Jul 14, 2012, 05:36 PM
Australia, QLD
Joined Apr 2012
Thanks guys, wasp does sound cool, i only have black and yellow paint on hand so i just put some stripes on it for shits and giggles, i might try and make it look better.
With the stab areas is there a desired size they should be, now i look at it the vertical stab, it looks small, it would have been alright if the fuse didnt wrap around it, and with horizontal stab, the bottom of it is a lot larger than what appears on top, does that make a difference? The control surfaces are exactly the same size as my first scratchbuild which flew as a 3 channel and it flew so good - i should have learned on it, but this ones wingspan is 50mm longer and the chord is 20mm longer, the elevator is 35mm by 220mm, the rudder is 35mm by 80mm and the wingspan is 900mm by 160mm,
Cheers, Mick.
