Old Jul 19, 2012, 08:16 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Now we have two complete sides.
At this point I was thinking...... I have a fuselage template. So I laid the fuse side down on a piece of luan plywood and traced the outline. I may use that on a later project to make a fuse from scratch.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Jul 21, 2012, 09:12 AM
Dark Yet??
Joined Dec 2009
With the two sides complete, now they have to be joined. The fuse sides are turned upside down on the fuse plan and pinned in place. Then you start adding cross members to tie the two sides together.
Old Jul 21, 2012, 09:16 AM
Dark Yet??
Joined Dec 2009
Paint cans and squares help keep things lined up.
Old Jul 21, 2012, 10:33 AM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
You know what? I love a stick frame plane being built!
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Jul 22, 2012, 02:33 PM
Dark Yet??
Joined Dec 2009
The fuse comes together quickly.
Old Jul 22, 2012, 02:36 PM
Dark Yet??
Joined Dec 2009
I'm doing a tail dragger so I put in a plywood plate for the gear to mount to. I may add some more supports after I see exactly where the gear will bolt in.
Old Jul 22, 2012, 08:41 PM
Dark Yet??
Joined Dec 2009
Most of the fuse is now complete. This side template will come in handy one day. I need some tail feathers to put the final pieces in the fuse and get everything aligned just right.
Guess I'll just have to build some....
Old Jul 23, 2012, 07:18 PM
Dark Yet??
Joined Dec 2009
Rudder
  • Plan
  • Protector
  • Cut
  • Cut
  • Cut
  • Cut
  • Glue
  • Glue
  • Glue
  • Hinge
Old Jul 23, 2012, 07:21 PM
Dark Yet??
Joined Dec 2009
My rudder did not turn out as good as I would like. The piece of wood for the rudder trailing edge was not symmetrical. It came out kinda warped.
Old Jul 23, 2012, 07:25 PM
Dark Yet??
Joined Dec 2009
Stab is the same thing. A razor saw and miter sander come in handy for all those angle cuts.
I used some scrap to block up the TE of the elevator so it won't come out like the rudder. Other kits I have built used different material for the TE of all control surfaces.
Old Jul 23, 2012, 07:27 PM
Dark Yet??
Joined Dec 2009
Finished stab and elevator. I made the area where the control horn goes a little wider.
Old Jul 24, 2012, 07:16 AM
Dark Yet??
Joined Dec 2009
I put in a plywood plate to mount my tail wheel bracket to.
Old Jul 26, 2012, 08:26 PM
Dark Yet??
Joined Dec 2009
I added some more braces to the LG mounting plate. Wish I had a little taller set of gear. CF would be nice.
Old Jul 26, 2012, 08:31 PM
Dark Yet??
Joined Dec 2009
Starting to look like an airplane.
How about some pics of your night flyers? I have to make the final decisions on colors soon. I am leaning toward mostly white covering lit from inside, with red and green strips on the wings and tail.
Old Aug 03, 2012, 09:11 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
She is coming together well and looks awesome!
The bones look beautiful
I agree with your instinct to use white. For my night flyers, I prefer to use a solid white covering on the top and usually a transparent colored covering on the bottom. The effect is that it looks like any other plane during the day, but at night the white covering reflects the colors of the LEDs you used. The transparent bottoms also can be fun because not only do they allow you to show off the frame underneath, but they also play tricks with the LED lights and reflect different colors differently.
Here are some of my Addiction X-
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
