Old Jul 12, 2012, 04:47 AM
aerosoardude is offline
Find More Posts by aerosoardude
Its not that windy...
United States, CA, PORTER RANCH
Joined May 2007
Adding Capacitors, what voltage and how much is too much?
Hey all,
I've recently bought the 150A 6s ESC from HK. I'm not actually planning to use it in an rc car, but that's besides the point of this post. Bottom line is that I need to reduce the voltage spikes as much as possible.
I've been reading up on the topic of adding caps to escs. Every time someone adds capacitors, they seem to use ones that are nearly twice the input voltage.
The HK esc only uses 25V caps, good brand caps, but only 25 nonetheless.
My questions are:
Shouldn't I upgrade the caps to 50V versions?
And as long as I'm at it, how big of a capacity can I add?
Thanks for any and all help!
aerosoardude is offline Find More Posts by aerosoardude
Old Jul 12, 2012, 07:34 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can add pretty much as much as you want within reason (ie not adding 5000mah of capacitors). If you add too much you can damage the batteries when they try to charge up the capacitors when you first plug the battery in.
There's no benefit to running a higher voltage, unless you can't find the lower voltage ones easily.
wparsons is offline Find More Posts by wparsons
Old Jul 12, 2012, 10:03 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
I think when adding caps to anything you need to go up atleast 30% more Volts than the system.
I think it's 30% but i could be wrong.
traxx de maxx is offline Find More Posts by traxx de maxx
Old Jul 12, 2012, 04:46 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You don't *NEED* to add buffer in the voltage, as long as the caps are rated for the maximum voltage you'll ever run.
I would go with a bit more than 25v if you plan to run 6s since 6s fully charged is 25.2v.
Old Jul 13, 2012, 05:22 PM
Joined May 2007
I ended up buying 50v caps in case of voltage spikes. Don't mean to ignore your advice wparsons, but if larger won't hurt, then I might as well use bigger ones.
Thanks for everything!
Old Jul 15, 2012, 04:56 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ Like I said, there's absolutely no harm in having higher voltage ones. You won't see any benefit if your voltage is well below the limit of both, but if you're running right near the limit it'll be nice to have the extra head room just in case.
Old Jul 16, 2012, 12:03 PM
uk
Joined Nov 2010
do they not store the same amount of voltage that supplies them anyway.
so if you use it on a 20V system then only 20V will be stored no matter how high the voltage rating is on the cap, or am i wrong somewhere.
Old Jul 16, 2012, 08:48 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
No, you're 100% right. They only store the voltage being supplied, the voltage rating is just the amount of voltage they can happily store.
Discussion What engine and servos would be best for Wot 4? Also how much fuel is needed? absandams Beginner Training Area (Fuel) 5 Jun 13, 2012 05:44 PM
Discussion how much wing damage is too much damage ?? :-) khooke Micro Ready-to-Fly 15 Jun 13, 2012 11:13 AM
Discussion How Much Should Government Do? How Much Is Too Much? How Much Debt? LcJ Life, The Universe, and Politics 80 Jul 28, 2011 07:43 PM
How much voltage is too much for this Aveox motor? temacc High Performance 4 Apr 23, 2004 07:36 PM
SS wing Dihedral, how much is too much? too little? Keesercc Beginner Training Area (Aircraft-Electric) 17 Jun 28, 2003 02:08 AM
