Old Oct 11, 2012, 10:10 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by madbomber View Post
Condolences, Alby. Hopefully you can repair it. Were those weights that were being taped in to the top of the wings?
I think it was just masking tape to make sure the wing sections didn't slide apart.
Sundancer is offline Find More Posts by Sundancer
Old Oct 11, 2012, 11:43 AM
albyone is offline
Find More Posts by albyone
Albyone
albyone's Avatar
Italia, Lombardia, Monza
Joined May 2006
Yes! is so.
The problem is that the wing works well at the ends.
the extreme wings must bear the full brunt
bayonets must be much more robust. Aluminum are not good
Ciao
Albyone
albyone is offline Find More Posts by albyone
Old Oct 11, 2012, 12:57 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Suggest carbon fibre tubes Albyone, either alone if thick enough walls or filled with hardwood dowels if not.
Old Oct 11, 2012, 02:51 PM
rk295 is offline
Find More Posts by rk295
rk295's Avatar
United Kingdom, England, Ruislip
Joined Mar 2007
Albyone, so sorry to see it crash, hope the damage isn't too bad and the repairs are quick!
rk295 is offline Find More Posts by rk295
Old Oct 11, 2012, 06:06 PM
ColinNZ is offline
Find More Posts by ColinNZ
ColinNZ's Avatar
Auckland New Zealand
Joined Aug 2004
Albyone, Sorry to see this beautiful model spiral in because of a wing failure If you have photos of the offending area it would help us understand that went wrong and maybe someone could offer advice.
ColinNZ is offline Find More Posts by ColinNZ
Old Oct 12, 2012, 01:36 AM
Tomahawk is offline
Find More Posts by Tomahawk
Tomahawk's Avatar
Southern Ontario, Canada
Joined Nov 2001
I looked at the plans and they call for 1/8" steel pins that slide into brass tubes on the inboard wing. Looking at the picture in post 69, I think he did use the pins but it is hard to tell. I assume they bent and then the balsa spar let go where the pins or tubes were stitched to the spar.
I am only guessing!
Chris
Tomahawk is offline Find More Posts by Tomahawk
Old Oct 13, 2012, 01:32 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by albyone View Post
Yes! is so.
Ciao
Albyone
I am only guessing!
Chris
From the above quote it looks as if Albyone MAY have used aluminium joiners, if so that would certainly account for the problem, no way they would be man enough for the job.
Old Oct 16, 2012, 04:29 PM
albyone is offline
Albyone
albyone's Avatar
Joined May 2006
The repair proceeds.
I put three bayonets to connect the wings.
Two bayonets from 4 mm made ​​from aluminum tube filled with carbon.
The third bayonet is composed of an aluminum rail on both sides and rod of carbon 6mm. Now there is a lot of stiffness in the joint and I think it can not happen again what happened
Ciao
Albyone
Old Oct 16, 2012, 05:07 PM
ColinNZ is offline
ColinNZ's Avatar
Joined Aug 2004
Looking at the end rib it appears to be split along the grain and looks like its balsa only, shouldn't the ribs that have the rods passing though them be ply to help with the load ?
Old Oct 17, 2012, 05:18 AM
Guizzo 17 is offline
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
I think you are right; as a minimum I would glue plywood rings to the rib, where the rods pass through.
Guizzo 17 is offline Find More Posts by Guizzo 17
Old Oct 17, 2012, 10:00 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
I really think that would be wise Guizzo, as you have now fitted very stiff joiners there is much more liklihood of a failure occuring elsewhere, like the ribs.
Old Oct 17, 2012, 02:02 PM
albyone is offline
Albyone
albyone's Avatar
Joined May 2006
from the "gull" I put a rib of plywood glued to the balsa. Can I do the same thing on the wings.
Ciao
Albyone
Old Oct 17, 2012, 02:04 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Sounds like a good idea Albyone.
Old Oct 17, 2012, 03:51 PM
ColinNZ is offline
ColinNZ's Avatar
Joined Aug 2004
Ciao
Albyone
Yes thats how I do mine. I use 1/32 ply
Old Oct 18, 2012, 04:01 PM
albyone is offline
Albyone
albyone's Avatar
Joined May 2006
New progress.
The front is almost ready
I can begin to cover the wings
Ciao
Albyone
Build Log yet another scratchbuilt twin boom pusher xatled99 FPV Talk 54 Aug 18, 2012 11:41 AM
Discussion First Scratch-Build: Twin Boom roo_ster Foamies (Scratchbuilt) 5 Apr 20, 2012 11:27 AM
Discussion 100" Pusher Glider with Twin Booms A-tail rclab1 The Builders Workshop 4 Mar 06, 2012 05:43 PM
