Old Oct 15, 2012, 08:11 PM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
For some reason, I thought you were using RGB leds with that controller.
prototype3a is offline Find More Posts by prototype3a
Old Oct 15, 2012, 09:10 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Yep...that looks great!
Originally Posted by Barn-E-Stormer View Post
This is with a piece of white Oracover laid over top of the wing. Keep in mind the backing is still on the covering. Should be even brighter with the backing off.
I don't think it needs any transparent covering. The colors shine thru the white just fine.
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Oct 16, 2012, 05:42 AM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Kadet Night Flyer Wing test (0 min 25 sec)
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Oct 16, 2012, 07:24 AM
Joined Apr 2006
I wonder what that would look like if you had used strips of red green and blue.
Keep in mind that I do have some RGB strip in my stash.
Old Oct 16, 2012, 09:34 AM
Dark Yet??
Joined Dec 2009
The right wing is red and left is green, so I used the white and blue.
Old Oct 16, 2012, 06:12 PM
Dark Yet??
Joined Dec 2009
The wing is wired. Just waiting on some connectors to come in. I ordered some Molex connectors from Tower Hobbies. Will still have to use multiple connectors but they are solder type and should work well, I didn't like the ribbon cable.
  • Leading edge panel LEDs -- 4 wires
  • RGB panels -- 8 wires
  • 2 servo extensions
  • 2 "Accessory" power sockets on the wing tips
Old Oct 17, 2012, 07:39 AM
Dark Yet??
Joined Dec 2009
Must of been providence, that this song would be on the radio when I made this clip.
Full Wing Test (0 min 34 sec)
Old Oct 17, 2012, 07:59 AM
Joined Apr 2006
That's awesome Barney!
Old Oct 17, 2012, 09:25 AM
Dark Yet??
Joined Dec 2009
THANKS!!
Working on the tail next.
Old Oct 17, 2012, 02:43 PM
Dark Yet??
Joined Dec 2009
Got the empennage all wired up and tested.
Old Oct 17, 2012, 07:10 PM
Dark Yet??
Joined Dec 2009
I put 2 meters of white strip inside the fuse. Will probably add some more as I get everything finalized. Now I am dying to start covering, my favorite part.
Going to start with the fuse. I will do the bottom and sides, leaving the top open to work thru as I do the final assembly.
Old Oct 19, 2012, 11:55 AM
Dark Yet??
Joined Dec 2009
Most of the fuse is covered. I left the top open to help with the final assembly. Made the windows red/green.
Old Oct 19, 2012, 12:24 PM
IFLYOS is offline
IFLYOS's Avatar
Joined Feb 2001
That is turning into one awesome bird!
Old Oct 19, 2012, 12:50 PM
Dark Yet??
Joined Dec 2009
Thanks!
Old Oct 19, 2012, 01:14 PM
Joined Apr 2006
Too late now but you should have punched out some kind of pattern in the sides of the plane. I was thinking a dot matrix of "BARN" would have been cool.
All the same... Very nice!
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
