avatar
Joined Apr 2004
I'm willing to risk rich. If you saw me anorexia would be the last thing you'd think of but I have to agree that reducing complexity at the rx end is wise especially if you want to waterproof stuff.
I just got a few Hobby King 4 channel orange rx's. I wonder if, after sticking it together it could be dipped in something to totally waterproof it (and any ESC) except for the battery lead?
Aside: Did you see the new 100 lb 4' drone sub to be used searching and destroying mines?
Old Jul 16, 2012, 06:41 PM
Joined Nov 2007
You could probably dip them in plasti dip or some other liquid rubber compound. Just put something in the sockets and keep all but the base of the antenna out.
I think the case, once assembled with the receiver, will be waterproof yet still accesible. I can throw any pins on it with out making it longer.
Aside: No I have not.
Old Aug 30, 2012, 01:55 PM
Joined Nov 2007
So I changed it up a little bit. It is now about 16mm long with the same width, but the pins sit 1mm lower. I gave it four 3 position spots, so the end user can just block a hole he/she doesn't need. I was thinking about assigning the lower spot to actual throttle, and the upper spot to throttle signal. I can just cap one when the other is not in use.
Description: Name: ImageUploadedByTapatalk1346352923.051403.jpg
Description:
Old Aug 31, 2012, 01:10 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
what about the deltang car/train receivers? they are tiny and run on either the surface radio or the air radio.
i really dont mind using the air receivers. other than having pins instead of connectors, what advantages are there?
i could see the brushed esc being higher rating being useful though...
derk is offline Find More Posts by derk
Old Aug 31, 2012, 09:33 AM
Joined Nov 2007
Those might be a bit over the top, plus they lack even a 2a esc so you wouldn't even be able to use a 7mm with them. All of them work with surface and air radios.
The pins are my main focus really. They are pretty much all the same though.
I just got a longboard for school and an led setup for it, so I am a little low on funds right now.
Old Jan 03, 2016, 11:42 AM
thijs slotman is offline
Find More Posts by thijs slotman
thijs slotman's Avatar
Joined Oct 2015
i would love to see a dsm2 ground receiver (really small) for my micro boats
i don't wanna spent 100 euro's/dollars on a transmitter (i already have a dx3c)
for now, there are only dsm2 micro systems for airplane transmitter's
and i love your idea keep it up
thijs slotman is offline Find More Posts by thijs slotman
Old Jan 03, 2016, 04:20 PM
GJB is offline
GJB
Find More Posts by GJB
GJB
Swifterbant, Holland
Joined Jul 2005
Thijs, small enough? http://www.banggood.com/2_4G-5CH-DSM...p-1004179.html
GJB is offline Find More Posts by GJB
Old Jan 03, 2016, 04:52 PM
Dennis Manning is offline
Find More Posts by Dennis Manning
RcBoater
Joined Feb 2014
Gentlemen; next you would have to buy a jewelers eye to see the rx l. I bought a new Tactic and rx is small which is 1 1/8" long x 1/2" wide. GJB shows what BG has with a blown up picture of rx, so you can see it. Now if you loose it play **** finding it. Just another item to buy for the tool box.
Dennis Manning is offline Find More Posts by Dennis Manning
Old Jan 05, 2016, 03:30 AM
Joined Oct 2015
Originally Posted by GJB View Post
is that also for ground transmitters?
Question What BNF Micro's Would you Like to See Made? MikeBiv Micro Ready-to-Fly 107 Sep 08, 2011 02:10 PM
Poll Vote for what kit you would most like to see designed. vintage1 Scale Sailplanes 42 Sep 01, 2010 12:49 PM
Discussion How many of you would like to see from parkzone (Horizonhobby) a biplane Like a Pitts MerlinKing Parkflyers 0 Nov 04, 2009 02:25 PM
Discussion Planes I would like to see made ARCHER7153 Sapac America 8 Apr 29, 2009 06:24 PM
Poll I would like to see a HZ Super Cub made available in this configuration: aeronca Beginner Training Area (Aircraft-Electric) 1 Jan 18, 2008 08:48 AM
