Old Oct 02, 2012, 06:21 PM
weathervane is offline
Find More Posts by weathervane
Left, NO your other left!
weathervane's Avatar
United States, MD, Baltimore
Joined Jun 2008
I love the build. You have done a great job. I'm looking forward to seeing it when it is done. Here is a video of my Kadet Sr night flyer.
Kadet flying at night. (10 min 16 sec)
-Andrew
weathervane is offline Find More Posts by weathervane
Old Oct 02, 2012, 06:24 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Finished the wing saddle and the wing fillet. Shaped the leading edge of the wing. Wing is complete except for glassing the center.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Oct 02, 2012, 06:33 PM
Dark Yet??
Joined Dec 2009
Weathervane, that is awesome! Great job. Could you post some pics showing the plane up close and some of the wiring? It looked like clear covering on the fuse and transparent red/green on the wing with matching LED color? Please give me some more details, yours is a great example to go by.
This the foamy I built to test the RGB controller. Should make some nice effects on the Kadet.
RGB Foamy (2 min 6 sec)
Old Oct 02, 2012, 06:54 PM
Dark Yet??
Joined Dec 2009
The ESC is going to be right behind this top cutout for cooling.
Old Oct 02, 2012, 06:58 PM
Dark Yet??
Joined Dec 2009
Made a servo tray and mounted it low and aft in the cabin area. I wanted it low enough to put a tray at the bottom of the window level to hold the light controllers and other electronics.
Old Oct 02, 2012, 07:05 PM
Dark Yet??
Joined Dec 2009
In the past I have covered planes and then found the push rods to be too floppy and unsupported. Made up all the linkages, test fit the horns and braced all the rods.
Old Oct 03, 2012, 06:01 PM
Dark Yet??
Joined Dec 2009
The battery hatch is going to be on the bottom. I cut out one cross brace. In case the fuse would be weakened by the large hatch opening, I boxed it in with CF.
Old Oct 03, 2012, 06:18 PM
Joined Jun 2008
Thank You
Thank you. It is not my design. I coppied it from someone else. Here is a build thread that I did.
http://www.wattflyer.com/forums/showthread.php?t=56979
Yes, you are right. There are red, green and blue LED's under the red, green and blue transparent covering. The fuse has white LED's under regular white monokote. The white defuses the color and makes it look like a soft white light bulb.
There are 231 LED's in there. (95W, 49R, 50G and 37B) All hand soldered to bare copper wire. About 500 solder joints in total. Post #65 on page 3 has the info on where I got my LED's from.
-Andrew
[QUOTE=Barn-E-Stormer;22896708]Weathervane, that is awesome! Great job. Could you post some pics showing the plane up close and some of the wiring? It looked like clear covering on the fuse and transparent red/green on the wing with matching LED color? Please give me some more details, yours is a great example to go by./QUOTE]
Old Oct 03, 2012, 06:35 PM
Dark Yet??
Joined Dec 2009
I read thru the build. Very nice.
Today I ordered 25 meters of LED strip and another RGB controller. I hope to use the Cree lights in the fuse.
Old Oct 03, 2012, 06:54 PM
Joined Jun 2008
Oh yea. One more thing. With the leading edge of the wing sheeted and a solid firewall. The plane can and will totaly disappear. mine does from time to time. Only when coming straight at you.
-Andrew
Old Oct 04, 2012, 07:02 AM
Dark Yet??
Joined Dec 2009
I don't plan on sheeting the leading edge. Was that just a mod you did or did I miss that on the plan?
Old Oct 04, 2012, 02:49 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Have you decided on your covering scheme? I hope you go with white all over, it will really allow your RGB controller to shine!
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Oct 04, 2012, 03:36 PM
Joined Jun 2008
Ok, your plane is different than mine. My plane was a basket case when I got it. The guy was going to toss it. I thought it was a plan built plane. I'm guessing it was not.
I have built up ribs in my wing and a sheeted LE. Mine is also a 3 channel plane.I also had to cut the hatch into the nose. Mine was already a tail drager.So I really have no idea where and what mine is from.
-Andrew
Old Oct 04, 2012, 07:41 PM
Dark Yet??
Joined Dec 2009
Yes I am going all white on the fuse, lit from inside. The wing will be white but with some color accents. I don't know whether to use all white covering and just LEDs to change the color or maybe some panels of red/green on the wing tips. I wish I had made the wing tips out of depron, then they could be lit from inside. I guess the wing tips and the front of the fuse will have some strips on the outside.
Any suggestions and/or pictures are appreciated!
Old Oct 05, 2012, 09:48 AM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
I would add a strip of color to the wings just inboard of the tips to help with any day flying. Otherwise I think I like the idea of all white covering.
prototype3a is offline Find More Posts by prototype3a
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
