Old Oct 18, 2012, 11:18 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
another great set of flight on this bird today in 10 mph winds gusting to 15, she is a blast in the wind. definitely my go to plane to test the conditions to fly. also added a few things pics to follow
kelloggair is offline Find More Posts by kelloggair
Old Oct 22, 2012, 03:25 PM
kelloggair's Avatar
Joined Mar 2008
anyone out there?
Old Nov 25, 2012, 11:12 PM
Lexx is offline
Find More Posts by Lexx
Certified Quad Crasher
Lexx's Avatar
Joined Aug 2012
Still flying this? How is it holding up?
Lexx is offline Find More Posts by Lexx
Old Nov 26, 2012, 12:00 AM
kelloggair's Avatar
Joined Mar 2008
yep, i love this wing it is my go to anytime flyer
Old Nov 26, 2012, 08:06 PM
Lexx is offline
Lexx's Avatar
Joined Aug 2012
That's good to know. I ordered a couple to give them a try. I just have to come up with the right motor/ prop combo.
Old Nov 27, 2012, 10:57 AM
kelloggair's Avatar
Joined Mar 2008
I don't know if you saw but I'm using the stock micro Stryker setup and it works great. Its nice and light with power to spare. I'm thinking of going to a 4040 prop and testing that out
Old Nov 27, 2012, 09:17 PM
Lexx is offline
Lexx's Avatar
Joined Aug 2012
Yeah, I saw that. I can't seem to find any micro stryker motors listed for sale. What do you think of these?
http://www.headsuprc.com/servlet/the...trunner/Detail
or
http://www.headsuprc.com/servlet/the...ushless/Detail
Old Nov 27, 2012, 09:55 PM
kelloggair's Avatar
Joined Mar 2008
i think i would use the second choice the first choice is 6 grams
Old Nov 27, 2012, 10:30 PM
Lexx is offline
Lexx's Avatar
Joined Aug 2012
I thought that at first too. It is actually .6 oz which = 17 grams.
How much does the micro stryker motor weigh?
Old Feb 26, 2013, 04:21 PM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
Still flying? I saw someone had set one of these up with the stryker gear with rudders (Looks really sweet)
Can these land like the stryker can? (IE elevator style and straight down with full ele?)
How bout some vids? Preferably as slow as she can fly.
bluemeane is offline Find More Posts by bluemeane
Old Feb 26, 2013, 05:20 PM
kelloggair's Avatar
Joined Mar 2008
not sure about an elevator landing but i can gaurentee she will go slow, far slower then the um stryker would if that gives any indication. im still flying mine and loveing it, she is my wind plane/ throw around anywhere plane. i will try to post a vid of slow flight here soon no promises though as winter has finally decided to hit us here in colorado. i have 2 vids posted back on page 3 not great but something.
Old Jul 31, 2014, 09:23 PM
LowBoTomy is offline
Find More Posts by LowBoTomy
LowBoTomy's Avatar
United Kingdom, England, Coventry
Joined Jan 2014
I got one!
It is quite expensive for such a tiny model but the foam is good quality EPP and the parts are accurately formed. Was 20 delivered.
Not much info in this little wing so i'll add some words and pics..
Here's my set-up for anyone interested...
Span: 400mm
AUW: 89.7g
Motor: T-Motor 1304 (6.5g, 3400KV, 30.1W, 130g Thrust @7v)
Prop: GWS 5030
ESC: 6A
Servo: Cirrus CS-201
Batt: 2S 300mah Turnigy Nano-Tech
Rx: Futaba R124F 35mhz
The only issues i've got with this setup is the battery voltage was dipping quite allot, even at half throttle. Got a 320 hyperion lipo coming tho.. And the Futaba RX has terrible range. Other than that it has loads of power and is lightweight.
Only flown it 3 times so far..
1st time I had huge radio glitches from a poorly routed aerial.
2nd time had the same problem.
3rd time fixed the aerial so got it flying. Then had to deal with finding the correct COG. Managed to bring the COG forward slightly which made it fly better, but it was still quite tail heavy. A larger battery should fix that though, so next flight is the true test... Also, the plane was very twitchy. I mean very very twitchy even for such a tiny model. But i think that was due to not having much expo and having nearly 80deg deflection on the elevons! (see pics lol). I have managed to rocket launch it though by standing it on its tail and punching the throttle.
Hopefully get a chance to see how she really flies soon...
Building wise I've put a carbon spar under the motor mount running most of the span. This seems the best place and doesn't interfere with the curve of the wing. The servos have been mounted just aft of the COG. There was not enough room at the front to mount the RX and Lipo in-line, and still get correct COG (hence my tail heavy problems). So i would place the servos further forward next time. The RX and Lipo have been staggered (RX on top, Lipo below) which weakened the structure abit so i have embedded a small sheet of Mylar and second carbon spar in the battery recess to strengthen. I've run 0.5mm carbon along the leading edge and trailing edge of elevons with extensive glass tape on the nose. I've also made housing for the Lipo and RX out of an old nylon dental floss box which just happened to be the perfect shape (I had weight to spare). The winglets are left un-braced. Epoxy glue all the way. I Just used a black marker and a couple of stickers to decorate and help with orientation.
I should point out that this Micro Swift has been built to last. Thrown around. Sat on. And generally abused. I carry it in a plastic bag and just sling it about, absent-mindedly put things ontop of it etc. It's my careless, dont-need-to-worry-about, easy-to-transport plane. And yes i have sat on it. And it's proving to be pretty tough! Flight one and two both incurred some very energetic, full speed crashes - not even a dent.
Built to last i tell ye! lols
Just need to find the COG, dial back the throws and i think it will be a keeper...
LowBoTomy is offline Find More Posts by LowBoTomy
Old Aug 04, 2014, 11:29 PM
kelloggair's Avatar
Joined Mar 2008
nice to see another
Old Aug 05, 2014, 01:11 AM View Post
Adelinee
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Dec 21, 2014, 11:06 PM
kf1111 is offline
Find More Posts by kf1111
Joined Jan 2012
I have had this for a couple of years. I first used it with a Stryker motor and some hxt servos. It works pretty well but i kept stripping the gears off the hxt's slamming it into the ground every once in a while. So I quit using it. The other day I pulled it out and put the E-Flite 280 motor off of an Edge 540, and the matching digital mini servos, and ESC. This little thing will seriously scream with this setup. I am using the 3s 450 mah batteries from the edge and a 5043 prop. I also laminated it with 5 mil laminate. These E-flite servos are much tougher, I have not stripped one as of yet. I have slammed it off the ground a few times! I have dopplered this setup, it will easily run consistently in the 60 to 70 mph range, sometimes a little more. I had to add some weight to the nose for balance but it still comes in around 5 ounces. Pretty impressive for such a tiny thing! I have no idea what it weighed with the stryker motor, but this motor is heavier as I had to add weight. It works really well with this setup and can even take wind up to about 15 mph!
It is more fun running the 3s setup! Also, I put laminate on mine, makes it much stiffer, but, laminated or not, I don't think it can be broken! This little jewel can outfly much bigger planes!
kf1111 is offline Find More Posts by kf1111
For Sale Swift NX, Swift 550 Carbon, Swift 16 - Parts (NEW) shipping CONUS LowWatts Aircraft - Electric - Helis (FS/W) 0 May 19, 2012 12:09 AM
New Product Micro Swift bluemeane Flying Wings 1 May 14, 2012 12:53 PM
Movin on up from Micros (to Swift) heli_newbie Electric Heli Talk 1 Oct 31, 2005 10:51 PM
video of super swift electric (aka Super micro bandit) dave morris Electric Ducted Fan Jet Talk 7 Nov 10, 2004 04:59 PM
super swift E (aka Micro bandit) on 400 watts dave morris Electric Ducted Fan Jet Talk 0 Oct 29, 2004 08:01 PM
