I recently purchased a Savage X SS kit that I converted to electric as it was being built. Boy, was that a pain to do all at once. Once the dust settled, and I had a beautiful electric powered almost Savage Flux, there were a ton of parts left over that I will never use. So, up for sale they go.
None of these parts have ever been used. Many of them are still in the sealed bags they came in. As much as possible, I broke everything up into lots based on what the part number would come with if you bought the part on its own. Wherever possible, I will include the fasteners that would come with the parts if bought on their own. This will not be the case every time, but if I have them, I will include the fasteners.
Some of the items were photographed together but are separate items. Only the items described on the line above the picture will be included for that sale. The other items in the picture will be listed elsewhere.
This post is quite long with all the pictures, but if you are looking for parts for a Savage X SS, it is worth a look.
3192 HPI Racing Warlock Wheel Chrome 83x56mm Savage X $ 19.00 for two sets or $10.00 per set
15201 HPI Racing Nitro Star K4.6 Engine w/Pull Start $ 150.00
Includes 86076 HPI Racing Pilot Nut 1/4-28x8.5mm Black Savage
72130 HPI Racing Stainless Slipper Disk $ 2.00 bag 11
72131 HPI Racing Slipper Clutch Pad $ 3.25 bag 11 – for two pads
See the picture under 72130 for this item
73961 HPI Racing Chassis 2.5mm Savage X Gray/Left $ 21.00
73962 HPI Racing Chassis 2.5mm Savage X Gray/Right $ 21.00
76914 HPI Racing Transmission Gear 44T Savage $ 3.50
If someone buys one of the pieces that make up this gear, I will separate the pieces
If someone buys both pieces, it will be shipped as a unit
76924 HPI Racing Transmission Gear 39T Savage X $ 3.25
Includes 94086 2x5mm Screws – 3 pieces
77107 HPI Racing Racing Clutch Bell 17T $ 11.40
85235 HPI Racing Gear Box/Bulkhead Set Savage X $ 21.00 for two sets or $12.00 each
86031 HPI Racing Bevel Gear 13 Tooth Savage $ 18.00 for two sets or $10.00 each
86060 HPI Racing Engine Mount Savage 21 $ 10.00
Includes
Z725 HPI Racing Set Screw M4x10mm
Z544 HPI Racing Cap Head Screw M3x12mm x4
Z792 HPI Racing Cap Head Screw M4x8mm Savage x4
86061 HPI Racing Exhaust Header Rear Exhaust Savage $ 13.00
Includes 1 each:
87049 – gasket
87054 – spring
86065 HPI Racing Axle 8x9x44mm Black Savage 21 (2) $ 20.00 for two sets or $11.00 each
No nuts
86069 HPI Racing Engine Plate 2mm Purple Savage $ 10.00
4 - 3x8MM screws – have?
86079 HPI Racing Engine Mount Savage X $ 11.00
86087 HPI Racing Clutch Gear Holder w/One-Way Silver Savage $ 16.00
Includes Z235 C clip and Z897 washer
86088 HPI Racing Idler Shaft 6x8x45mm Black Savage $ 5.50
Includes pins, no E-clips
If someone buys one of the two pieces that make up this shaft, I will separate the pieces
86092 HPI Racing Brake Cam/Piston Set Savage $ 3.25
86130 HPI Racing Slipper Clutch Hub Savage $ 2.75
86133 HPI Racing Brake Disc Stainless Steel Saxage X (2) $ 4.75
86134 HPI Racing Heavy Duty Dogbone 9x123mm Savage $ 25.00 for two sets or $13.00 each
Includes 6811 HPI Racing O-Ring 6x9.5x2mm Black Savage 21
86138 HPI Racing Polished Aluminum Tuned Pipe Savage $ 30.00
One Polished Aluminum tuned pipe.
Mounting equipment (including one 86173a mounting spring, and one 86173a bracket.)
Hardware:
Z721 HPI Racing Set Screw M3x4mm Proceed
Z741 HPI Racing Set Screw M5x5mm
Z517 HPI Racing Binder Head Screw M3x8mm
Z903 3/32 hex wrench
86145 HPI Racing Flange Pipe 3x6x10mm Savage X $ 1.25
They are in the bag in the picture
86171 HPI Racing Metal Spacer Set 5x7.5x3mm Savage X SS $ 2.00
86271 HPI Racing Flywheel 3 Pin Savage $ 7.00
Does not include brass collar
86356 HPI Racing Brake Linkage Set $ 5.50
One throttle return spring
One throttle linkage rod
One brake linkage rod (long) to servo
One carburetor linkage rod
One brake linkage rod (short) to brake cam
Includes the following plastic pieces that go with the brake linkage set:
85050 – parts 3, 11, 12 (two of each piece)
85058 – parts 4, 7, 14, 18, 19
86368 HPI Racing Clutch Holder Black Savage X $ 8.25
Includes 86094 HPI Racing Screw Shaft M4x2x12mm Black
86369 HPI Racing Clutch Hub Heavy Duty 2-Speed Savage X $ 3.25
No screws
86803 HPI Racing Joint Post 4x6x74mm Savage X (2) $ 5.50
86806 HPI Racing Steel Spur Gear Set 47T - assembled $ 38.00
47 Tooth Steel Spur Gear
Spur Gear Hub
86826 HPI Racing Alloy Diff Set/Case Assembled Savage X SS $ 65.00 for two sets or $35.00 each
87040 HPI Racing Silicone Exhaust Coupling 12x18x30mm Purple Savage $ 3.50
Includes two zip ties
87149 HPI Racing Fuel Tank 160cc Savage $ 11.25
Includes frame mounting pieces
Includes 6899 O-Ring 5x8x1.5mm Savage x4 if I have them
87151 HPI Racing Teflon Clutch Shoe/Spring Set Savage $ 7.50
Includes three clutch shoes
Includes three clutch springs
87154 HPI Racing Brake Plate/Pad Set Savage $ 4.75
Three aluminum brake plates
Two composite paper pads
87199 HPI Racing Air Cleaner Sleeve Set Nitro Star K4.6 $ 4.50
| May include Z543 M3x10 x1 if I can find it
| May include Z224 M3x8 washer x2 if I can find them
| 6154 zip tie x2
| rubber coupler
same bag filter base
| center section
| top section
87204 HPI Racing Air Cleaner Foam Element Set Nitro Star K4.6 $ 5.00
If these items are bought by two people, I will need to open the bag to separate the parts
Included with 87199
B021 HPI Racing Ball Bearing 5x10mm Proceed (2) $ 11.00
I have the following available even though I did not manage to take pictures of them.
B085 HPI Racing Bearing 8x16x5mm Savage $ 2.00
I also have the following available, and if you pay for shipping (one stamp probably) they are yours:
Z203 HPI Racing Washer M3x6 x2
Z515 HPI Racing Button Head M 3x5 2-Speed x2
Z570 TP Binder Head Screw M3x18mm x2
Z695 HPI Racing 2-Speed Washer 4x6x.3mm x3
Condition – all parts are New
I have successfully sold many things on Helifreak, RunRyer, RC Groups, and many more on photography forums and on eBay. My user name on eBay is Metalhead1986 if you want to check me out.
Money orders or PayPal will be accepted, and the above price includes PayPal fees.
Shipping is not included in the above prices. Priority Mail or Parcel Post with Delivery Confirmation is my usual method of shipping, but I can ship with any of the major carriers. Please PM or e-mail with your ZIP Code for a quote. Insurance is optional and always the responsibility of the purchaser, even if we make a deal that includes shipping. The Post Office charges so much for insurance that it would kill me to pay for insurance on a bunch of small packages.
Multiple parts purchased by the same person will be combined into one package to save on shipping.
Steve
