Old Aug 29, 2012, 08:50 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
And I'm using F-30As, not yet received them. I'll flash them with simonK f/w.
Thanks TS00.
Vineet
vineet_p is offline Find More Posts by vineet_p
Old Aug 29, 2012, 08:51 AM
TS00 is offline
Find More Posts by TS00
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
They should work very well.
We want video!
TS00 is offline Find More Posts by TS00
Old Aug 29, 2012, 08:58 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Thanks TS00. I can't wait to start building it, but HK.....!
Old Aug 31, 2012, 01:24 AM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
You want these for 4S:
http://www.hobbyking.com/hobbyking/s...50kv_140w.html
And 30amp ESCs are a tad big. I get away with 12amp plush using 4S no probs.
Stunt Double is offline Find More Posts by Stunt Double
Old Aug 31, 2012, 05:30 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
But if I use 750kvs, I'll need larger props spinning at low rpm = slow and sluggish quad = no fun.
Old Sep 04, 2012, 03:46 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
A quick question: NTM 2826 1200kv + 9047 props + F-20A (20A ESCs) (on a 4s)
Is this a good setup? Will the draw be less than 20A or do you suggest me to go for 30A?
Thanks!
Old Sep 04, 2012, 03:47 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
That's a fast motor, a big prop, and a little ESC
Should be fine with 8045, or with a 1000kv motor, or with a 30A ESC.
Edit: I just noticed the 4S - I think that quad will be devilishly hard to fly.
Old Sep 04, 2012, 04:03 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Thanks for the reply.
I will then buy the F-30As. (they're on backorder and it seems HK is not interested in restokcing).
I'll first learn to fly with a 3s, then upgrade to 4s.
Old Sep 04, 2012, 04:08 AM
TS00 is offline
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Turnigy Plush 30A or Skywalkers would also work pretty well. These 40A monsters are very well priced:
http://www.ebay.co.uk/itm/4-x-Hobbyw...item4d01772043
Old Oct 06, 2012, 05:12 AM
srepfler is offline
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
NTM 1200 on 3s with 10x4.5
Just for reference NTM motors 10x4.5 3s 30A BlueSeries no SimonK.
AUW around 1.6 kg with 2x 2200 3s, tested with 2x 2200 3s + GoPro
X666 + KK2 having fun on windy day (11 min 35 sec)
Like this motors.
srepfler is offline Find More Posts by srepfler
Old Oct 06, 2012, 06:54 AM
deno6031 is offline
Find More Posts by deno6031
deno6031's Avatar
Turkey, Izmir
Joined Oct 2011
I ordered NTM 2826 1200kv and 9047 props. Will use a 4s LiPo, AUW will be around 1200-1300g.
Will post results. Thank you all!
that setup will be a rocket my fpv quad's AUW is 1250grams, and i use the same motors on 3s lipo with 8x4.5 carbonfiber props, and it hovers at %40 throttle easily. even on my setup 4s makes my quad much more powerful
you are going to have a great time with it
PS: don not use simonk firmware with ntm 2826-1200kv motors, there are a lot of threads of this problem.i had alot of crashes until i found out that the problem was the simonk firmware timing issue.Use the wii-esc code, believe me, i am on your side
deno6031 is offline Find More Posts by deno6031
Old Oct 06, 2012, 07:54 AM
EddieWeeks is online now
Find More Posts by EddieWeeks
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
If you run 4S..... a really good motor is this.. 3020-600kv.... $20...
http://www.hobbypartz.com/86mb96-3020-600kv.html
It spins a APC 12x3.8 on my tri with 11000 mah... my friend has the 950 version.... does not
work as well and can only use 10" props
I have tried all kind of different motors and props.... 600kv on 4S and 12" props is in the sweet spot.
my tri can fly for 20 min or lift 2.5 lbs and fly around...
Don't try to guess on motors props and KV.... use what works for someone else... there are too many combos
Tri-Copter Bucket Race.... APM2 2.7.1 (0 min 15 sec)
EddieWeeks is online now Find More Posts by EddieWeeks
Old Nov 18, 2012, 10:45 PM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Hi! Im using the ntm prop drive 2826 1000kv motor on my hexa (clone f550). Auw is 2.6 kg. including the battery, gopro+gimbal, landing gear. The motor runs hot after 4mins flight. Is this normal? I've used 10x4.5 and 9x6 props and get same results. Is my setup too heavy for this motor?
DYORD is offline Find More Posts by DYORD
Old Nov 18, 2012, 11:04 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
hah i see you wrote there too
so someone says that 10x4.7 gives 930g thrust @ ~15A so thats plenty under the 21A max. 930 x 6 = 5580g max thrust and half that is 2790g (max weight of the multi for good stability) and you are under that, so id think it would be fine.
could you take something heavy off (gimble?) and see if it is any cooler (to rule out weight, or not)?
is it really hot out? do motors sound bad ( add a little oil to lub them maybe), is the heat progressively growing, or immediate?
sirbow2 is offline Find More Posts by sirbow2
Old Nov 19, 2012, 12:31 AM
DYORD is offline
Joined Apr 2012
Actually, it will get heavier once i get my 4500mah pack. I haven't tried to do the 2min test, but i'm just worrying if im pushing the motor to its limit. I dont have a temp gauge so i cant tell how hot is hot. Im thinking around 60 celsius?
I'll try to put it into more diet. Maybe i'm still missing something.
What do you mean progressively growing? Actually it becomes hot after 2 secs right after flight
For Sale 4 -New NTM Prop Drive Series 28-26A 1200kv Chad2323 Aircraft - Electric - Multirotor (FS/W) 1 Nov 29, 2012 11:12 AM
Help! NTM Prop drive 750kv motor THRUST data! Urgently needed! vineet_p Power Systems 2 May 31, 2012 10:39 AM
Discussion Prop adapter for NTM Prop Drive Series 4248 650kv justin144 Electric Motor Design and Construction 6 May 13, 2012 09:41 PM
Sold NTM Prop Drive Series 35-36A 1400Kv +60 Amp ESC and props and extras nige838 Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2012 10:05 PM
For Sale NTM Prop Drive 35-36A 1800 Motor NIP rcwarrior Aircraft - Electric - Power Systems (FS/W) 3 Apr 09, 2012 10:53 PM
