Old Jul 15, 2012, 12:27 AM
SAslinky is offline
Find More Posts by SAslinky
SAslinky's Avatar
Umkomaas, South Africa
Joined Mar 2010
Build Log
Complete a Project in 2014 Build Off - R.C. Veron Bee Bug original size
Third time a charm!
This is now the third build off this model has been entered in and I am sure I can do it this time.
Having been busy with that thing we call "making a living" I have had little or no time to get back into finishing the Bee Bug, but I am sure that over the course of this year it will be completed.
Ok so finally I have started to put the Bee bug together.
I have decided to keep all dimensions the same as the original control line version.
For power I am going to use electric (still to decide what size as I have a few to chose from) with aileron and elevator control.
Here are a couple of pictures of the start I have made.
Lionel
SAslinky is offline Find More Posts by SAslinky
Old Jul 15, 2012, 12:52 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Watching with interest Lionel. Should be a hot little number!
Sundancer is offline Find More Posts by Sundancer
Old Jul 15, 2012, 06:36 AM
owlsabie is offline
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Good stuff Lionel!! Mines still on the to-do list . . . .
owlsabie is offline Find More Posts by owlsabie
Old Jul 15, 2012, 10:29 AM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Subscribed. I wanted to build a bee bug when I was flying control liners way back when. It will be great to see how it goes when free of tether!
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 16, 2012, 02:03 PM
SAslinky is offline
SAslinky's Avatar
Joined Mar 2010
Its going to be real fun to fly, my brother wants me to put a Tee Dee .049 in it like the control line version we had, I think that would just be way over board
sparks
I hope it does not act like a C/L model when free from a tether!!!! but at least give me some sort of control.
Old Jul 16, 2012, 02:14 PM
SAslinky is offline
SAslinky's Avatar
Joined Mar 2010
Tonight i did a little more on the wing.
I finished off the leading edge, trailing edge in front of the ailerons was installed, wing tips glued on and wing sanded.
Then I cut the ailerons out of the wing, now all I need to do is fill the ailerons leading edge with wood and sand them.
Starting to take shape but its a "as I go I modify" type build!
Here are some pictures of the progress.
Old Jul 16, 2012, 10:58 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I think it will bazz about in the the sky wherever it is pointed with those full span almost full trailing edge chord ailerons, slinky! Great!
sparks
Old Aug 19, 2013, 03:38 AM
SAslinky is offline
SAslinky's Avatar
Joined Mar 2010
So the build continues......................................... I have found the box where the wing was packed away and now to tidy the work bench and start making an aeroplane that flies!
I have decided on a power source and it is going to be the Turnigy C1822-2100 motor, should be enough power for the model.
Lionel.
Old Aug 19, 2013, 06:04 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Go to it Lionel; I am looking forward to seeing the result; I had two Bee Bugs back in the day, one with the recommended E.D. Bee, which was - OK, and one with a Frog 150 which was terrific, although it took a bit of keeping up with!
Old May 29, 2014, 05:07 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
It's been a while, Lionel - any progress?
Old Sep 29, 2014, 11:04 PM
SAslinky is offline
SAslinky's Avatar
Joined Mar 2010
Started again on the Bee Bug
Ok, now that work life has got a little less hectic, I decided I MUST finish the Bee Bug off.
I got all the pieces out and guess what............................ one aileron is missing, and for the life of me I cannot find it. Only thing to do is make a new one, so I found a piece of scrap wood and sanded it down to match.
Now I am back to where I was, um???? 2 years ago
As the build continues I will take photos.
IT WILL BE FINISHED!!!!!!!!
Lionel.
Old Sep 30, 2014, 12:06 AM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Originally Posted by SAslinky View Post
Ok, now that work life has got a little less hectic, I decided I MUST finish the Bee Bug off.....IT WILL BE FINISHED!!!!!!!!
That's the spirit, Lionel!!
Colonel Blink is offline Find More Posts by Colonel Blink
Old Sep 30, 2014, 12:30 AM
Paul_BB is offline
Find More Posts by Paul_BB
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Good luck Lionel.
Paul_BB is offline Find More Posts by Paul_BB
Old Sep 30, 2014, 01:31 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hey, great to see you back Lionel, loking forward to seeing this little beauty finished!
Old Dec 29, 2014, 09:01 PM
SAslinky is offline
SAslinky's Avatar
Joined Mar 2010
Getting There!!!!!
So now that there is only a couple of days left I decided that I must finish the Bee Bug.
A few hours of work produced something that almost looks like an aeroplane.
I now need to cover the wings, dope the fuselage and tail feathers and spray, I must also test the motor to make sure it works as it has been lying around in a box and the wires pulled out but dont look to be broken.
Here are some pics of what has happened in "LAST MINUTE SMITH'S " workshop in the past couple of days.
The weather does not look good for the foreseeable future for a test flight but I might get lucky as the weather has been changing on an hourly basis here at the moment.
Lionel.
Build Log Britkit Build Off 2012 - Mercury Mars - Plans Published, see post #90 Sundancer Vintage & Old-Timer Designs 89 Mar 18, 2013 08:59 AM
Build Log Britkit build off Fleetwing 65" rabidrue1 Vintage & Old-Timer Designs 69 Nov 16, 2012 08:23 AM
Build Log Britkit Build Off April 2012 - Veron Deacon cd_webb Vintage & Old-Timer Designs 66 Sep 22, 2012 06:54 AM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
Build Log Britkit Build off 2012 -Veron Coupe' sparks59 Vintage & Old-Timer Designs 49 Jul 22, 2012 08:20 AM
