Old Nov 14, 2003, 04:08 PM
Salto is offline
Find More Posts by Salto
Australia, NSW, Sydney
Joined Feb 2003
Photos of 90% Ultimate for IPS Dual
Hi Foamies,
Here's my latest effort on the Foamie front. It's loosely based on Tim Hart's Ultimate Bipe, scaled to 90% to better suit the IPS Dual drive. At this scale the wing chord looked worryingly small, so I increased it to 160mm (6 1/4"). It's all 3mm Depron, coloured with Sharpie pens.
I wanted someting that would hide the gear and look a little better than a profile model, so I simply cut two fuse sides and spaced them one E-Tec width apart with Depron bulkheads. A bit more work, but worth it for the better looks. I used 0.4 x 2mm carbon flat top and bottom of both wings.
690mm (27") span
160mm (6 1/4") chord
30mm (1 1/4") aileron chord
IPS Dual B, 1180 GWS prop
2 x 1200 E-Tecs
3 x no name 5g servos.
Jeti Rex 5 RX
247g (8.7 oz) AUW
On this set up it will hover for most of the pack. It flies really nice indoors, the transition in and out of hover is particularly smooth and drama free. It does nice tight loops and rolls, and flies inverted with almost no down elevator required.
The big surprise is how well it flies outdoors. For it's size it eats up sky, doing big tumbling stuff, but can also be flown right up close. I test flew it on a very windy day (20 mph +), but whilst not much fun it was always in control.
Graham.
Salto is offline Find More Posts by Salto
Old Nov 14, 2003, 04:12 PM
Salto is offline
Joined Feb 2003
I increased the tail areas a bit, to match the wing chord increase.
Old Nov 14, 2003, 04:15 PM
Salto is offline
Joined Feb 2003
The "canopy" area has 6mm depron bent to the side profile, glued between the 3mm sides, then sanded to a rounded shape. The fuse top in front of the canopy was done by bending 3mm Depron around a broom handle.
Old Nov 14, 2003, 04:33 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Quartz Hill
Joined Nov 2003
Hey Salto, great looking plane! What do you mean by IPS Dual? Is it dual ball bearing? Which drive is it (the A, or B, etc)? Good thinking on the use of Sharpie pens. I recently found a silver Sharpie and want to use it to try to simulate panel lines.
foamflyer is offline Find More Posts by foamflyer
Old Nov 14, 2003, 04:40 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
I believe he means dual motor ips....flies the TM great with lopos.
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old Nov 14, 2003, 04:47 PM
Salto is offline
Joined Feb 2003
Foamflyer,
I used the IPS dual RXC (7.2V) motors mounted on a B gearbox. See www.gws.com.tw
I used this motor/gearbox/prop combination to keep the current down and the flight time up. The motors draw about 3.4 Amps (total) on 7 Volts so the power is about 24 Watts. I get bored before the pack runs down, and the motors should last forever.
Graham
Old Nov 14, 2003, 04:51 PM
Salto is offline
Joined Feb 2003
Some more figures on this model.
Wing loading: 3.7 oz/sq ft. - nice, slow stall
Power loading: 44 Watts/pound - could be better, but still hovers!!
Energy loading: 15.45 Wh/lb - flies forever!!
Graham.
Old Nov 14, 2003, 05:17 PM
GenesisCreation is offline
Find More Posts by GenesisCreation
GenesisCreation's Avatar
United States of America
Joined May 2003
Congratulations on a great looking plane Salto!
GenesisCreation is offline Find More Posts by GenesisCreation
Old Nov 14, 2003, 05:54 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Hey Salto, great looking model! I've been tempted to build something like this for our upcoming winter season, and was wondering if you would be able to give me some more measurements. I know next to nothing about designing biplanes, so I'd like to get some details from a model that clearly works well.
Could you tell me:
- distance from the LE of the bottom wing to the backplate of the spinner
- distance from the TE of the bottom wing to the LE of the horizontal stab
- stab root chord, tip chord, span
- fin root chord, tip chord, span
- sweep of the wings
- separation distance of the wings.
If you wouldn't mind, I'd be really grateful!
SoarNeck is offline Find More Posts by SoarNeck
Old Nov 14, 2003, 06:15 PM
Salto is offline
Joined Feb 2003
SoarNeck,
Have a look at this link, and download Tim's plans for the Ultimate Bipe
http://www.rcgroups.com/forums/showt...5&pagenumber=1
I simply printed this plan out at 90% scale. I added 10mm on the LE and TE of both wings, made the aileron chord 30mm, and kept everything else important pretty much the same except the stab and rudder/fin which I scaled up about 20%. I also dropped the balanced tail surfaces because I thought they would be too susceptible to damage. And of course, I made two 3mm fuse sides instead of the single 6mm profile on Tim's plan.
Next build I will take out most, if not all of the sweepback to get rid of the strong yaw to roll coupling, and adjust the wing position to keep the balance right. I guess I'm waiting to see what Tim is doing about this before proceeding. I'd also do balanced tail control surfaces and increase the elevator area some more to get better elevator authority in high alpha manoeuvres.
I hope the above link, plus these comments answer your questions. If you want more info just ask.
Graham
Old Nov 14, 2003, 07:27 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Thanks for the reply - I didn't realize that this was based on an available design. Too much time in the sailplane and High-Performance forums...or is it that RCGroups has too much interesting info on it?
Old Nov 28, 2003, 09:53 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Awesome!!!
poobs is offline Find More Posts by poobs
Old Feb 10, 2004, 05:35 PM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
Hey Graham.
How does it knife at that weight ?
Michael
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Feb 10, 2004, 06:35 PM
Salto is offline
Joined Feb 2003
Hi Michael,
It knife edges well, I guess because there is plenty of rudder authority and side area (and power). Plus with the biplane configuration and central, zero Deg. thrust line all the thrust and drag forces are nicely aligned.
In level flight the swept back wings produce a strong yaw to roll coupling - the model can be flown on rudder only (no aileron) quite easily. At zero angle of attack on the wings, as in knife edge, this coupling will drop to zero, but the entry to knife edge can be a bit tricky. I usally lift the nose a bit first, then drop in a bit of down elevator as I roll over and enter knife edge. If I don't get it right, the yaw to roll coupling will slowly screw the plane out of knife edge.
Graham.
Discussion 22" Ultimate Biplane for IPS Power P. Tritle Scale Kit/Scratch Built 165 Jul 14, 2013 03:59 PM
anybody have free plans for fanfold foam with ips dual motor new flyer Foamies (Kits) 9 Sep 23, 2004 01:12 AM
Question GWS IPS DUAL, which one for the Tiger Moth? dostacos Parkflyers 2 Apr 05, 2004 08:14 PM
Discussion Indoor foam Ultimate for IPS build thread jpflyer 3D Flying 162 Jan 21, 2004 03:55 PM
90 ccpm for 8UHFS petn7 Electric Heli Talk 4 Aug 01, 2001 09:45 PM
