Old Oct 10, 2012, 07:56 AM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
You mean all the panels behind the leading edge in white?
The fuse is going to be all white.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Oct 10, 2012, 09:30 AM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
Yeah.. only colors on the leading edge of the wings and maybe a racing stripe on the fuse?
prototype3a is offline Find More Posts by prototype3a
Old Oct 11, 2012, 07:43 PM
Dark Yet??
Joined Dec 2009
Glassing the center of the wing.
Cut your fiberglass cloth so the fibers are at a 45 degree to any long edges. This prevents fraying along the edges.
Use thin CA to tack down one end, then pull it tight enough to get the wrinkles out and produce a smooth surface.
Use an old credit card or room key to squeege 30 minute epoxy on as sparingly as you can but still filling the weave.
Tack down the other end with CA.
Hit it with a heat gun to make the epoxy thin out and make a glassy surface.
Old Oct 11, 2012, 07:45 PM
Dark Yet??
Joined Dec 2009
Let epoxy set, then trim the edges.
Old Oct 11, 2012, 07:52 PM
Dark Yet??
Joined Dec 2009
I wanted lasers on the wing tips, pointing forward. I have not found any laser diodes that really make a nice visible beam. This one puts out a nice beam but unless there are some particles in the air, it does not show up. That may not be a problem since at Summersville it's usually foggy at night or at least the smoke from fireworks floating in the air.
Can anyone suggest a good visible green laser diode?
Old Oct 12, 2012, 07:02 AM
Joined Apr 2006
Green would be the best color for visibility... unfortunately I don't know where to buy one. I would also look for something around 15mW if you can find it.
It looks like you finally got the red laser diode working. What prevented it from working before?
Old Oct 12, 2012, 07:04 AM
Dark Yet??
Joined Dec 2009
This is a different one. It has a lens on the front to focus the beam. I never got the other diodes to work.
Old Oct 12, 2012, 08:57 AM
Joined Apr 2006
Ahh.. A cluster of red ones on one wing tip and green on the other would be pretty cool...
Old Oct 12, 2012, 09:00 AM
Joined Apr 2006
Hrmm...
https://www.sparkfun.com/products/9906
Old Oct 12, 2012, 08:09 PM
Dark Yet??
Joined Dec 2009
I looked at that laser and it had all kinds of warnings and cautions, sounds dangerous.......
So I ordered 2 of them.
Old Oct 12, 2012, 09:09 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Like!!
karl k is offline Find More Posts by karl k
Old Oct 15, 2012, 06:40 PM
Dark Yet??
Joined Dec 2009
I decided to go with my original color scheme. It will have colored panels behind the leading edge. I hope to get one side wired up temporary and see what it looks like with white covering. May have to use some transparent red and green on the leading edge panels.
Old Oct 15, 2012, 06:45 PM
Dark Yet??
Joined Dec 2009
Added this small piece of CF rod to support the LED strips. It might even add some strength. The strip is glued to the CF rod on one end and I cut a slit in the trailing edge and glued the other end into it. The leading edge panels are on circuit by their self, and I plan to leave them on all the time. The bays are wired to the RGB controller. I am going to add a socket to the wing tip for the lasers to plug into and be removable instead of built into the wing.
Old Oct 15, 2012, 07:21 PM
Dark Yet??
Joined Dec 2009
Old Oct 15, 2012, 07:31 PM
Dark Yet??
Joined Dec 2009
This is with a piece of white Oracover laid over top of the wing. Keep in mind the backing is still on the covering. Should be even brighter with the backing off.
I don't think it needs any transparent covering. The colors shine thru the white just fine.
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
