Old Jul 15, 2012, 02:31 PM
rnorman3 is offline
Find More Posts by rnorman3
Joined Jun 2012
Best plane for windy conditions?
Hi All, I'm getting ready to purchase my first RC airplane but this might be a tough question. The area I live is never a zero wind condition, but there are days where we might get down as low as 2-5mph wind which is when I'd be doing the most flying. A foamie trainer will probably be a waste of $$ in these conditions? What type of plane should I get. I want electric... Perhaps you might say the best plane is one with not a lot of lift? A more symmetrical wing design? Or suggest an actual model to get? I already have a 5 channel DX5e Spectrum radio. I'm hoping for an ARF plane, that I can also land on the water with the addition of pontoons. A lot to ask maybe...
Thanks!!
Richard
rnorman3 is offline Find More Posts by rnorman3
Old Jul 15, 2012, 02:52 PM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
I'd say get a HobbyZone Super Cub (which will bind to your radio) and try not to fly in turbulent conditions. The Super Cub has the advantage of being bigger than the most popular "teach yourself" foamie", the Hobby Zone Champ and will still be nice and docile for a first timer. Getting a hot plane that can cut through the wind will be a bigger waste of money than a trainer that might get tossed around by the wind. A fast plane will just give you a lot less time to react and will bury itself in the ground that much farther... thr super cub like might actually stay in the air long enough to teach you something between your initial "rough landings" and it will literally bounce back from most air-ground interaction.
You can put floats on most planes (high wingers in particular) with only a couple slight modifications.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jul 15, 2012, 02:59 PM
jonone is offline
Find More Posts by jonone
jonone's Avatar
United Kingdom, Whitby
Joined Jun 2012
Thanks for that i have just asked a simuler question on my post.
Cheers Jon.
jonone is offline Find More Posts by jonone
Old Jul 15, 2012, 03:06 PM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
If you have never flown an RC airplane before, ANY airplane would be a waste of money in those conditions. Your goal should be to lean how to fly an airplane, period, not necessarily to fly in windy conditions. To that end, the Hobbyzone Super Cub would be a great first choicce. It will fly in 5-7 mph winds and even more as you gain experience.
chucksolo69 is offline Find More Posts by chucksolo69
Old Jul 15, 2012, 03:13 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
Talking from experience my advise would be get a simulator to learn how to fly unless you have Deep pockets. There are those that will disagree but I would have been a successful flyer faster an cheaper if my first plane would have had ailerons. I hate a 3 channel, airplane it's harder to fly, in my opinion. My 1st plane was the HZ super Cub and I struggled with only rudder and elevator. Regardless of that, a sim will save your ass, where your wallet is.....ZEE
zeezee is offline Find More Posts by zeezee
Old Jul 15, 2012, 03:14 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
Wind
When I started flying wind was a problem. Now I enjoy a good windy day.
Wind can be many different things depending on your environment.
A steady wind is much easier than gusting and turbulence.
Hills can cause the wind to do strange things near the ground.
Higher up you can find thermals. Gliders love wind.
Learning to coordinate rudder+aileron helps making turns.
As long as the motor is strong enough, the nose heavy enough and you have ailerons, just about anything will fly in a good wind. I have a aileron modified super cub that does wind nicely, also a small profile foamy that can handle windy days.
Ranandar is offline Find More Posts by Ranandar
Old Jul 15, 2012, 03:28 PM
AMA 537620
Joined Oct 2008
FWIW, the Super Cub is float ready with their float kit and as Ranandar said, you can modify it for aileron control.
Old Jul 15, 2012, 03:31 PM
Swen is offline
Find More Posts by Swen
Passion
Joined Sep 2009
This is one of the questions that pop up frequently. I agree, get a plane that is within your abilities and learn to fly, including calm and windy conditions. Agreed, some of the cheap planes are terrible in the wind, but any decent plane can be flown in windy conditions, it all depends on the pilot.
Swen is offline Find More Posts by Swen
Old Jul 15, 2012, 03:39 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
The best plane for windy conditions depends on the skill of the pilot doing the flying. There is no such animal as the best for windy weather flying. Some are better than others but none are fool proof.
BM
BillM is offline Find More Posts by BillM
Old Jul 15, 2012, 05:39 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
http://www.rcgroups.com/forums/showthread.php?t=1628209
cmdl is online now Find More Posts by cmdl
Old Jul 15, 2012, 07:15 PM
rnorman3 is offline
Joined Jun 2012
How about UMX Carbon Cub SS BNF
Thanks for the replies! I don't want to get a cub and have to modify it for ailerons 8-(... I found this similar UMX Carbon Cub SS BNF. It seems to have ailerons and even flaps. I have a DX5e so that should control the entire thing? Would this plane be an equally good option or better even?
Thanks!
Old Jul 15, 2012, 07:20 PM
Elios000 is online now
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
BM
there is one its called a kite
if the wind gets much over 15mph i break out my stunt kite
Elios000 is online now Find More Posts by Elios000
Old Jul 15, 2012, 11:33 PM
Swen is offline
Passion
Joined Sep 2009
Slope soaring. No wind no fly. High wind best flying.
Old Jul 16, 2012, 01:38 AM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
Winds up to 5mph are fine but I wouldn't fly in anything more than that in the beginning. As already said, the ability to fly in wind depends on the experience of the pilot as much as the plane. The hobbyzone super cub bnf definitely fits the bill for what you're looking for. You don't have to modify it with ailerons if you don't want to you can just fly it with 3-channels then move on to something like the e-flite apprentice or parkzone t-28. Be sure to master your plane over land before trying it on water. The carbon cub isn't for someone with no flying experience. If you haven't already I suggest reading the six keys to success for new pilots, it covers the most common mistakes that beginners make.
Rayne is offline Find More Posts by Rayne
Old Jul 16, 2012, 01:44 AM
Joined Jul 2010
you need a slope for that far to flat out here
Question EPP parkfly plans and density for windy conditions scott_f Foamies (Scratchbuilt) 2 Apr 11, 2012 06:59 PM
Poll Which Electric RC Foam Airplane is Best for Windy Conditions? Victory Pete Foamies (Kits) 6 Sep 05, 2011 09:16 PM
Discussion Looking for a plane for windy conditions buildscapeinc Thermal 2 Mar 09, 2009 12:07 PM
Discussion Best AP plane design for windy conditions? Moelich73 Aerial Photography 72 Jan 14, 2009 06:50 PM
Discussion Best Platform for Windy Conditions greenjohnsmith FPV Talk 17 Oct 21, 2007 12:57 PM
