Old Jul 12, 2012, 05:54 AM
sugas182 is offline
Find More Posts by sugas182
Joined Jul 2012
A-6 Intruder Profile, Kf-2 PLANS
Here's my second model design, and plans. This one is a profile of the A-6 Intruder. I've included outlines for a Kf-2 airfoil if you would like to use one
Hope this is good. Let me know what you think.
Hardware specs, as with any decent parkjet:
2200kv, 6-8in prop and a 1000mAh battery should do good.
CG is about 70mm from the front end of the rear part of the fuselage when assembled. I've included a JPEG of the location. If you do want the CAD plans PM me or fire an email to sugas182@gmail.com
Cheers
sugas182 is offline Find More Posts by sugas182
Old Jul 12, 2012, 10:51 AM
roo_ster is offline
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
sugas:
Looks great. I like the small parts count.
But I have one question:
Is the whole rear of the aircraft held to the front by about 1/2" of foam between the horizontal prop slot and the aileron?
roo_ster is offline Find More Posts by roo_ster
Old Jul 12, 2012, 11:16 AM
sugas182 is offline
Joined Jul 2012
Originally Posted by roo_ster View Post
sugas:
there's a slot in the rear fuselage for accepting the rear wing tabs. That and a line of.hot glue along the join of the wing rib and the fuselage should do good I suppose.
If it's integrity still bothers you then you could cut out the motor and prop slot more towards the Kf. Although I have to agree with you that is the weakest point in the structure. a small 3mm wood towel or CF tube (whatever your fancy) underneath that should help too.
I wish I could build this and show, but as I said in my last post I don't have much in the way of money of my own. kinda sucks but Ah well I'm doing my bit for the RC community :-)
P.S. hope this answers your question :-)
Old Jul 12, 2012, 11:18 AM
sugas182 is offline
Joined Jul 2012
I mean dowel*
Old Jul 12, 2012, 11:32 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Disregard was already mentioned.
dedStik is offline Find More Posts by dedStik
Old Jul 12, 2012, 11:59 AM
sugas182 is offline
Joined Jul 2012
dedStik:
disregard what? I didn't quite get you.
dedStik and roo_ster:
tell you what, I'll make some revisions and post the revised plans in the same thread?
Also PM me your email ids and ill send you the sketchup plans if you guys would like to tweak them yourself. :-)
how does that sound?
I'll upload the revisions as soon as I can in the morning.
Old Jul 18, 2012, 02:57 PM
georgy is online now
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
I like it. The "weak-spot" is a problem. My 1st own-design was a Mig-15 slot jet, but how do you ensure fuse strenght when a prop cuts all the way thru it?
I used a 4" prop with 4000kv motor so the prop fits inside the fuse hight. Then re-enforced the fuse top & bottom with bamboo skewer...
I would move the prop forward to get the max available fuse hight, use small prop & skewer top/bottom.
Doing the same again on a "sort-of" BAE HAWK. This time a low-wing with top-only bracing.... 3500kv heli 2218 with 5.2" apc
Loud but fun...
georgy is online now Find More Posts by georgy
Old Jul 18, 2012, 09:16 PM
sugas182 is offline
Joined Jul 2012
georgy,
You're right, I don't seem to have taken the strength issue into account. And to think I had finally made a beautiful design :P
I like your idea and what you've done with the MiG and the Hawk. I'll definitely incorporate them and take more care towards the structure in the future plans
The MiG looks really beautiful. Do you mind mailing me the plans? I'll make it for sure once I'm finally able to.
I'm trying to work on designs for an A-1H Skyraider and/or a Bucc. Which one would you suggest?
Cheers
Suhas
Old Jul 19, 2012, 10:30 AM
georgy's Avatar
Joined Jan 2012
Hi Suhas,
The Mig was done from 3-view, so no plans sorry. If you want i can try & help you to do one. It was a mission to get it to fly nice, but the lessons learned i can help with. Its retired now but was a nice flyer after all the mods.... Not very acrobatic... but more jet-like.
Below is my (short) build thread...
http://www.rcgroups.com/forums/showthread.php?t=1615277
I'm a bit of a jet-nut so i would go for the Buccaneer
It is a good candidate for a set-up similar to Your A-6, but maybe using the hi-kv motor with smaller prop so you can ensure strong fuse...
George
Old Jul 19, 2012, 03:31 PM
planecrazy1969 is offline
Find More Posts by planecrazy1969
Gone Fly'n
planecrazy1969's Avatar
USA, NV, Las Vegas
Joined Jan 2007
You could always give this a try...some planes just fit better around EDF's...found these pics here... http://www.radiocontrolesing.com.mx/jet%20planes.htm
planecrazy1969 is offline Find More Posts by planecrazy1969
Old Jun 18, 2015, 01:55 PM
eduardo escalona is offline
Find More Posts by eduardo escalona
Joined Nov 2014
radiocontrolesing
It is not http://www.radiocontrolesing.com.mx
it is http://www.radiocontrolesing.com
not with mx
eduardo escalona is offline Find More Posts by eduardo escalona
Discussion Profile kellet autogyro plans MikeSafir Auto Gyros 1 Jul 07, 2012 03:51 PM
Discussion RC Superpowers Extra 300 Profile plane with kf-2 Airfoil! H2o Buffalo Foamies (Scratchbuilt) 5 Jan 30, 2009 09:59 PM
For Sale A-6 INTRUDER prop driven plans 54"WING SPAN ama-hobby Aircraft - Fuel - Airplanes (FS/W) 0 Mar 21, 2006 06:58 PM
For Sale A-6 INTRUDER plans 54"WING SPAN ama-hobby Aircraft - Fuel - Airplanes (FS/W) 0 Mar 03, 2006 05:11 PM
