Espritmodel.com Heli Air
Old Jul 25, 2012, 10:01 AM
Joined Jul 2012
Originally Posted by healthyfatboy View Post
Do you have voltage on the 5V rail for M2-M8 on the board? If you disabled the BEC on the 2nd and 3rd motor, then your servo won't get any voltage as the BEC from the 1st motor is separate from the rest of the connections.
Thank you !!!
I think you're right ...
I disabled the other two controllers BEC.
I'll check and I'll update the thread
eitan is offline Find More Posts by eitan
Old Jul 25, 2012, 01:57 PM
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by eitan View Post
What could be the reason that the servo does not respond at all?
I use this servo: http://www.hobbyking.com/hobbyking/s...idProduct=8761.
The servo worked fine with the HobbyKing Multi-Rotor Control Board V2.1.
Thank you
Besides the BEC being disabled on #2-8, make sure ch4 is set to servo and not esc.
H
shelterock is offline Find More Posts by shelterock
Old Jul 25, 2012, 05:18 PM
Joined Jul 2012
Thank you all, The problem was solved with the connection to the second BEC.
Old Jul 26, 2012, 07:06 PM
Joined Jan 2007
I have a Hitec HS-5085MG digital servo coming so I'll give that a try and see how well it works for the yaw.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Jul 27, 2012, 03:03 PM
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
So far it seems that the "jitter" and other problems are user errors.
It can happen. There are alot of things to remember and configure.
Is the board , or programming at fault?
It hasn't been shown to be.
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Jul 27, 2012, 05:26 PM
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
Nobody I've heard of has shelled out 50$+ yet for a quality digital micro servo. I've read only one case where a budget digital worked. Kk himself said there is an issue where sub quality servos may not work. So yes, its a problem with the board.
rcbif is offline Find More Posts by rcbif
Old Jul 27, 2012, 07:30 PM
Phalanx-0's Avatar
Joined May 2008
Originally Posted by shelterock View Post
So I installed a solar digital servo for $12 from hobbypartz. D657. 25g with 3.0kg 0.1 seconds to 60'. No wobble. Set servo on high. Sweet. $12 fix and tri is good!! H
hrm...wasn't even a $50 servo either.
I guess someone's not paying attention in their own thread.
Old Jul 27, 2012, 09:14 PM
Do a Barrel Roll!
rcbif's Avatar
Joined Jun 2005
Old Jul 28, 2012, 04:15 AM
Australia, NSW, Wauchope
Joined Jan 2012
If you're not trying to sort this problem out 1st hand yourself then you clearly have no experience or constructive advice to pass on.
Out.
TLHover is offline Find More Posts by TLHover
Old Jul 28, 2012, 11:18 AM
Joined Jan 2007
I bought a decent, quality servo so once it gets in, I can test it out. Patience grasshopper!
Also, why does it have to be $50+?
Old Jul 28, 2012, 11:35 AM
Do a Barrel Roll!
rcbif's Avatar
Joined Jun 2005
It dosent, but most of the brand name fastest digital servos are around that range which is what is supposed to work with this board in it's current config.
Old Jul 28, 2012, 09:57 PM
team SSG
crezzee's Avatar
Worcester UK
Joined Nov 2004
From the kk2 thread:
Originally Posted by knutek View Post
Hi and thank you for a great board.
Does this mean you have a FW update ready soon?
Originally Posted by kapteinkuk View Post
No, it is lot of stuff left to do.
Looks like there will be no firmware solution for the tail servo problem anytime soon
crezzee is offline Find More Posts by crezzee
Old Jul 28, 2012, 10:10 PM
United States, MA, Sturbridge
Joined Jun 2008
So an consensus on which servo actually works here people?
slowjett is offline Find More Posts by slowjett
Old Jul 28, 2012, 10:43 PM
Joined Jan 2007
I'll try out the Hitec HS-5085 next week when it comes in. I'll try to get a video with the HS-85MG and the HS-5085MG to show a difference.
Old Jul 29, 2012, 08:05 AM
Phalanx-0's Avatar
Joined May 2008
What board isolation solutions have been tried, and failed or succeeded?
Discussion Hobbyking KK2.0 Multi-rotor LCD Flight Control Board MoRaLeSD Multirotor Talk 4 Nov 22, 2012 11:16 AM
Discussion Tricopter tail servo parts TS00 Multirotor Talk 5 Jun 23, 2012 01:40 PM
Discussion Problem Flashing Hk Board for Tricopter timmerflyer Multirotor Talk 0 Jun 20, 2012 12:10 PM
Help! TriCopter with HK Board V2 Savage27 Multirotor Talk 0 Jun 12, 2012 03:44 PM
Discussion .hex firmware for hk board tricopter emberjelly Multirotor Talk 1 Sep 25, 2011 05:33 AM
