Old Jul 13, 2012, 03:50 PM
New_Flyer95 is offline
Find More Posts by New_Flyer95
Joined Jul 2012
Flying an RC plane with TWO fpv cameras running at the same time
Hello, I am new to fpv systems and I was wondering if it was possible to hook up two fpv cameras and run them at the same time. My plan is to run both and record the video playback in 3d to view. I was also wondering if it was possible to run both cameras in one fpv goggle set; for example, hook up the left camera playback in the left goggle eye and hook up the right camera playback to the right goggle eye. Would I need to worry about getting two different types of frequencies for each fpv camera set, or would it even be possible to use two fpv cameras linked to one transmitter and receiver?
New_Flyer95 is offline Find More Posts by New_Flyer95
Old Jul 13, 2012, 05:12 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Lemme stop you right there. If you're new you should just try regular FPV
before even considering doing something like you go on to talk about.
To answer your question, yes, its possible. Unfortunately it's worthless since 3D
becomes negligible at long distances. So if you're cruising around at 400 feet
looking at the ground the difference between 3D and regular will be negligible.
It could be useful in a multicopter but 99% fly them just fine without it.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Jan 06, 2016, 09:45 AM
BigBadBry is offline
Find More Posts by BigBadBry
United States, AZ, Chandler
Joined Jan 2015
3d is pretty slick for close prox flying, like Blue said. There are actually dual cameras already on the market (search out the skyzones) and Fatsharks upper-end offerings happily playback 3D feeds , even over HDMI.
http://www.getfpv.com/skyzone-3d-fpv-goggles-w-3d-camera-dual-transmitter-dual-receivers.html
BigBadBry is offline Find More Posts by BigBadBry
Old Jan 08, 2016, 08:24 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Skyzone
Nerdcam3d
Blackbird 3dcam
Everything already available on the market for long time... But not quite popular as regular FPV.
schumixmd is offline Find More Posts by schumixmd
Poll Anyone flying two or more dragon links at the same time ? ecampos FPV Talk 23 Nov 01, 2011 09:36 AM
Discussion Flying with two RC planes at the same time - the hard way Kami64 Electric Plane Talk 15 Sep 25, 2011 04:58 PM
Can you fly two RC planes at the same time? ghoti Electric Plane Talk 28 Feb 09, 2011 02:08 PM
Whoops! I can't get two ESCs running at the same time on a twin... Mike_Then Power Systems 8 Nov 18, 2009 08:49 AM
can I run two battery packs on one plane, at the same time? e-sailpilot86 Power Systems 8 Mar 08, 2008 07:36 PM
