Old Jul 14, 2012, 10:24 PM
b15605 is offline
Find More Posts by b15605
Joined Oct 2009
Plank tapering techniques
I am currently building a typhoon and it requires a lot of tapered planks.
My question is: what way is best for tapering planks. My method seems quite tedious though it works:
A. Make marks every two inches along the plank as guides
B. mill off using a small wheel grinder and check measurements with calipers as i go
C. Block sand once general shape is achieved to straighten edges.
This seems to take forever and I am wondering if there are better methods out there or better tools?
b15605 is offline Find More Posts by b15605
Old Jul 14, 2012, 11:31 PM
CGAux26 is online now
Find More Posts by CGAux26
United States, TX, Tomball
Joined Aug 2007
I have built just one plank-on-frame hull. I used a small pocket plane to trim the edges of some of the cheater planks, and a sanding block, too. My planks were balsa, so it cut easily.
CGAux26 is online now Find More Posts by CGAux26
Old Jul 14, 2012, 11:35 PM
LONGBIKE is offline
Find More Posts by LONGBIKE
If you cant find it Build it!
LONGBIKE's Avatar
NEAR ST. LOUIS ILL. SIDE
Joined Jan 2006
I use a disc sander, its fast and makes straight edges
http://s.shld.net/is/image/Sears/009...sm=0.9,0.5,0,0
These work great also.
LONGBIKE is offline Find More Posts by LONGBIKE
Old Jul 15, 2012, 06:07 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
But you're pretty much stuck with the careful measuring and marking part! I use inexpensive digital calipers to measure ...
patmat2350 is offline Find More Posts by patmat2350
Old Jul 15, 2012, 09:15 AM
A-37 is offline
Find More Posts by A-37
A-37's Avatar
Cortland OH
Joined Dec 2007
I run the lead of a pencil (not the tip) along the plank edge to which the next plank will butt. Then I lay down the new plank and press it against the penciled line where the new plank overlaps the previous plank. The lead will transfer to the new plank. There's your trim line.
Carbon paper also works but who has carbon paper anymore?
Ed
A-37 is offline Find More Posts by A-37
Question Wing taper: strait LE, strait TE, or dual taper? psguardian Foamies (Scratchbuilt) 5 Jul 15, 2012 11:11 AM
Discussion Elevon tapering angle? Teamsherman Australia 42 Jul 08, 2012 10:10 PM
Discussion Exhaust Tube? To taper or not.Opinions please Hover or die Electric Ducted Fan Jet Talk 4 Jun 14, 2012 09:43 AM
Help! G-62 crankshaft taper mcjustis Engines 2 May 13, 2012 11:09 PM
For Sale Losi Taper Pin Red Truck Tires BNIP EverettY Cars - Trucks and Parts (FS/W) 2 Mar 12, 2012 11:14 PM
