Old Nov 19, 2012, 03:45 AM
ketiljo is offline
Find More Posts by ketiljo
Joined Aug 2012
Originally Posted by deno6031 View Post
PS: don not use simonk firmware with ntm 2826-1200kv motors, there are a lot of threads of this problem.i had alot of crashes until i found out that the problem was the simonk firmware timing issue.Use the wii-esc code, believe me, i am on your side
The timing issue with NTM motors should be fixed in the lastest SimonK firmware.
ketiljo is offline Find More Posts by ketiljo
Old Nov 19, 2012, 04:40 AM
Pauluk1 is offline
Find More Posts by Pauluk1
I never crash,my copter does
Pauluk1's Avatar
United Kingdom, Wales, Cardiff
Joined May 2012
Originally Posted by vineet_p View Post
A quick question: NTM 2826 1200kv + 9047 props + F-20A (20A ESCs) (on a 4s)
Is this a good setup? Will the draw be less than 20A or do you suggest me to go for 30A?
Thanks!
Im flying the same motor on 4s 8045 props, 30A esc,runs really great,will try 9047 props when i get a chance to hopefully extend the flying time.
I can confirm these work great with the latest simonk firmware.
Pauluk1 is offline Find More Posts by Pauluk1
Old Nov 19, 2012, 06:31 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
anyone else? but after 2sec, that seems like a ESC/motor issue. is this only one motor, or all of them? are the ESC/ESCs hot?
sirbow2 is offline Find More Posts by sirbow2
Old Nov 19, 2012, 07:12 AM
DYORD is online now
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Escs are not hot! But all the motors do. Would it help if i put bigger prop? Like 11"? Would that extend battery life too?
DYORD is online now Find More Posts by DYORD
Old Nov 19, 2012, 08:21 AM
DYORD is online now
Joined Apr 2012
Btw, i replaced all the shafts because it was installed backwards...making the props higher than usual. I never knew about the prop adapter that i should have bought along with the motor. I'm using a collet type prop adapter.
Will that make the difference?
Old Nov 19, 2012, 08:22 AM
DYORD is online now
Joined Apr 2012
How much is your total weight? And what's your setup? A hexa or quad?
Old Nov 19, 2012, 11:29 AM
sirbow2 is offline
Emress
Joined Nov 2011
take off the gimble. see if it is any better. did you ever fly without the gimble and was it better then?
Old Nov 19, 2012, 11:58 AM
Pauluk1 is offline
Pauluk1's Avatar
Joined May 2012
Its a quad with a dji 330 frame,total weight is around 1.1 kg,thats with a sony bloggie camera,landing gear,5000 mah 4s battery.
Flight time = 15 mins.
Old Nov 19, 2012, 12:30 PM
sirbow2 is offline
Emress
Joined Nov 2011
dyord, are you on 4s ? maybe 9in props are too big? try some 8in.
Old Nov 19, 2012, 01:45 PM
furex is offline
Find More Posts by furex
France
Joined Oct 2006
i got 4 of this on f450.
with 9X4.5 and 3S, They are powerful but make too vibration for onboard camera.
Ball bearings are very low quality .
in all case, that's great motor for accro quad.
furex is offline Find More Posts by furex
Old Nov 19, 2012, 06:13 PM
DYORD is online now
Joined Apr 2012
No i still use 3s battery. Is there a big difference in using 9x4.5 and 10x4.5?
Old Nov 19, 2012, 06:24 PM
sirbow2 is offline
Emress
Joined Nov 2011
geez dude take off a kg and see if its better. yes could be.
Old Nov 19, 2012, 07:55 PM
DYORD is online now
Joined Apr 2012
Thanks! will try that this afternoon!
Old Nov 20, 2012, 07:53 AM
DYORD is online now
Joined Apr 2012
Did a test today without the gopro, gimbal, landing gear, accesories. Flew it in 2mins and the motors are quite warm. Flying weight is 1.7Kg. Will test again with everything in two mins to see if it's still hot. I just weigh the extra payload and it is just around 700grams making it 2.4kg in total. Is that bad? If i do the math, the load is only 400 grams per motor.
Old Nov 20, 2012, 04:28 PM
sirbow2 is offline
Emress
Joined Nov 2011
if theyre still nearly as warm as before, id say its not a weight issue,
For Sale 4 -New NTM Prop Drive Series 28-26A 1200kv Chad2323 Aircraft - Electric - Multirotor (FS/W) 1 Nov 29, 2012 11:12 AM
Help! NTM Prop drive 750kv motor THRUST data! Urgently needed! vineet_p Power Systems 2 May 31, 2012 10:39 AM
Discussion Prop adapter for NTM Prop Drive Series 4248 650kv justin144 Electric Motor Design and Construction 6 May 13, 2012 09:41 PM
Sold NTM Prop Drive Series 35-36A 1400Kv +60 Amp ESC and props and extras nige838 Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2012 10:05 PM
For Sale NTM Prop Drive 35-36A 1800 Motor NIP rcwarrior Aircraft - Electric - Power Systems (FS/W) 3 Apr 09, 2012 10:53 PM
