Old Aug 04, 2012, 07:29 AM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
That is a beautiful job bsbauman. On thing that impressed me was not seeing any connection wires. Nice neat job.
Update: The build slowed down due to a death in the family. The plan was for this plane to be ready for Wally's Squadron, Summersville WV by Aug 18th. That won't happen. So to be ready for Wally's I am building two foamys and testing some of the new gear and techniques I hope to use in the Kadet.
After Wally's I will get back to the Kadet and have plenty of time to finish it up nice.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Aug 04, 2012, 07:33 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am sorry to hear of the loss and my best goes out to you and your family.
Good decision on putting the build on hold, after all the hours you will eventually have in this project, you will be happy you did not rush anything
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Aug 04, 2012, 08:41 PM
Dark Yet??
Joined Dec 2009
I built this foamy to have for Wally's. It uses the RGB controller I plan to use later in the Kadet.
Old Sep 26, 2012, 07:43 PM
Dark Yet??
Joined Dec 2009
Time to get back to work on the Kadet.
My friend gave me this motor to use. I checked it out and put a new prop adapter on it.
EFlite Power 46 with EFlite 60A ESC.
Old Sep 26, 2012, 07:50 PM
Dark Yet??
Joined Dec 2009
Attached the firewall with 30min epoxy. Drilled and installed the blind nuts for the motor mounts.
Since this is a dedicated night flyer, I am not going to make the wooden cowl. If anything I will try to find a fiberglass cowl I can light up from the inside.
Old Sep 27, 2012, 12:13 AM
USA, GA, Atlanta
Joined Nov 2008
That Power 46 is a beast, you will like it. What batts and prop do you plan to use?
I have a Power 46 in a Sundowner 50, on 6s with 10x10 prop- setup has been rock solid for 2 plus years and run hard... it will do about 90-95mph level, when using high C batteries.
Old Sep 27, 2012, 08:48 AM
Dark Yet??
Joined Dec 2009
I won't need ultimate power so I will start with 4S and maybe a 10X6 prop.
Old Sep 27, 2012, 08:49 AM
USA, GA, Atlanta
Joined Nov 2008
cool! I look forward to seeing your numbers
Old Sep 27, 2012, 12:54 PM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
Just FYI..
I recently learned that the catalyst added to epoxy to speed the cure actually weakens the bond and the epoxy. So, always use very slow cure epoxy when you need maximum strength.
prototype3a is offline Find More Posts by prototype3a
Old Sep 27, 2012, 01:48 PM
Dark Yet??
Joined Dec 2009
Yes I always use 30 minute to join wings or other high stress joints. 5 minute for everything else.
Old Sep 27, 2012, 01:52 PM
Dark Yet??
Joined Dec 2009
Now that the firewall is attached, the sides have to be sheeted. Since this is a night flyer, I used a leather punch to put some holes for light to shine thru and to lighten it a bit.
Old Sep 27, 2012, 01:57 PM
Dark Yet??
Joined Dec 2009
Laid the fuse on each side flat, weighted, and glued with thin CA. Trim the edges off flush with the fuse.
Old Oct 01, 2012, 11:56 AM
Dark Yet??
Joined Dec 2009
I decided to leave the front sheeting off. Let more light out from inside.
Old Oct 02, 2012, 02:10 PM
USA, GA, Atlanta
Joined Nov 2008
Very wise move to cut all those lightening holes... I have seen others disappointed when they have spent much time lighting up the inside, only to find no light escapes the fuse through the sheeting... I cannot imagine that kind of frustration!
You are on a great track, keep up the good work!
Old Oct 02, 2012, 06:17 PM
Dark Yet??
Joined Dec 2009
Thanks BS!
I need some input on the next stage. The airframe is mostly finished, a clean canvas for a night flyer masterpiece. Considering how to do the LEDs. From all the pics I have looked at, white covering lit from the inside seems to be the way to go.
The fuse should be easy. White covering lit with white lights from the inside. The tail feathers will have to small pieces of LED strip or individual LEDs.
The wing has options. Cut notches in the top of the ribs and run LED strip, like on the glider, or light each "box" of the wing structure separately. I can use different colors and my RGB LED controller can make patterns. I wish I had made the wing tips out of 3mm depron. Then they could be lit from inside.
Besides LED strip I have some Cree lamps, used to make flashlights. Very small and super bright. Also I go some 3 and 5 watt assemblies to experiment with and this other little component.
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
