Old Jul 12, 2012, 05:34 AM
indoor_fr is online now
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Build Log
Semi scale Gee Bee R3 (potensky kit improved)
RobotBirds (Uk) sells this cute little EPP kit from POTENSKY.
The plane is already painted. There are no landing gears. Too bad for a Gee Bee R3!!!
Otherwise, the kit is nice. The right wing has an aileron, while the left wing doesn't have any. I've read on forums that it works, but i'll have two ailerons.
My goal is to bring some improvements in order to have a semi scale plane:
Add landing gears
Add flying wires
Replace the canopy by a transparent one
Install a pilot
The airframe is very light: 22g.I would like to build a light airplane, so it could fly indoor and outdoor.
I will use:
- a DT RX (the AR6400 doesn't fit in the narrow fuselage).
- 3 x 1.7g servos
I've got a Tiger 1302 motor and a 1 S ESC, but i think that the AUW will be too high for this little motor.
I also have a 6g motor and a 2S ESC that could suit. We'll see.
indoor_fr is online now Find More Posts by indoor_fr
Old Jul 12, 2012, 10:37 AM
Chrizz is offline
Find More Posts by Chrizz
OY-5542
Chrizz's Avatar
Denmark, Central Denmark Region, Silkeborg
Joined Nov 2009
Hi Frank!
Interesting model! any chance for some more pics? Maybe of that narrow fuselage (is it hollow already?.. I'm asking because I notice that the motor seems mounted outside the fuselage.)?
About your statement that a AR6400 won't fit inside the narrow fuselage, have you fought of mounting it vertically?
Chrizz is offline Find More Posts by Chrizz
Old Jul 12, 2012, 11:57 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Originally Posted by Chrizz View Post
Hi Frank!
About your statement that a AR6400 won't fit inside the narrow fuselage, have you fought of mounting it vertically?:-)
Hi Chrizz!
The fuse is not hollow. There are some holes to install the servos, rx, etc...
a part of the fuselage is removable and will hide the rudder and elevator servos + the RX (see pictures).
I have thought about mounting the AR6400 vertically, but this is not convenient, especially for the rudder and elevator linkages.
I 've already my DT RX and my servos.
Here are some pics.
Cheers.
Old Jul 13, 2012, 01:11 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The rudder and elevator are installed. I haven't glued yet the servos .
Old Jul 13, 2012, 03:01 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Some nice pictures of an RC model in Germany.
http://www.airworld.online.de/deutsc...Bee/Geebee.htm
Old Jul 14, 2012, 05:45 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
I've installed the servo for the ailerons.
I'm planning to use an XP-7 ESC with light wires and an AP05 motor on 2S.
I have to work on the landing gears. I've bought spare parts of the UMX Gee BEE R2.
They are quite heavy (15g) but i don't want to bother to build them.
Old Jul 15, 2012, 11:32 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
A little more progress. I've carved into the wings to "insert" the landing gears, because the plastics pieces that holds them have the curvature of the UMX Gee Bee R2's wings.
Old Jul 17, 2012, 04:36 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The flying wires are partially installed.
I'm waiting for the AP05 motor. Meanwhile, i'm working on the canopy. I've searched for a blister that could fit, but i didn't find one.
I'm thinking of making a mold and try to make my own canopy.
Old Jul 17, 2012, 10:32 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
looks pretty good
minimicrorc is offline Find More Posts by minimicrorc
Old Jul 19, 2012, 03:14 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks.
Here is a the canopy mold made with some plaster. I have used a plastic canopy (from a FF model) that was not long enough. I've added a bit of lenght.
I hope i'll be able to form a new canopy with it...
Old Jul 19, 2012, 03:24 AM
Chrizz is offline
OY-5542
Chrizz's Avatar
Joined Nov 2009
Nice the canopy! I can only be envious of your molded canopies (compared to my usual 'depron-non-see-through').
Is it just heated to take form?
Old Jul 19, 2012, 03:42 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks Chrizz.
I will use a piece of plastic and heat it in my oven, then plug the mold in it. I haven't any peculiar skills at doing canopies, so i guess i'll have to try many times to get something correct.
Why would not you try? A clear canopy really makes a difference and it worths the effort.
Old Jul 19, 2012, 09:30 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
flying wires done
Ok, i have to mold the canopy and make the pilot head.
I like this one: nice looking and easy to make.http://modelis.at/node/351#http://
Old Jul 22, 2012, 08:43 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
The AP05 arrived 2 days ago, and i have installed it in the plane.
I'm using an XP-07A ESC.
The fuselage being narrow, i've cutted in a triangle shape the motor mount and carved the foam in order to insert the motor.
The Rx is installed and the ailerons, the elevator and the rudder are working fine.
I will have to determine the CG location.
I still have to make the pilot and the canopy...
Old Aug 02, 2012, 01:09 PM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
making a canopy with clear shrink tube
I've tried to make a canopy with a clear shrink tube. I'm not completely satisfied because it is opaque and quite heavy (2.2g).
It was just a try, to see if it could be an alternative to the traditionnal method.
I use a hair dryer.
Sold Hobby Lobby R3 Gee Bee Fantasy Racer FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 4 May 09, 2012 04:27 PM
For Sale Potensky Gee Bee R3 rwait Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2012 03:32 PM
Question gee bee r3 stargate123 United Kingdom 0 Feb 22, 2012 10:53 AM
For Sale GEE BEE R-1 1/5 Scale Semi-kit REDUCED!! tlh101 Aircraft - Fuel - Airplanes (FS/W) 5 Sep 29, 2006 03:41 PM
