Old Oct 31, 2012, 12:21 PM
prototype3a is offline
Find More Posts by prototype3a
Which one is aileron again?
United States, VA, Christiansburg
Joined Apr 2006
Originally Posted by Barn-E-Stormer View Post
I did the wing tips in different colors for my friend the exiled Republican.
HAHAHAHAHAHA
Thanks!
Any idea where the new Wytheville field is?
prototype3a is offline Find More Posts by prototype3a
Old Oct 31, 2012, 05:43 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
We are looking at 3 different fields, all on private land. We are weighing the options to see which one we will have the longest term relationship with.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Nov 01, 2012, 07:44 AM
Dark Yet??
Joined Dec 2009
Starting to work on the connection board for all the lights.
Old Nov 01, 2012, 07:47 AM
Joined Apr 2006
I've been looking at moving for a month or two now and I may end up closer to Wytheville than the other fields in the area. I hope they find a field that allows night flying. Seems like those are fairly rare for some reason.
Old Nov 01, 2012, 09:16 AM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
I really like how this is turning out. I am really looking forward to how you handle wire management with the addressable LEDS...That's allot of wire to keep looking neat, more than you find in some giant scale aircraft.
I know that in the 35% Extra I had, there were far less leads than in any on my current nightflyers....
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Nov 01, 2012, 12:14 PM
Dark Yet??
Joined Dec 2009
The cable from the wing will have two of the Hitec six pin connectors as mentioned earlier and two servo extensions. These will plug directly to the connection board. It's hard to see in the pic but I have some .1 spacing headers on the board I will use to connect all the wiring from the tail, fuselage, and maybe a landing light. I will crimp servo connectors to all the fuse and tail wiring which will plug onto the headers. Power coming onto the connection board will be either a EC3 or a Deans. The connection board will have to be made with connectors, not hard wired, for easy access and maintenance. If I hook it all up and it works correctly the first time it will be a miracle.
Old Nov 01, 2012, 07:43 PM
Dark Yet??
Joined Dec 2009
Flash back to when the stab was being built.......
I am sure the Kadet designer knows more than I do, but, it looks like the stab needed at least two more sticks so it would have more area to glue to on the fuse. Just the one strip of wood down the middle does not attach to much of the fuse. If I ever build another Kadet I will add some wood to the stab to make it easier to mount on the fuse.
Added some cross pieces to have more area to glue to. I plan on using 30 minute epoxy.
Old Nov 01, 2012, 07:48 PM
Dark Yet??
Joined Dec 2009
Now I have made all the wire attachments on the tail, 6 separate pairs, braided together to form one cable to the attachment board. I test fit the stab at least ten times and got the elevator push rod installed and braced up. Small wood screws will be used to pull the stab down tight while the glue dries.
Wish I had a extra set of hands....
Old Nov 01, 2012, 08:20 PM
Dark Yet??
Joined Dec 2009
One more mock up and measure before the glue hits. Only get one chance.
Old Nov 02, 2012, 09:22 AM
Dark Yet??
Joined Dec 2009
The empennage is glued in.
Old Nov 02, 2012, 08:11 PM
Dark Yet??
Joined Dec 2009
Crimped servo connectors on the empennage cable and they plug onto a board header. Got the majority of the connection board wired, enough to test the empennage lights. It all works!
Old Nov 03, 2012, 06:09 PM
Dark Yet??
Joined Dec 2009
Finished the wing cable and all the RGB wiring on the connection board. Also put in a header for the "always on" circuits, like in the fuse and leading edge of the wing. With everything on full bright it draws 2.8 amps.
Old Nov 03, 2012, 06:11 PM
Dark Yet??
Joined Dec 2009
More pics.
Old Nov 04, 2012, 07:36 AM
plcline67 is offline
Find More Posts by plcline67
plcline67's Avatar
United States, WV, Montcalm
Joined Sep 2007
Looks good, Barney!
plcline67 is offline Find More Posts by plcline67
Old Nov 07, 2012, 03:23 PM
Dark Yet??
Joined Dec 2009
Fully assembled. Landing gear and tail gear mounted. Main gear may need to be taller. Had to make a spot for the batteries to be mounted and tied down. Used a 4000mah 4 cell for the motor and a 2600mah 3 cell for the light system. Any less battery and it will be tail heavy. I put long standoffs on the motor for more leverage against the tail heavy condition. Balance is right on the main spar now. Ready for a test flight!
Discussion Sig Kadet Senior - ARF. Good For A Newbie? itsme2 Electric Plane Talk 23 Feb 15, 2013 03:13 PM
For Sale Kadet senior unfinished kit lpu price drop steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 16, 2012 06:46 AM
For Sale sig kadet senior kit(started) lpu steeg Aircraft - Fuel - Airplanes (FS/W) 1 Jul 07, 2012 11:28 PM
Wanted Wanted to buy Sig Kadet Senior Kit shadowridertcw Aircraft - General - Miscellaneous (FS/W) 1 Jun 13, 2012 05:13 PM
