This thread is privately moderated by hobby2011, who may elect to delete unwanted replies.
Old Jul 13, 2012, 05:03 AM
hobby2011 is offline
Find More Posts by hobby2011
中国, 广东省, 深圳
Joined Sep 2011
Tarot 2012 Latest ZYX-S Flybarless 3 Axis Gyro System - zyx s
Product Description:
The TAROT-S Version ZYX high performance multi-function 3-axis gyro system is the lightest flybarless system in the world. It is compatible with all 200-700 nitro or electric power helicopters and support 90, 120, 135, and 140 degree CCPM swashplate systems. Furthermore, it is compatible with all type servos, and support firmware update. The setup process is quite easy, needs only ten minutes.
ZYX-S 3-axis gyro system provides five different flight modes, which can satisfy players from beginners to advanced. ZYX-S 3-axis gyro system has many adjust options; pilots can adjust the parameter of swash plate and rudder servo, which make pilots feel the impressive of the flybarless helicopter.
ZYX high performance 3-axis gyro system uses MEMS gyro sensor which can be used in bad weather condition and pilots can control the flying status of helicopter precisely. Built-in pirouette flip optimization function, the speed of pirouette is really stable. When the helicopter pirouettes flip, the fuselage will spin at one point without shifting
The ZYX-S and ZYX 3.0s new function:
1:The ZYX-S add DSM2 and DSMJ satellite receiver support function.
2:The ZYX-S add Futaba S-Bus receiver support function.
3:The ZYX-S add failsafe function when using DSM2 and DSMJ satellite receiver,
user can set the failsafe values for throttle and collective pitch.
4:The ZYX-S add four aircraft configrations: + quadrotor, X quadrotor,
conventional airplane(enhance hover and 3D flight), delta airplane.
5:The ZYX-S can use the USB adapter to connect to PC, the new PC software is
ZYX 3.0. It can be setup by the ZYX multifunctional gyro programmer.
6:The ZYX 3.0 add parameter explanation function, put the mouse on the parameter,
the explanation will be shown.
ZYX-S New Specification:
1) Dimensions: 37.2mm*25.2mm*13mm
2) Weight: 9.8g (not including connecting wire and adaptor)
3) Operating voltage: DC 3.5V-9V
4) Operating current drain: 60mA
5) Operating temperature:-15C~65C
6) Maximal angular velocity: 800 degrees/sec
7) Tail servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo, 960us digital servo
8) Swashplate servo compatibility: 1.52ms analog servo, 1.52ms digital servo
9) Radio compatibility: PPM, PCM, 2.4G
10) Supporting firmware upgrade
11) Supporting Multi-Blade Rotor Head
Manual:
http://www.hawk-rc.net/download/ZYX_GYRO_MANUAL.pdf
Rom Update:
http://www.hawk-rc.net/download/zyxs.rar
Firmware upgrade instruction
1.Connect the ZYX gyro to PC by ZYX USB adapter,click "Connect ZYX",make sure it succeed.
2.Open the Firmware in ZYX PC software.
3.Keep the PC,USB adapter and ZYX gyro connecting.Power off ZYX gyro,press "SET" button of gyro and power on.
4.The red lamp is flashing,click "Upgrade" button to start upgrade,the ZYX gyro will restart after successful upgrade.
5.Please make sure your gyro is Tarot ZYX,otherwise the gyro will be damaged.The ZYX gyro does not need to be setup again.
rcmodelpart3@hotmail.com
hobby2011 is offline Find More Posts by hobby2011
Discussion New Tarot ZYX/ZYX-S/ZYX-S2 Flybarless System beenflying Mini Helis 12391 Jul 07, 2016 09:44 PM
Discussion tarot zyx-s 3 axis gyro richb77 Flight Accessories 4 Mar 29, 2015 01:15 PM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
