Old Jul 15, 2012, 08:50 AM
edge_pilot is offline
Find More Posts by edge_pilot
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
Help!
Optima 9 RX blue LED won't light
I have an Optima 9 receiver in my 35% and I can't get it to bind so the red and blue light are on on the receiver. The transmitter is in scan mode and both the blue and red LED's are on on it. Why won't the RX bind to scan mode?
I am running a Smart-Fly power box which is supplying my receiver 5.0 volts. I am running the rest of the plane on 7.2volts with high voltage servos. Works fine the way it is binding, I jjust feel safer having both LED's on with the TX and RX.
edge_pilot is offline Find More Posts by edge_pilot
Old Jul 15, 2012, 04:37 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Scan Mode or Scan Function? Scan mode no longer applies with current firmware,
use of which is strongly recomended for a model of that size.
LED display if effected by firmware version.
Ascertain firmware version in each of the three units as follows:
1. A9 firmware version displays under [INFO].
2. Spectra Module - requires use of HPP-22.
3. Transceiver - requires use of HPP-22.
Current firmware versions and more information under:
. AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedure for
........Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver.
. Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use (with screenshots).
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jul 15, 2012, 06:16 PM
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
Well tried all that again for the 10th time atleast. The TX binds with both red and blue lights on, the RX will only bind with the red light on.
Both are upgraded to the latest and greatest firmware.
This is very confusing to say the least
Old Jul 15, 2012, 06:30 PM
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
I have come to the conclusion this is a bad receiver. I have 3 other Optima 9's and they are all working perfect with both red and blue LED's on when the transmitter links. This one I just pulled out of the box and it won't bind properly no matter what.
Old Jul 15, 2012, 06:38 PM
A.T. is offline
Joined Aug 2002
"The TX binds with both red and blue lights on" ?
Module does not appear to have been updated to V3.01 as after completing scan function
and cycling on/off, then Blue LED should not light again.
Check also that every transceiver has been updated to V2.02(0), as any recent purchase would be.
If firmware does not match, then LED sequences vary as does proper link.
Spectra module setup with Optima Transceiver: Blue LED should glow only during scan function.
Once scan function is completed and Tx cycled On/Off only Red LED is seen.
Refer last two pictures under the ID_Setup page above, then:
". 07 Oct 2011 Update:
Blue LED on Optima V2.02 may not hold steady after ID setup, just a very brief flash.
- so fast easily missed Red LED then holds steady.
Cycle power both TX & Optima to complete and then range test as usual."
After which the module LED should be RED only,
if not then module has not been properly updated to V3.01.
Alan T.
Old Jul 15, 2012, 06:52 PM
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
OK, I will admit I am a moron.
I was updating the TX and RX, but I did not update the MODULE itself.
I now have EVERYTHING updated and the lights work as you say they do. Thank you for your help and patience with my oversite.
Old Jul 15, 2012, 07:34 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
Glad you admitted it! (joke). Believe it or not seems like an easy brain fart or senior moment to me, so you really aren't a moron.
4*60 is offline Find More Posts by 4*60
Yippee! Hitec Optima 9 Rx on sale! 20% off! ServoCity ServoCity.com 1 Jul 05, 2012 10:37 AM
Discussion my Sirius Pro Former green led won't light up edwu Batteries and Chargers 10 Mar 04, 2012 09:49 PM
Discussion DSM2 6ch OrangeRX won't bind--won't even flash the LED horseflesh Radios 12 Jun 09, 2011 12:06 AM
Wanted Trade Hitec Optima 7 RX + $ for a Hitec Optima 9 RX cjdscratch Aircraft - General - Radio Equipment (FS/W) 0 Dec 01, 2010 11:45 PM
F/S: GWS Tiger Moth with 9 LED Curtek Navigational Lighting RTF Ch.19 Rx Jr shift LESLIEx317537 Aircraft - Electric - Airplanes (FS/W) 5 Jun 27, 2004 07:57 AM
