Old Jul 15, 2012, 07:57 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
2x wemo/ w 6000kv 3s
I starting a scratch built 2x50mm bird, what would the power consumption be?
What size lipo would you suggest?
D_FAST is offline Find More Posts by D_FAST
Old Jul 15, 2012, 05:28 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Each of the Wemo 50mm fan and 6000 KV will pull about 350 watts so 700 total watts for the pair. I typically run a 3S 1800 25C for one of those setups but I fly full throttle the whole flight so eat up the power quickly. Probably a 3S 3000 would be fine. I also have a 4S setup that is about the same total watts (the 4800 KV motor) , I typically run a 4S 1320 in those jets so maybe a 4S 2200 would be OK if you had some throttle management.
The Don is offline Find More Posts by The Don
Old Aug 16, 2012, 08:05 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Before i pull the trigger on these, your web site states 430watts on 4s with the 4800 is this typical?
the reason i'm asking is the bird is getting heavy, i miss quoted your web site in the below link.
http://www.rcgroups.com/forums/showt...1681958&page=4
And as the build draws closer to completion, i may have been strong on my weight calculations, im now hoping for 36oz AUW, providing my thoughts below.
the 4800 on 4s pulling 29amps at 430watts
I could shed some weight going with the 30amp esc rated for 40amp burst, also these are linear becs, and will also eliminate the need for a Ubec saving more weight.
Is my thinking correct?
Thanks again, oh and could i request red stickers with the purchase?
Old Aug 16, 2012, 06:44 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That is pretty typical.
To be honest the Pentium 30 on 4S do not like to be pushed hard. They can overheat easily and then they throttle back to half throttle to allow them to cool. Having a linear BEC means that the the ESC will be even hotter as it has to dissipate the 4S lipo voltage down to 5volts. I think you would be better off getting the 40 amp as they have a 3A switching BEC in them. So just disable one red wire on one ESC to disable the BEC then plug the servo leads into a Y harness and run your servos off the built in BEC and save the weight of the external BEC.
Just specify in the comments that you want red.
Old Aug 27, 2012, 08:28 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Received in perfect condition.
who would have guessed 2x50mm flying a 36oz ship at 1/2 throttle
The J 14 Project (2 min 37 sec)
Old Jan 10, 2013, 12:41 AM
spencer6891's Avatar
NC
Joined Aug 2004
That looks great D_FAST! I'm also in the early stages of planning a twin 50mm project. Do you (or Don) know the weight of one of the wicked units?
spencer6891 is offline Find More Posts by spencer6891
Old Jan 10, 2013, 06:38 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
im sure the Don has it. ive forgtten
Old Jan 10, 2013, 08:07 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
About 84 grams assembled.
For Sale Turnigy 2x 3s 1000 mah and 2s 1000 mah and Turnigy 2s/3s Lipo charger. Falconpunch Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 18, 2012 09:47 PM
Sold dons 6000kv/wemo 50mm/40A ESC LTR450 Aircraft - Electric - Power Systems (FS/W) 1 Mar 30, 2011 01:10 PM
For Sale FS: 2x PQ 3S1P 2600 10C w/taps "PQ-B2600N-SP 3S" $30ea/$55 both maximal Aircraft - Electric - Batteries & Chargers (FS/W) 6 Apr 03, 2007 08:34 PM
Sold 2x Kokam 3s 1500mAh w/ Dean's plug Rex A Lott Aircraft - Electric - Airplanes (FS/W) 17 Jun 12, 2005 08:54 PM
For Sale 2x Tanic 3s 830 w/ micro deans SeanJ Aircraft - Electric - Airplanes (FS/W) 1 May 29, 2005 07:29 PM
