Old Oct 05, 2012, 02:01 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Yes I was thinking of the tips and the next 2 panels done in transparent red/green.
I boxed in the bottom hatch opening with CF and made this hatch out of lexan. It still has the protective film on it. A clear hatch will let more light out.
I need cooling air to have a exit. Proto...could you mill out some nice slots in the lexan like on the bottom of the Extra canister tunnel?
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Oct 05, 2012, 02:35 PM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
I should be able to do that... Sketch up what you want and I'll see if I can't write some code to do it.
prototype3a is offline Find More Posts by prototype3a
Old Oct 07, 2012, 02:29 PM
Dark Yet??
Joined Dec 2009
Rainy day, good time to work on this hatch.
I drew up an array of exit holes and cut this template on the vinyl cutter. Put the template on the lexan cover. Now it's time for the Dremel.
Old Oct 07, 2012, 02:38 PM
Dark Yet??
Joined Dec 2009
As a kid I couldn't color inside the lines. I'm not much better with a Dremel but it turned out OK. Used some super magnets to hold it on, no screws.
Old Oct 08, 2012, 02:17 PM
Joined Apr 2006
I take it, you don't need me to CNC it anymore? :P
Old Oct 08, 2012, 02:22 PM
Dark Yet??
Joined Dec 2009
No but thanks for the offer. A rainy Sunday took care of that.
Thinking about the cables from the wing to fuse. I don't want to have 5 cables to sort out and attach in the dark. Considering using a 40 pin ribbon cable and header for one wing connection. The minimum I can get by with is 12 wires, and most connectors get large in that number of pins. A 40 pin ribbon cable I can double up the current carrying wires.
Old Oct 08, 2012, 02:44 PM
Joined Apr 2006
Why not cut up some JST-XH balance extensions? Why do you need 12 wires?
Old Oct 08, 2012, 05:54 PM
Dark Yet??
Joined Dec 2009
  • Servo ground
  • Servo power
  • Right Aileron signal
  • Left Aileron Signal
  • LED ground
  • Red
  • Blue
  • Green
  • Laser ground
  • Laser power
Old Oct 08, 2012, 07:29 PM
Dark Yet??
Joined Dec 2009
So I am considering the wing color scheme.
How about leaving the red/green leading on all the time and wire the bays to the RGB controller. They will be able to strobe, chase and fade. I could do the leading edges also but I have found large strips flashing to be too disorienting.
This would be 6 meters of LED strip, 360 individual LEDs, pulling 1.2 amps at full brightness.
Old Oct 08, 2012, 07:39 PM
Dark Yet??
Joined Dec 2009
A note on LED tape.
There are two kinds of LED tape I find most common for our purpose. The LED strip from Hobby King and from Hobby Partz.
Both LED strips seem to be electrically the same, they draw the same current vs voltage. 200ma at 12v per meter. Same brightness.
The Hobby King is physically a larger strip, thus heavier but easier to solder.
The Hobby Parz is physically smaller (exactly 6mm wide so it fits perfectly on the edge of depron foamys) but is harder to solder. The pads are extremely small and need to be "tinned" before attaching wires.
Old Oct 09, 2012, 06:38 PM
Dark Yet??
Joined Dec 2009
So does anybody have a comment on the wing? If you think it sucks just tell me. I can take it.
Old Oct 09, 2012, 06:39 PM
Dark Yet??
Joined Dec 2009
Putting some fiberglass and epoxy on the center section.
Old Oct 09, 2012, 06:47 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
I love the look of wing!!! That will stand out well, and make it easy to see in the sky. Go for it!
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Oct 09, 2012, 07:29 PM
Dark Yet??
Joined Dec 2009
Thanks!
Old Oct 10, 2012, 06:51 AM
Joined Apr 2006
I don't like it. I would do the interior in solid white so it is more neutral with the color leds behind it.
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
