Old Jul 15, 2012, 12:47 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
how do you mount this landing gear on x525?
I was looking for a landing gear for my x525 to put some stuff under it .. and it came up with this
http://www.goodluckbuy.com/x600-x525...pcs-black.html
but im confused how are you going to mount it on...... what else should I get with this ?
thanks
jy0933 is offline Find More Posts by jy0933
Old Jul 15, 2012, 02:03 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Thats for a diff. x525 it does not work with the HK x525 At least it does not look like it would work
This is what i used http://www.ycopter.com/FLYINGROBOT-5...4_4637345.aspx
thanks
gitit20 is offline Find More Posts by gitit20
Old Jul 15, 2012, 02:06 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
the x525 i got is this one I assume they are the same one?
http://www.goodluckbuy.com/x525-v3-q...lticopter.html
otherwise I might just get one of this and drill a hole on it
Old Jul 15, 2012, 05:46 AM
gitit20 is offline
gitit20's Avatar
Joined May 2012
Yes that's the one I have
Old Jul 15, 2012, 09:40 AM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
My x525 came with no landing gear, just some ghetto rigged spring loaded bouncers on the arm ends. So, I bought a set of heli skids from Trex450, and just drilled small holes in the bottom frame plate to screw the skids to the frame.
topforce is offline Find More Posts by topforce
Help! how do mount a wing on the front if my merv? mini t king Off-road Cars 13 Jul 25, 2012 08:31 PM
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Help! How do i mount the prop on this??? (and tail gear issue) ian_ryeng Beginner Training Area (Aircraft-Electric) 2 May 28, 2008 12:39 PM
How do you mount retracts on Formosa if the stock gear is bent forward? Bonsai Master GWS (Grand Wing Servo) 0 Jan 09, 2005 05:54 PM
Help! How do you install Landing gear on a foamy? kickflipkid687 3D Flying 12 Jan 02, 2005 08:35 AM
