Old Nov 30, 2012, 06:53 AM
J Morgan is online now
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I know that method is used in creating panel lines on a plug. A little worried about weight buildup but hopefully it wouldn't be too bad. This porker is over 30 lbs now so.........
Thanks guys, I may try that on the stab and see how it goes.
J
PS - Nice work Chad
J Morgan is online now Find More Posts by J Morgan
Old Nov 30, 2012, 10:53 AM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
J, it is only necessary to spray primer over the tapes and maybe half an inch or so either side. Then you sand the primer back down to reveal the tape and feather the outer edges into the finish. The result is a very narrow build up of primer on either side of the tape and I doubt the weight build up would be any more than if you left the tapes in place. Shouldn't be of any consequence on a model the size of this one I wouldn't think. I'm sure whatever you decide it's going to look fantastic. Keep on truckin'!
Chad Veich is online now Find More Posts by Chad Veich
Old Nov 30, 2012, 11:48 AM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
John
I did my entire T28 fuse with both raised overlap panels and the flush fit taped panels using no more than 4 fluid ounces of primer. Most of that was wet sanded off.
acesimmer is offline Find More Posts by acesimmer
Old Nov 30, 2012, 02:55 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Hey John, I'm also in the process of adding panel lines and wowplanes rivets to a FMS Corsair that I'd like to have done by SEFF. I was going to use the tape and primer method of putting on the lines.
Gotta admit that I'll be using alot less of both than you.
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Dec 01, 2012, 07:36 AM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks guys
Back in the shop today. I've wanted to try that on a fuselage mold if I ever get to the point that I wanted to do a conventional mold. Should have tried it on the cowl molds. I might as well work on the technique on the 119. I'll see what I can work up on it today.
J
Old Dec 01, 2012, 08:56 AM
acesimmer's Avatar
Joined Oct 2011
One thing to watch out for is the amount of primer that you use. My first go at the tape and primer was a disaster. I used a touch up gun along with a quality 2k primer. So I lay a couple of coats and think..... not much buildup. So I do several more coats. After cure I begin to wet sand... and sand... and sand! Holy crap! I could not see the tape. After a half hour and failure I switched to using my airbrush and sprayed thinner coats. About four passes and its just right for the panel lines and about six to seven for the raised overlapping panels (see pic for both).
I found a pack of 3/8" colored electrical tape at Lowes. I use this for the raised hatches and overlaps. The tape is perfect thickness at around 0.010" and forms perfectly. Comes off with no residue or issues.
Old Dec 01, 2012, 10:37 AM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Ace,
I'm testing the technique on one of the cowls now. I'll keep that in mind.
J
Old Dec 01, 2012, 11:53 AM
Scale Builder
Joined Jul 2002
I use electrical tape and spot putty or evercoat for making overlapped panels. The electrical tape allows for wet sanding the putty without disentegrating in the process. Once again all that is left is a few thousandths of an inch of filler and the weight build up is negligible. Primer works too but I think spot putty provides a more durable edge to the overlapped panels. My .02 cents anyway. The difficult part of this process is just figuring out what order in which to proceed with application of the panels and then building up on the correct side of the tape!
Here they are on my Harvard.
Old Dec 01, 2012, 12:22 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Very nice work Chad.
I have some thin vinyl sheet stock that I plan on using for access panels. I can stick it on, build up around and remove for a recessed panel or cut a negative and build up inside for a raised panel.
Meanwhile back at the ranch I tried the cowl panel lines. Came out pretty good. Need to go to the auto supply and resupply my primer. Ace was right, it builds faster than you can tell. Sort of a learning curve.
I have the second cowl ready to wet sand and the stab is getting it's coats of primer. People, we have created a lot more work before I can paint. No turning back now.
J
Old Dec 01, 2012, 12:51 PM
HawkLover is offline
Find More Posts by HawkLover
Callsign: CornDog
HawkLover's Avatar
Milpitas, CA
Joined May 2003
Looks pretty good J! Did you by chance take a before and after weight. With this smaller piece, it may not be possible to catch a difference, but just curious.
HawkLover is offline Find More Posts by HawkLover
Old Dec 01, 2012, 12:55 PM
acesimmer's Avatar
Joined Oct 2011
Looking really nice John. I had never done them before. After seeing the outcome I'm doing it on all my plugs for moulds. If you do any rivets I found the yellow tight bond to be superior to Elmer's white glue. I can handle the plug with no issues along with lots of waxing etc. When I used the white glue I lost a couple of rivets. The TB glue also rounds out better so very few raisins.
Old Dec 01, 2012, 06:08 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Nope, didn't weigh it Hawk. But there isn't enough primer on there to matter. Besides, this thing at 30 lbs flew like a 10 lb model.
I doubt if I do any rivets Ace. At 1/12th scale they would be so small it would be very difficult I think to get them small enough.
J
Old Dec 02, 2012, 09:44 AM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Work continues on the panel lines. I'm keeping them pretty simple otherwise she won't get painted for the next Vegas much less SEFF.
The stab panel lines are done. I'm not doing any panel lines on the bottom, you would have to be an eagle to spot them on a flyby. And I don't plan on turning this beast over anytime soon.
Gotta go........ more lines to do.
J
Old Dec 02, 2012, 04:40 PM
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Middle section is done. Working on the outer wing panels now. Will finish them in the morning and then start on the fuse.
J
Old Dec 02, 2012, 04:47 PM
jpt62 is offline
Find More Posts by jpt62
Joined Feb 2012
Zebra.... Now that is an interesting camo pattern
jpt62 is offline Find More Posts by jpt62
Video AC-130U, (K. Sparks-based) wewprez Electric Plane Talk 3 May 21, 2012 10:10 AM
Questions and thoughts about Palmer Plans C-130 Lucas in Alaska Scale Kit/Scratch Built 35 Oct 30, 2008 05:00 PM
T-38 Based on CMYK Plans Ralph A. D'Amelio Electric Ducted Fan Jet Talk 30 Nov 24, 2004 11:27 AM
Enlarging Plans Based on Engine Size (A7 Corsair II propped) sethorus The Builders Workshop 8 Oct 22, 2003 10:53 PM
Palmer Plans KAMarks Scale Kit/Scratch Built 4 Nov 08, 2001 08:42 AM
