Old Jul 13, 2012, 01:00 PM
hjjkrishnan is offline
Find More Posts by hjjkrishnan
Joined Jul 2012
Best battery, ESC, motor, prop combination for my quadcopter..
Pardon me for my newbie questions, as this is my first quad.
My quad in total will weigh about 1.5 kg. So will the following parts be adequate?
1.motors- hexTronik DT750 Brushless Outrunner 750kv
http://www.hobbyking.com/hobbyking/s...247&aff=655899
2.ESC's-hobbyking ss series 25-30 amp.
http://www.hobbyking.com/hobbyking/s...460&aff=655899
3.Props-Slow Fly Electric Prop 114.7SF RH Rotation (4 pc)
http://www.hobbyking.com/hobbyking/s...451&aff=655899
4.Battery-ZIPPY Flightmax 5000mAh 3S1P 30C
http://www.hobbyking.com/hobbyking/s...idProduct=8587
5.Frame, im planning to build my own with aluminium.
6.Controller-atmega328
7.IMU- IMU Digital Combo Board - 6 Degrees of Freedom ITG3200/ADXL345
http://www.sparkfun.com/products/10121
(Also, is there an alternative one just as good as this one, available in hobbyking?I'd like to buy all from a single site to save my shipping costs )
8. Radio -RX-tx Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)
http://www.hobbyking.com/hobbyking/s...042&aff=655899
( i thought i'd use this as, i've already planned on using Xbees for giving me flight data, I could use them to adjust the gains using that )
hjjkrishnan is offline Find More Posts by hjjkrishnan
Old Jul 13, 2012, 01:01 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
1.5kg is pretty heavy for a first quad... how are you building that thing?
Your links don't work btw.
acetech09 is offline Find More Posts by acetech09
Old Jul 13, 2012, 01:16 PM
Joined Jul 2012
Sorry about the links. I have edited them, please have a look.
And about the weight, I've planned on using aluminium and i wanted to add some extra protection for my propellers in case my quad crashes. So,1. frame = 500g.
2. battery = 408g
3.motor X4 = 312g
4. ESC X4 = 88g
5. other electronics = 50g
6. future add ons , like a camera.
So , in effect it comes to about 1358g.
Old Jul 13, 2012, 01:28 PM
acetech09's Avatar
Joined Apr 2012
I really don't know, honestly... I think that the only protection you'd need for your props is prop savers... as long as you buy extra props. That is a pretty heavy quad though. I'm a bit busy atm but can reply later about it.
Old Jul 13, 2012, 01:38 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
that battery is a bit big, try a 2200mah or bigger 3s. and you have the frame weight and wires etc so it could come out to 1.5kg+
you need both CW and CCW props:
http://www.hobbyking.com/hobbyking/s...dProduct=22451
http://www.hobbyking.com/hobbyking/s...dProduct=22450
getting a turnigy 9x and flashing it with er9x firmware later is for sure better than the HK TX
HK doesnt have any IMUs just FCs. that IMU is a RIP OFF! get this one: http://www.ebay.com/itm/MPU-6050-3-A...item2572b0b780
OR
the same one as you picked but cheaper: http://www.ebay.com/itm/Mini-Nine-ax...item2a1c0cdf69
are you writing your own code for the FC?
you could use some CF plate for the center plate of the quad:
http://www.hobbyking.com/hobbyking/s...dProduct=24964
http://www.hobbyking.com/hobbyking/s...idProduct=9782
http://www.hobbyking.com/hobbyking/s...idProduct=9781
the image attached shows how i made my DIY FC. D8 in that pic can be aux input 2. that image is for MWC, but would be a good layout for custom FC with custom firmware, too.
sirbow2 is offline Find More Posts by sirbow2
Old Jul 13, 2012, 02:01 PM
Joined Jul 2012
Sure. I would really appreciate that.
With 2200 mah won't the flight time be too low? I was hoping to get about 12-15 mins.
Apart from the extra channels and the display, to set the gains etc, is there any other thing that this RC has to offer? I actually was planning to set the gains via my xbee i use for telemetry.
Thanks for the heads up. Are you sure this one will work, firstly i've never bought electronics from ebay fearing they might be damaged. Also i am a lil' skeptical about using a new IMU on my quad. Has anyone used them before?
yep. That's the plan.
Thanks a lot for your replies
Old Jul 13, 2012, 02:24 PM
sirbow2 is offline
Emress
Joined Nov 2011
the looks you get from non-RC people from all the knobs it's just generally better. more features, models options etc, reliability.
yeah, tons of people buy these. ive gotten stuff like this before and it has been packaged pretty nice. if you're really worried, then go for a "top rated seller". the first link is.
time to do some calcs!
with 11x4.7 you get 1133g thrust which draws 17A per motor = 4532g thrust, and 68A max for all 4 motors. 1.5kg is 3.0213 (roughly a third, 4532 / 1500) of 4532g. so that means you need a third of the thrust to hover, therefor you need a third of the max amps which would be 22.503A to hover. then to find flight time we divide battery capacity in amp hour by amp draw of the quad and then times that by 60. so with a 5000mAh battery and a 1.5kg AUW: ((5Ah/22.502A) * 60) = 13.3 min hover. with a 2.2Ah you would get 5.86minutes hover.
you may just want to go with bigger motors fora 1.5kg quad...
Old Jul 13, 2012, 02:46 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
I have a similar build...link
i found for my 750kv.. the flight time stays the same as you increase/decrease the weight..(for my set up..) but hovering time will increase as you add mah
noted.. the flight time in this calc is 100% throttle.. you dont want to go 100% all the time.. so the combined flight time will be kind of in the middle of both
jy0933 is offline Find More Posts by jy0933
Old Jul 14, 2012, 04:13 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
Hey! You from India?
Vineet,
Hyderabad
vineet_p is offline Find More Posts by vineet_p
Old Jul 14, 2012, 05:01 AM
Joined Jul 2012
Something like a 900 or 1000kv ? The specs of this ones says it gives 1000g+ thrust...
And the problem with my battery is the weight right? What's my maximum mah, so that it stays light enough and still do the job?
I'm confused, you seem to have ESC's rated for 20A, but the battery's rated for 65/100 C .Won't a 30C or so be a better one? Please correct me if i'm wrong. Also, your quad does good with 750 KV motors and the 1200g ? If you don't mind, please post the specs of your quad.
Namastey saab! Yes, i'm from India, Trivandrum. That your quad in the pic? Looks awesome.
Old Jul 14, 2012, 08:24 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Namastey! Yep, that's my quad.... and it's on sale now.
You can contact me on vineet.p[at]hotmail.com
Vineet
Old Jul 14, 2012, 09:09 AM
Fugbucker is offline
Find More Posts by Fugbucker
Fugbucker's Avatar
Australia, VIC, Hampton Park
Joined Feb 2011
Forget the SS ESCs... Get the Plush ones... They are probably on backorder because everyone wants them..
Fugbucker is offline Find More Posts by Fugbucker
Old Jul 14, 2012, 10:42 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
normally .. 1.5~2x of needed will be good cuz higher C batteries have better voltage handling but a bit heavier
ESC i will suggest go for hk30A(F-30A). and flash them to this
literally you want esc also at leas 1.2~1.5x of you max current... just cooler and smoother
Old Jul 15, 2012, 07:49 AM
Joined Jul 2012
Hey, is there any parts that are available in India? My shopping list has all parts even connectors and heat shrink tubing from Hobbyking. Everything amounts to a lot of shipping money also.
Thankyou Fugbucker and jyo933...
I've changed my ESC to http://www.hobbyking.com/hobbyking/s...ontroller.html
Old Jul 15, 2012, 09:45 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
checkout:
www.rcbazaar.com (Bangalore, limited multirotor products)
www.rcbharat.com (Hyderabad, has got nice quad frames, FC, Txs, connectors, etc.)
thehobbyshop.in (Pune, stay away from this shop, the shipping times are horrible, bad packing and missing parts)
www.hobbysea.com (New Delhi) (Newly opened, so prices are insanely low!)
www.rcelectro.com (I think it's in Gurgaon, HR) (Has got a custom-built fiberglass quadframe)
www.rcdhamaka.com (Bangalore) (Has a quadcopter combo and a kk blackboard)
www.aeroworks.co.in (Chennai) (This guy sells Parrot AR drone 1 and 2, and also has some quad products)
Enjoy!
Vineet
Question Motor/Battery/ESC combination jpex62 Electric Power Cars 11 Jun 26, 2012 09:28 PM
Discussion Help me pick out motor, ESC, battery, and servos for my first scratchbuilt. MightyRed Foamies (Scratchbuilt) 4 Jun 19, 2012 09:42 PM
Discussion Best combination for my FVP setup fabianabegglen FPV Talk 11 May 02, 2012 06:06 AM
Help! Motor//esc//battery combination Rcexperimental Electric Plane Talk 5 Apr 18, 2012 08:10 PM
Discussion Best Prop/Gear/Motor/Battery Combinations Pete P. Scratchbuilt Indoor and Micro Models 6 May 24, 2004 07:35 PM
