Old Jul 17, 2012, 09:16 AM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
The bottom dihedral brace is made to be the strongest. It was already very close to 6mm so I just used two rods in the slot and cut the slot for another piece of 6mm strip in the spars. I glued that in with epoxy. Once it sets up I can sheet the center.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Jul 17, 2012, 09:26 AM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
This is coming along really nice. I appreciate how you are documenting the dihedral change. Years ago, when carbon was just to hard to come by, I remember cutting new braces out of lite ply and sanding a little at a time till I was certain that it all fit properly. Much easier nowadays!!
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Jul 17, 2012, 03:13 PM
Dark Yet??
Joined Dec 2009
Now the top of the wing is sheeted.
The directions say not to shape the leading edge until the wing has been fit to the fuse.
I have been looking at the ailerons. I may just use the trailing edge, after it is cut off. It looks a bit small. I don't have any aileron stock handy so a trip to the hobby store is in order. On other kits I have done in the past, they had you glue a piece of spruce to the hinge face for reinforcement. I may do that. I thought about using a piece of 6mm CF strip, but it would be hard to cut the slit for CA hinges. Robart style would work.
Time to start on the fuse.
Old Jul 18, 2012, 10:21 AM
Dark Yet??
Joined Dec 2009
There was no science behind my aileron choice, I used what I have. A 36" piece of aileron stock, cut in half gave me 18" barn door ailerons. Using a caliper I cut the trailing edge off where it would be the same thickness as the aileron stock. This still left plenty of wood for strength.
Old Jul 18, 2012, 10:24 AM
Dark Yet??
Joined Dec 2009
Mark the two pieces for hinging. I will be using CA hinges. A hinge slotting blade makes quick work of all those slots.
Old Jul 18, 2012, 10:42 AM
Dark Yet??
Joined Dec 2009
After cutting all the slots, the leading edge of the aileron needs to be shaped to a "V".
Now we have one complete aileron. Just need one more......
Old Jul 18, 2012, 10:44 AM
Dark Yet??
Joined Dec 2009
Shazam!
Old Jul 18, 2012, 11:30 AM
BobBoxKite is offline
Find More Posts by BobBoxKite
Joined Sep 2011
Barn, I am glad to see you doing one. I am about to start building my 3rd Senior Kadet. I will be scratch building mine. Let me know what your power plant will be. I look forward to watching you build yours.
Bob(N2RYD)
BobBoxKite is offline Find More Posts by BobBoxKite
Old Jul 18, 2012, 12:20 PM
Dark Yet??
Joined Dec 2009
A friend offered to give me a Eflite power 46. I will use that on 4S.
Barn(KK4GST)
Old Jul 18, 2012, 12:26 PM
Dark Yet??
Joined Dec 2009
Now a place to mount our aileron servo. I use pins to nail it all together, then thin CA, then cut the pins off. I boxed the top of the servo in to have a place to seal the covering to.
Old Jul 19, 2012, 10:19 AM
Dark Yet??
Joined Dec 2009
Now the wing is done.
Moving on to the fuse. Lay the fuse section of the plan out. You will have to cut one part off the sheet and tape it together to have the full fuse plan. Iron it out, cover it with protector(protector works better than wax paper), and follow the instructions. It builds right over top of the plan. Take note: some of the sticks are spruce and some are balsa, look at the plan closely. Put all your longest sticks in first. Use pins to hold it down. It looks like a daunting task, but it goes quickly and is a lot of fun.
Old Jul 19, 2012, 10:23 AM
Dark Yet??
Joined Dec 2009
The wood block on the front and other gussets just come printed on a plank. You get to get to cut them out by hand.
Old Jul 19, 2012, 10:29 AM
IFLYOS is offline
IFLYOS's Avatar
Joined Feb 2001
Are you gonna do tricycle gear or convert it to a taildragger?
Tim (AG4RZ)
Old Jul 19, 2012, 01:04 PM
Dark Yet??
Joined Dec 2009
It will be a tail dragger. I don't like nose gear.
I still put the triangles in the sides where LG would go. Using what I have laying around, a set of gear from a Four-Star 60 will fit perfect. I will just glue a plywood floor in the forward part of the fuse bottom.
One side finished......
Old Jul 19, 2012, 08:13 PM
Dark Yet??
Joined Dec 2009
Now with one side built, pull out the pins, cover that side with protector, and build the next side right over top of the first. This assures the two sides are the same.
Down thrust is built into the firewall. If any right thrust is needed I will shim the motor mounts. The plan says no right thrust is needed.
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
