Old Jul 14, 2012, 01:01 PM
Electronick is offline
Find More Posts by Electronick
did it flied?
Electronick's Avatar
London, UK
Joined Apr 2005
Idea
Dual Thrust IR Micro Boeing 747
Howdy
I just love the Boeing 747, it's such a good looking airliner. So I made this 4mm motor IR dual thrust version. It's made from 2mm wallfoam and printed tissue.
AUW is 5.2 grams. I created the plans on photoshop, if you wish, you can of course use them and edit them to create your own Jumbo Jet. The idea is to build a relatively aesthetically pleasing foam model that can be built into a glider or RC.
The best glue for small models like this is UHU por. I first print on the A4 sized tissue then iron it to the foam. After cutting out the pieces, roll curves into the fuse on a table edge or a pen. There is a technique to this so practice makes perfect. You can use depron too! The pics were taken on my phone.
Strictly indoor flying only, the infra-red signal does not do well outside, water can smudge the ink and even 2mph wind can flop it over. No video yet.
If you have a question, let me know
Electronick is offline Find More Posts by Electronick
Old Jul 14, 2012, 01:33 PM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Simply AMAZING Electronic! Smallest airliner I've ever seen
Very cool!
demondriver is online now Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Jul 14, 2012, 01:50 PM
depronair is offline
Find More Posts by depronair
Sittin' on my hands
depronair's Avatar
United States, WA, Seattle
Joined Jan 2005
That is so neat. Please post a video when you can.
depronair is offline Find More Posts by depronair
Old Jul 14, 2012, 03:23 PM
did it flied?
London, UK
Joined Apr 2005
The Boeing 737 I made a while back uses the same components, the flying manners should be similar. What I'm really looking forward too is picking up the gondola from the Plantraco Nano blimp, it has three motors but one only needs to chop the 3rd up/down motor off and use the two vectoring motors for control. That means fully proportional lightweight control at 100 metre range, suited for outdoors too. Unfortunately they are out of stock at the moment. The dual thrust IR components I use now are extremely poor in range and outdated but have some potential.
Indoor flying Potters Bar (2 min 17 sec)
Old Jul 14, 2012, 03:27 PM
did it flied?
London, UK
Joined Apr 2005
Very cool!
Thanks! They can be enlarged for a more floaty experience though, I find the best size is about 45-55 cm WS for authentic flight patterns w/2mm wallfoam.
Old Jul 14, 2012, 03:38 PM
did it flied?
London, UK
Joined Apr 2005
The larger size 737 w/ starscream radio control components is the better size choice though for scale speed, great for outdoor flying and weight becomes less of a worry. The smaller models tend to be more difficult to trim.
RC Boeing 737 Air France (5 min 22 sec)
Old Jul 14, 2012, 04:38 PM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Holy crap!!!!!!!!, WOW...i thought about this concept but never did anything with it, but its for sure is well worth doing it!....now since there r no flight control surfaces, how do you control pitch of the flying model, i can see how you do the turns but .......
Concordefan is offline Find More Posts by Concordefan
Old Jul 14, 2012, 07:10 PM
Up-Out-&-Gone
Joined Mar 2007
I love the 737!
Old Jul 17, 2012, 09:12 AM
Frank Rys is offline
Find More Posts by Frank Rys
Frank Rys's Avatar
Monson,MA
Joined Mar 2000
what exactly is the wallfoam you use?....where can one get it? thanks
Frank Rys is offline Find More Posts by Frank Rys
Old Jul 17, 2012, 02:53 PM
did it flied?
London, UK
Joined Apr 2005
Wallfoam is a 2mm thick polystyrene foam material used for home insulation in the UK. It is sold under the brand name 'Warmaline Decolite'. I have not found in any stores lately, I think the company has stopped manufacturing it. I only have a few pieces left, enough to build a dozen or so more airliners.
But, you can prepare it yourself with a few tools and hardware. At the factory they cast the EPS foam into large drum-like cylinders and then shave off sheets with a sharp blade, not a hot wire, creating a long roll of thin sliced foam. It is very lightweight.
You can also use 1mm depron to build if 2mm EPS foam is not a viable option
Old Jul 17, 2012, 02:57 PM
did it flied?
London, UK
Joined Apr 2005
Full throttle causes the plane to pitch up and gain altitude, half throttle and it flies level while zero throttle will allow a controlled decent since the turning still functions without the throttle.
Old Jul 17, 2012, 03:07 PM
did it flied?
London, UK
Joined Apr 2005
I love the 737!
Me too. Sometimes when I finish building a plane I put it next to my bed for a few days so when I wake up in the morning the first thing I see is my love. This one time a had a whole mini Heathrow airport going on in my bedroom.
Old Jul 17, 2012, 04:26 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Lol Can i come see you maiden this thing? ??
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 18, 2012, 09:27 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
http://www.youtube.com/watch?v=LR7MvWTeF0I&feature=plcp
Nice! Whats the wingspan on the bigger version?
electricrc68 is offline Find More Posts by electricrc68
Old Jul 19, 2012, 05:33 PM
msurguy is offline
Find More Posts by msurguy
Max
Joined Jul 2006
Different IR system
Hey Electronick, have you considered replacing your IR system with Koichi Tanaka's Two motor proportional IR ?
Check out one of my old posts, http://www.rcgroups.com/forums/showthread.php?t=622328
That plane has a small two motor IR system and I was able to fly outside at a park with it, I'm sure it would improve your range.
Are you interested in something like that? I can provide you with details on how to build one or how to order one from Koichi or from me.
msurguy is offline Find More Posts by msurguy
Gallery Ultra micro 5g Boeing 747 mrexcel Scratchbuilt Indoor and Micro Models 17 Oct 02, 2013 03:50 PM
Discussion 3D model of Boeing's new 747-8 "Intercontinental" Mike James CAD/CAM 7 Sep 01, 2012 06:17 PM
Discussion Boeing 747 F-86FLIER4LIFE RC Airliners (Commercial, Cargo, Troop Carrier) 91 Aug 26, 2012 07:28 PM
Discussion The Boeing 747 F-86FLIER4LIFE Scratchbuilt EDFs 70 Aug 26, 2012 01:04 PM
WTB--HobbyFlite Boeing 747 and micro plane aerodragon Aircraft - Electric - Airplanes (FS/W) 1 May 27, 2002 02:01 AM
