Old Jul 15, 2012, 02:13 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Those dang DJI props caused a CRASH AGAIN, I should have known better AGAIN ! ! !
So I 've already had two crashes on my DJI F550 from the props breaking and you would thought I had learned to never use them again. but NOOOOOOOOOO, not me.
I blame those crashes on the old style thin diameter hubs and my F550 being loaded up with weight.
I got a new F450 a few weeks ago with the NEW thicker 16mm diameter hubs and I'm flying 3s and only have my FPV gear on so I'm pretty light at 3lb 4oz.
Didn't have time to get new props before coming to Mexico plus I would have thought the new props would be ok.
I've ran some videos (which are uploading) but when I crashed I had the ContourGPS in photo mode to get some aerial photos of the owners house.
It's very windy here on the beach and the F450 was blowing around like crazy.
I can't believe a prop brokje and I dropped about 75 feet into the sand. Luckily only one arm broke but I brought some from home so I can fly again.
I don't have extra props so I'm going to have to use the 8" ones.
I hope 3s and 8" will work until tomorrow.
I attached two water buoys to the arms just in case I went into the water. Thank god that didn't happen in the salty ocean.
Man, I'm glad we are the only ones on the beach and I wasn't over concrete.
I would have thought the DJI stock prop would have been solved by now from all the crashes everyone has had using them.
After I get back to the states it's only Graupners or others from now on. I'll use the DJI props as stir sticks for painting.
I wish I had it in video mode, it was a spectacular crash.
Here's a few photos, it was recording a photo every 3 seconds, I really wish it was in video mode. Only one photo was taken falling out of the sky.
jasper7821 is offline Find More Posts by jasper7821
Old Jul 15, 2012, 02:19 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
I've been using 9" Gemfans on mine with good success so far. I had to drill the hole in the hub to 8mm. Then I used luck nuts with teeth to hold them in place. No slipping, they're usually fairly well balanced and none have broken on me so far. Graupners are great too, just a little hard to find and pricey.
WiseDuck is offline Find More Posts by WiseDuck
Old Jul 15, 2012, 02:26 PM
Joined Mar 2008
I'm used to the 10" Graupners and the hole is the right diameter.
I just need to order a bunch of them and never use a DJI prop again.
Old Jul 15, 2012, 02:52 PM
Joined Mar 2008
Here's a video of Rocky Point Mexico.
Unedited and 9 minutes (sorry) can't edit on my ipad
Las Conchas Puerto Penasco Rocky Point Mexico (9 min 12 sec)
Old Jul 15, 2012, 04:23 PM
jetbootz is offline
Find More Posts by jetbootz
jetbootz's Avatar
Australia, Lord Howe Island
Joined Jan 2010
it really is unbelievable that after so many crashes from random exploding props in flight that DJI would not have fixed this issue yet. I have not and will not ever fly with stock props. Graupners all the way....
jetbootz is offline Find More Posts by jetbootz
Old Jul 15, 2012, 10:43 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Never fly EPP props....
on reinforced EPP props, wood or full CF
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 16, 2012, 11:12 AM
Joined Mar 2008
I ordered some Graupners last night from Spain so they'll be here in a few weeks.
Hopefully these 8" stock props on my 3s battery will be ok for a few flights until the 10" ones get here.
Old Jul 16, 2012, 11:18 AM
blade strike is online now
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Jasper Jasper Jasper... No more DJI props for you!
blade strike is online now Find More Posts by blade strike
Site Sponsor
Old Jul 16, 2012, 01:05 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I am still using the original 10in props. Flying aggressive and up to 150' up with FPV gear and a GoPro on board. Lucky I guess.
I did lose a prop once but it was 2 seconds after I flipped it over... The ground cracked that one.
MCrites is offline Find More Posts by MCrites
Old Jul 16, 2012, 05:03 PM
Joined Mar 2008
I know, me of all people should have known.
It flies like crap on the 8" props with 3s.
I guess I just have to wait a few weeks for the Graupners to come in.
I have some old 10" props left from my F550 if I just want to test equipment out hovering a foot from the ground.
Joined Mar 2008
You've just been REALLY lucky.
Old Jul 16, 2012, 06:13 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
you know, when I first heard about prop breakage, I went to 8 " prop until i could find another safer prop. I've settled on zingers and never looked back. they are bit more fragile to crashes and bit more maintenance to keep them balanced, but they don't break in air like these. I can see why apc uses such heavy hub. I love my wooden props.
askman is offline Find More Posts by askman
Old Jul 17, 2012, 11:24 AM
Joined Mar 2008
I don't have a prop reamer so I'm ok with the 10" Graupners.
I've never crashed with them on my F550 since I'm only hovering around.
I just seem to crash with the stock props.
Here's the POS that took me out.
18 flights on the quad until the prop broke, and my F550 was around the same when two of those props broke.
Old Jul 17, 2012, 03:15 PM
Joined Jan 2006
Yep, I have even had an 8" let go on me on my 550
Site Sponsor
Old Jul 17, 2012, 03:16 PM
Joined Jan 2006
Do they fit the dji motors?
Site Sponsor
Discussion DJI 10" Props.....what should I upgrade too?? Aubrishusband Multirotor Talk 16 Jul 05, 2012 11:29 PM
Discussion I SHould Have Known Better Michael in Toronto Life, The Universe, and Politics 1 Oct 19, 2008 05:22 PM
Discussion purchased a used compositeailplane should known better kristorphor Crash Discussion 5 Sep 14, 2008 11:29 AM
