Old Mar 15, 2013, 10:18 AM
BAMA1 is offline
Find More Posts by BAMA1
Joined Jan 2013
Originally Posted by caprini83 View Post
What did you mean when you said you put a cap on your radio ? Thanks for all the links, looks like my Neptune will be getting some upgrades
That wasen't me it was Hemiblas. No prablem
BAMA1 is offline Find More Posts by BAMA1
Old Mar 15, 2013, 11:03 AM
hemiblas is offline
Find More Posts by hemiblas
United States, CO, Aurora
Joined May 2009
I try to add one of these
http://www.hobbyking.com/hobbyking/s...Protector.html
or these
http://www.hobbyking.com/hobbyking/s...3uf_3sec_.html
to the radio receiver if I think the bec in my esc is going to be pushed to its limits. Ok, basically this means that any esc that is not a castle ice 100 (that has a 5 amp bec), I put one of those capacitors on. they really work. With 2 digital servos on a turnigy plush, the servos will pull too much current and the bec overheats and shuts down, which cuts power to your receiver. Once you stop moving the servos the receiver will re-initialize and you would never know you had a problem. The capacitor will store energy and if the servos are pulling too much the capacitor discharges, when the servos are not being used the capacitor charges waiting for the next heavy load to supply needed current. On my cheap esc's it keeps me from losing control of my airplanes mid flight. Some receivers take 1 second to re-initialize, others take longer.
The 3 second capacitor is great for a plane with retracts or other heavy loads that could put more stress on your bec.
I'm thinking on your plane, when you run the speed controller for a while it gets hot. The bec and the speed controller are on the same board so if one gets hot the other gets hot. When the bec gets hot it is not as effective and just using the servos will make it hotter and the bec will go into thermal shutdown and you lose power to your radio. The caps will put less stress on your bec so it stays cooler over the length of the entire flight, but also supply that needed current if the servo is pulling to much current because you are going really fast and turning and the servo has too much stress.
I hope this makes sense.
hemiblas is offline Find More Posts by hemiblas
Old Mar 15, 2013, 11:09 AM
hemiblas is offline
Joined May 2009
Originally Posted by BAMA1 View Post
My buddy flew his neotune with a 4s,short burst's of speed ONLY or (like him) you
will burn the motor up. Im running a 4300 allum aloy 4s motor with stock servos with a 2650 4s batt and about 97 mph. The esc is mounted outside to help keep cool and for space reasons. http://www.youtube.com/watch?v=zVGVweEIaK0.
I'm up at 6000' so edf's are not pulling as much air or as many amps as someone at sea level. I feel good about a 4S setup where I fly, but yeah someone at sea level running at 4S could see some pretty high currents which could fry the motor.
Old Mar 15, 2013, 11:12 AM
caprini83 is offline
Find More Posts by caprini83
I crash fast
United States, CA, Vacaville
Joined Mar 2013
or these
Okay cool. I will give it a try, when my brown out happened I didn't get any controls back until I unplugged and plugged the battery right back in .I had to would probably 200ft or so To get my plane
caprini83 is offline Find More Posts by caprini83
Old Mar 15, 2013, 12:34 PM
hemiblas is offline
Joined May 2009
Or if not try a new esc. It could be it is overheating as the fan pulls lots of amps from what everyone is saying. I try to buy castle esc whenever I can as they seem to be the most solid from my experience.
Old Mar 15, 2013, 12:40 PM
I crash fast
Joined Mar 2013
I have heard the good and bad about those, but as we all know nothing is perfect. I just purchased a Turnigy dlux 40A SBEC Brushless Speed Controller w/Data Logging esc for my rad jet, if I like it I will buy one for the Neptune as well.
I'm thinking I might want to replace my receivers as well after reading some threads about the Spektrum Ar6100e as that's what I'm running in all my aircraft's right now and going with full range receivers like the AR600 or AR500
Old Mar 15, 2013, 08:01 PM
BAMA1 is offline
Joined Jan 2013
Some of you are talking about the sonic 64 from Hobby King, they have the PNF only for 113$
NitroPlanes has the kit w/motor for 66$ ARF is 95$.
Old Mar 15, 2013, 11:30 PM
Bob Reynolds is offline
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
This is what I did to the bottom of my plane. Makes it legal for jet rallies. The legallity is being able to use the runway like a normal plane would. It flies like any other jet, which is OK.
Bob Reynolds is offline Find More Posts by Bob Reynolds
Old Mar 15, 2013, 11:39 PM
I crash fast
Joined Mar 2013
I was thinging about doing that. I have the same color tape covering my motor wires
Old Mar 16, 2013, 11:07 AM
Mitchie is online now
Find More Posts by Mitchie
Mitchie's Avatar
Canada, QC, Gatineau
Joined Jan 2011
How does it fly with the gear on? I was thinking of modding mine with rudders, using small wheels on the bottom of the rudders, and mounting a stryker wheel in the front.
Mitchie is online now Find More Posts by Mitchie
Old Mar 16, 2013, 08:14 PM
warbirdzzz is offline
Find More Posts by warbirdzzz
Joined Jul 2012
After a few flights I just felt like painting the Neptune and give it some new looks. Didn't know what to do at first but a friend gave me the idea to do a 'Horten' inpired paint scheme. I got a little carried away, put some stickers on it, but I still like it, and it looks awesome flying, the chrome underside in special.
Tell me what you guys think about the paint.
I have one question though: I've noticed my both ailerons are slighty warped on the outer side. When they are flush on the most inner part, the most outer tips stay elevated as if i had two or three clicks elevator up on them (I think you ca make it ou on the pictures). I don't remember if this was already like that when I flew it (yeah, i know), so can anyone tell me if this is normal? And if not, will it change my flight characteristics? I havent had time to fly it since I saw that 'problem'.
Any ideas on how to fix it?
thanks!
Alex
warbirdzzz is offline Find More Posts by warbirdzzz
Old Mar 16, 2013, 10:35 PM
Tucson, AZ, USA
Joined Nov 2000
Never flew it without the gear, so I have nothing to compare it too. I don't see the gear holding it back at all. Short takeoff roll and comes in just a little nose high for slow landings.
Old Mar 17, 2013, 08:09 AM
Mitchie's Avatar
Joined Jan 2011
Warbirdzzz, I like it! Now it needs the canopy mod, and it'll look real . Bob, like the idea, mebbe do something similar, but I'm just stuck on retracts.....
Old Mar 17, 2013, 10:26 AM
I crash fast
Joined Mar 2013
thanks!
Alex
That looks awesome
Old Mar 23, 2013, 02:16 AM
boiko is online now
Find More Posts by boiko
Home of A-10 - Farmingdale NY
boiko's Avatar
United States, NH, Londonderry
Joined Dec 2006
What type of connector comes with the Neptune...XT60 or Deans (T-Plug)?
-mike-
boiko is online now Find More Posts by boiko
Discussion NEPTUNE EDF Planes gillian Hobby Stores 1 Jul 08, 2012 10:58 PM
New Product Neptune EDF Planes gillian Product Announcements 3 Jul 08, 2012 10:57 PM
Discussion Techone F16 foamie EDF ejohn Foamy EDFs 0 Oct 05, 2010 12:43 PM
Data TechOne Hobby Micro F-35 30mm EDF Conversion NitroCharged Micro EDF Jets and Power Systems 2 Dec 27, 2009 12:13 AM
Discussion Techone Hobby Rafale profile EDF dog fart Electric Ducted Fan Jet Talk 2 Jun 26, 2009 07:37 AM
