| Thread Tools |
| This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies. |
Brushless 1S Champ (micro)
Just finished my BL micro champ. Always wanted to try this!
I used an AR05 BL 3700Kv motor and 5A Turnigy ESC from HK. Brick (RX) is an AR6400L multi channel rx. Tested it out and mounted a 3-blade 110x80 prop using graphite-epoxy after reaming carefully the prop hole in the hub. THe AR05 has a 1.5mm shaft size, JUST larger than the hub hole. There was a touch of play, but enough to glue the prop on. Just before curing (~6-7 min until pretty much solid), around the 5 min mark, I adjusted the track and then ran the motor slowly enough to let it self-center and rotate in a plane, and self-balances. Let sit for another minute, and repeat. Care was taken to avoid over rotating the prop and having it fly off the shaft! ![]() Motor was mounted using 1/32" thin ply in 2 layers (1/16" total). Holes drilled to match motor and shaft rear. I then used 2mm cap screw hardware to affix to the wood. Total weight was just under 2g above the stock brushed motor and mount system. Not bad! I then hard wired the whole assembly and put in the plane. The ESC was positioned aft of the RX to help balance a bit better. Also, the motor is connected using a spare 2S balance lead plug to ease motor replacement if necessary. Running is close to the brushed for draw: 1.66Ap. Run time in the 9 minute range at mid-throttle (0.6A), with nominal draw around 2.5W, about 6W peak. The 3A nominal, 5Ap Turnigy ESC runs this VERY well. I could never get the el-cheapo generic ESCs to run with this. While the ESC DOES have a BEC, I left mine in N/C mode, with only the throttle channel going to the ESC, and run the RX/ESC in parallel. Very effective. Flight is fine - a bit less zippy than the stock setup due to weight: 52g AUW. About 6-7g over stock. I added some Dubro 123 (1.23") sport main wheels, and a DUB12MTW (tail wheel to replace the stock foamy crap. Rolls on grass very nicely. Throws are VERY aggressive, with about a 1.8" variance between max/min on both axes. Tight loops and turns (3rd hole on horns from top). Still playing with trim, but this so far flies VERY close to straight with almost no extra trim req'd. Pics below ---- Unit sounds louder than brushed due to resonance in the plane's body. See video on next entry! Darren/SkyCadet
Thanks!
Yeah, I was pretty happy with the conversion. It flies pretty well, just a tad heavier than stock. What I like is that the motor is NOT brushed, and no gearbox is needed. Less mechanicals equal simpler operating and more consistent flight and performance. SC |
Latest blog entry: Some notes on the ORX 3AS V2 and DX6i...
| Thread Tools | |
| For Sale E flight micro chargers (striker and any 1s micro) | Racerx4 | Aircraft - Electric - Micro & Indoor Airplanes | 0 | Mar 11, 2012 11:26 AM |
| Data Gearbox with brushless micro-motor to achieve maximum thrust with powered only by 1S. | Vladimir88 | Indoor and Micro Models | 252 | Feb 13, 2012 02:26 AM |
| Discussion Maximum thrust micro- brushless motors with powered only by 1S. | Vladimir88 | Indoor and Micro Models | 37 | Dec 31, 2011 11:47 AM |
| Sold Mirco plane/Micro Heli brushless motors/esc/1s parkzone battery extensions/batteries | indoorheli | Aircraft - Electric - Micro & Indoor Airplanes | 6 | Feb 06, 2010 05:57 PM |
