Old Nov 22, 2012, 10:25 AM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Tested it again with the whole thing! I'm not sure if i just over reacting but its hot, but bearable when i put my fingers on it. I dont have a temp gauge so i cant really tell. All i can tell is it's not beyond boiling point.
DYORD is offline Find More Posts by DYORD
Old Nov 22, 2012, 07:23 PM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
On my tricopter- the front two motors get to around 27 degrees celcius (80.6 F) and the back gets to around 42 degrees celcius (107 F), which is hot to touch. I don't know if I should prop down, but the main problem I think is that my yaw gains are not perfect yet, and the rear motor is compensating a lot more frequently than the front two.
Lpbug is offline Find More Posts by Lpbug
Old Nov 22, 2012, 10:09 PM
DYORD is offline
Joined Apr 2012
i assume this is a CG problem.
Old Nov 24, 2012, 05:12 PM
vartaz is offline
Find More Posts by vartaz
Denmark, Central Denmark Region, Karup
Joined Aug 2012
I have the motors 1200kw 2628 ntm, on 2 quads, they have alot of power specially on 4s, and dont get wery hot. Used 10x4,7 props and had alot of thrust, no prob lifting 1,8kg quad. But something bad happened today- my quad with camera after many flights suddently lost power on one engine and fell from the sky. broke an arm and several frame parts. I felt the motors, one of them was burning hot. i waited till it cooled down, and it flew ok again, but after 2 mins of flight it again fell from the sky and now one motor is burning hot after 2mins flight and not spinning as it should = Burned wiring in motor, will replace it have another in stock. But other then this failing motor they perform very nice.
vartaz is offline Find More Posts by vartaz
Old Nov 24, 2012, 08:36 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
that drop out of the sky thing happened to me once. was a bad motor. could be an ESC though too.
sirbow2 is offline Find More Posts by sirbow2
Old Nov 25, 2012, 09:00 AM
vartaz is offline
Joined Aug 2012
I tried flying it today and it went fine for about 3 min and then suddently the same happened it was hovering over grass. And after that one motor wouldent spin proberly just runs slow and its burning. That motor has failed.the escs seem to doing fne. Its plush 30 a esc.
Old Dec 20, 2012, 02:34 PM
vartaz is offline
Joined Aug 2012
Today one motor smoked out on me, after many flights. I think i found out what i did wrong. But if flew awesome. I was using 10x4.5 on 4s on these motors, and i think that is too much. Now im exchanging the motor and trying 9x4.5 instead, i didnt do the bench test but i proberly should do it and see the amps
Old Feb 08, 2015, 12:22 PM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
qav400, 4s, 20 flights and bearings failed on 1 motor. new bearings from boca are $17
yosemitez is offline Find More Posts by yosemitez
Old Feb 13, 2015, 06:48 PM
yosemitez's Avatar
United States, CA
Joined Nov 2010
qav400, 4s, 20 flights and bearings failed on 1 motor. i repacked the bearings and they sound good now
25 flights and circlip fell off one motor, good thing that is part of my preflight check, other wise they are nice motors
For Sale 4 -New NTM Prop Drive Series 28-26A 1200kv Chad2323 Aircraft - Electric - Multirotor (FS/W) 1 Nov 29, 2012 11:12 AM
Help! NTM Prop drive 750kv motor THRUST data! Urgently needed! vineet_p Power Systems 2 May 31, 2012 10:39 AM
Discussion Prop adapter for NTM Prop Drive Series 4248 650kv justin144 Electric Motor Design and Construction 6 May 13, 2012 09:41 PM
Sold NTM Prop Drive Series 35-36A 1400Kv +60 Amp ESC and props and extras nige838 Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2012 10:05 PM
For Sale NTM Prop Drive 35-36A 1800 Motor NIP rcwarrior Aircraft - Electric - Power Systems (FS/W) 3 Apr 09, 2012 10:53 PM
