Old Jul 17, 2012, 01:13 PM
MIDNCOCO is online now
Find More Posts by MIDNCOCO
United States, CT, Glastonbury
Joined Feb 2010
Originally Posted by rcbif View Post
micro tricopter? What servo?
When I put mine in high it makes a buzzing noise and does not respond.
I am using the 9 gram hobby king servos. I get a buzzing too. I think a digital may work better
MIDNCOCO is online now Find More Posts by MIDNCOCO
Old Jul 17, 2012, 01:42 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
I say "hear. Hear" to rcbif! My tri flew fine before and showed these issues. We're just asking about it. Certainly not ordering anyone to do something about it.
I ordered a couple digitals. I fly over water at times and didn't want to ditch a $300 tricopter if I can ditch a $150 equivalent.
Long live the king, long live KapteinKuk!
H
shelterock is offline Find More Posts by shelterock
Old Jul 17, 2012, 04:17 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
All posts from that phal muppet have the same tone, just ignore him.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Jul 17, 2012, 04:29 PM
Phalanx-0 is offline
Find More Posts by Phalanx-0
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
Yeah, I'm a bore.
Ignore my suggestion to use digital servos and you will never get your V2 to fly.
I outlined why analog servos won't work.
You can lead a horse to water...
Go ahead flame me...I love the heat.
just let me know if digi servos fix your tail problems.
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Jul 18, 2012, 07:13 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
I'm inching towards building my first tricopter (inspired by an RCexplorer and hallstudio's "cheap tricopter" videos) and have been ordering parts. I got a new KK2 board as it sounds like it flys better, especially for a newbie like me. I was a bit behind in reading so didn't read about these potential servo problems until last night. (I had just ordered an earlier version board too when the new one was released, so I have that to use as an option if need be).
I only have analog servos right now. If I was going to order a digital one to use with the KK2 board does anyone have any suggestions on what would be a good choice?
I'm not going to be doing any camera work (for a while anyway), so maybe I can just live with it?
I'd appreciate any experience.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Jul 18, 2012, 08:55 AM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
cheers,
Andrew
Well at this point (what hulk up there fails to understand) is we have a few people with digital servos on their tricopter, and most all of them have tail wobble, except MIDNCOCO. I'd ask what servo he has. However, MIDNCOCO hasnet really said if his wobble is completely gone?
My tricopter flys okish by LOS after getting it somewhat dialed in, but the faster flying I do fpv really messes with the yaw.
rcbif is offline Find More Posts by rcbif
Old Jul 18, 2012, 09:58 AM
Del-Dredd's Avatar
Joined Aug 2004
Who's flying V2's anyway thought that was a German Missile of WW2.
I have some digital servos on way, they will beat the KK2 which has obviously been on the back of a HK delivery snail for over 3 weeks now.
Old Jul 18, 2012, 12:51 PM
Phalanx-0's Avatar
Joined May 2008
Hrm...seems as tho this guy has a stable tail
http://www.rcgroups.com/forums/showp...6&postcount=97
I'd recommend this family of small digi servos
http://www.advantagehobby.com/181968/EFLRDS76T/
I own several. They seem robust, as I thrash mine pretty hard.
Old Jul 19, 2012, 06:19 PM
SleekStryker is offline
Find More Posts by SleekStryker
Joined Jan 2006
Hi everyone,
I just wanted to share my experience with the tail servo jitter and how I solved it.
I'll be direct to the point, the cause of the servo jitter is vibration.
I've been flying my tricopter for some time now starting with the original KK board. My main focus is aerial video (I'm no expert, but still learning). Because of this, it was essential for me to have a very stable platform. I spent hours balancing my motors and props (using magnetic prop balancers, etc.) when I first built my tri. It flew very well and stable.
Then came the KK2 board, slapped it in my tri, did some tweaks and it was all good. Flew perfect and no tail servo jitter. One day while playing with the autolevel, I happen to hit a wall (damn wall!). No major damage from the looks of things. Flew it again and suddenly the tail servo started jittering severely! Damn, I thought my new KK2 board got damaged!
Through a series of trial and error, the main culprit was one of the prop collet holding the prop got slightly bent when it hit the wall (Damn wall!). It was just a small bend, but enough to cause a small vibration on my tricopter's body and eventually affect the KK2 board. The KK2 board is very sensitive on the yaw axis. Anyway, I replaced the prop collet alone and the servo jitter stopped completely.
I'm no expert, and mine could be an isolated case, but I hope this helps.
EDIT: Just wanted to add... the bent prop collet was the front right prop. It caused a very minor vibration, but the KK2 got affected by it, causing the yaw servo to jitter a little, thus causing more vibration back to the KK2 board, thus causing more vibration back to the yaw servo, and so on. I guess what I'm trying to say is that a small vibration would exponentially increase vibration (did that even make sense?) lol Sorry I'm not good at explaining this part.
SleekStryker is offline Find More Posts by SleekStryker
Old Jul 19, 2012, 07:24 PM
TLHover is online now
Find More Posts by TLHover
DLG Bug Bit Me
TLHover's Avatar
Australia, NSW, Wauchope
Joined Jan 2012
Hrm...
Seems hallstudio has tail servo jitter aswell.
Refer to post 918 in kk2 q&a that suggests reading before asking questions.
TLHover is online now Find More Posts by TLHover
rcbif is offline
Do a Barrel Roll!
rcbif's Avatar
Joined Jun 2005
Originally Posted by SleekStryker View Post
Hi everyone,
What model tail servo are your running? Digital? My tricopter is pretty well balanced. The only vibrations seem to be come from the servo twitching back and forth.
I could see why vibrations would effect the servo, but I dont think that's the majority of our problems. Even KK himself said it's because the analog servos cant handle the signal so they wobble. That's why I'm curious what servo your running.
Old Jul 19, 2012, 07:26 PM
DLG Bug Bit Me
TLHover's Avatar
Joined Jan 2012
Post 918 on this page i mean.
http://www.rcgroups.com/forums/showt...2#post22164439
Old Jul 19, 2012, 07:27 PM
rcbif is offline
Do a Barrel Roll!
rcbif's Avatar
Joined Jun 2005
Originally Posted by TLHover View Post
Hrm...
hallstudio was the first one I messaged about this
from hallstudio (hope he dosent mind me sharing his PM)
"If its a fast back and forth about 1/3 to 1/2 inch i have it to. not sure how to help. i hope my servo does not burn up. on esc setup there is a high and low setting for rudder. check and see if its set to high or low. i set mine to low for analog and high for digital. not much help there on the wobble but when i had it set to high on the analog it burnt up in 3 or 4 flights."
Old Jul 19, 2012, 08:57 PM
Joined Jan 2006
I'm using Hitec HS-82MG. I'm waiting for my new(better) motors to come in from rctimer to replace my emax motors. I'll record a before and after video and show you what I mean with regards to this issue. Should arrive sometime next week.
Try this for a test: Remove your KK2 board and isolate it from your tricopter body. You'll need long servo extensions. Secure your KK2 board on a solid surface nearby and throttle up. See if the servo twitch goes away. Please exercise caution here as it can be dangerous. It's better to secure the tricopter body on a rig.
I tried this test myself when I was troubleshooting it before. Which led me to conclude that it was the vibration. Which led me to the bent prop collet.
I'm not saying that this is the ultimate cause/fix, but it's something that could help you guys troubleshoot better.
Old Jul 19, 2012, 09:37 PM
DLG Bug Bit Me
TLHover's Avatar
Joined Jan 2012
I'm using hs82-mg aswell. They're analogue.
I'm going to try isolating the board and see what happens and report back.
Good suggestion. Hope its that simple.
Discussion Hobbyking KK2.0 Multi-rotor LCD Flight Control Board MoRaLeSD Multirotor Talk 5 Apr 09, 2014 11:05 AM
Discussion Tricopter tail servo parts TS00 Multirotor Talk 5 Jun 23, 2012 01:40 PM
Discussion Problem Flashing Hk Board for Tricopter timmerflyer Multirotor Talk 0 Jun 20, 2012 12:10 PM
Help! TriCopter with HK Board V2 Savage27 Multirotor Talk 0 Jun 12, 2012 03:44 PM
Discussion .hex firmware for hk board tricopter emberjelly Multirotor Talk 1 Sep 25, 2011 05:33 AM
