Old Aug 30, 2012, 05:49 AM
dado099 is offline
Find More Posts by dado099
Italy
Joined Sep 2007
Originally Posted by Rafa's CB100 View Post
I just noticed that there is a f/w update available on Walkera's site, V1.1. The notes say, "The program provides improved throttle lock set a negative value appears related death, throttle BUG."
Back when I was writing the review, I noticed that, since it's on Fixed ID, if I bound the model with throttle hold on (which was set to -5), then turned throttle hold off, the motor would start to turn slowly. Apparently, the rx takes the -5 that the tx is putting out and assumes it to be zero, so that when you take it off throttle hold, the rx is actually thinking 5% or something like that. I took care of this by setting my throttle hold value to zero instead of a negative number. I'm guessing that this f/w update addresses this concern.
Rafa
Hi Rafa,
I flashed V1.1 and everithing was ok, but when i reconnect the receiver the UP02 software still says it is V1.0.
Did you actually flash the new FW ?
Can you check the actual FW version reported by UP02 software ?
Thank you very much.
dado099 is offline Find More Posts by dado099
Old Aug 30, 2012, 06:51 AM
Rafa's CB100 is offline
Find More Posts by Rafa's CB100
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Yes, I updated it, and yes, it still shows 1.0 when you first connect the rx to the tool. It's the same way on my Ladybird. I'm pretty sure that the '1.0' refers to the hardware, not the firmware (my ladybird has '1.0' printed on the board itself). It seems like there should be a way to know which f/w is installed, but I haven't found it.
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Aug 30, 2012, 10:28 AM
dado099 is offline
Italy
Joined Sep 2007
Rafa
Thank you Rafa.
Anyway, when I last updated mini cp with FW ver. 1.1, after the update it showed correctly ver. 1.1, so there should be something wrong with walkera.....
Old Aug 30, 2012, 10:35 AM
Bean Bandit is offline
Find More Posts by Bean Bandit
Sudan, Khartoum
Joined Aug 2012
Don't know about Walkera but they are certainly not the first company to bring out an update and missing to update the version number. This is something easily overlooked by programmers.
Bean Bandit is offline Find More Posts by Bean Bandit
Old Aug 30, 2012, 08:42 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Bal Delay on POTS
I have following question s on Bal Delay swith on the RX.
- Function , is it suppose to keep the heli level horizon. So higher means more horizonally level?
- Higher or lower to deal with wind, otherwords how does it get affect by windy conditions.
- Higher or lower for sports flying
Not to confuse with Elev-Ale Ext which makes the servo responds quicker.
Torch8 is offline Find More Posts by Torch8
Old Aug 31, 2012, 02:10 AM
dado099 is offline
Italy
Joined Sep 2007
Not quicker, but more servo travel.....
Old Aug 31, 2012, 09:49 AM
martin_ is offline
Find More Posts by martin_
Joined Sep 2010
Where have you seen the Bal. delay pot? There is no bal. del. on the V120.
martin_ is offline Find More Posts by martin_
Old Aug 31, 2012, 09:53 AM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
Sorry wrong post, should have gone to M120d01.
Old Sep 02, 2012, 07:11 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
Hey Y'all,
You may remember me mentioning my friend Kenny in the original review. He finally got a V120 v2, and here was it's first flight. I'd checked screws and copied a model over to his tx, but I never spooled it up. Too bad it was this windy. He was left wanting more head speed, and I haven't delved into the motor/pinion upgrade options yet, so I might be asking y'all for powertrain upgrade advice soon.
Kenny's maiden with his new Walkera 'New V120D02S' pt 1. (1 min 46 sec)
Kenny's maiden with his new Walkera 'New V120D02S' pt. 2 (1 min 20 sec)
Hopefully there will be less wind next time.
Rafa
Old Sep 03, 2012, 08:32 PM
Travis MCH is offline
Find More Posts by Travis MCH
Travis MCH's Avatar
United States, TX, New Braunfels
Joined May 2011
Pretty cool Rafa,
Let me know next time you guys plan to go to the field and I'll come too. I'm curious to see any mods Kenny makes on the V120
Travis MCH is offline Find More Posts by Travis MCH
Old Sep 03, 2012, 08:42 PM
Travis MCH's Avatar
Joined May 2011
Did Kenny mess with the pots on the RX or did he leave them at stock settings?
Does he have a Devo or is he using yours?
Just curious what kind of RX and TX setting he may be using.
Old Sep 04, 2012, 12:26 PM
Live to learn. . .
Austin, TX
Joined Dec 2009
Originally Posted by Travis MCH View Post
Pretty cool Rafa,
Will do. You have to know that I'm jazzed about having a more experienced guy at the field with one of these.
I spoke with Kenny last night. He said he increased the E/A gyro pot a bit, also 'maxed' the extent pots. That's after 10 flights, so let's see what happens. For now he is using my 8S. He just finished buying a fancy tx-I think it's a JR, and it might be able to program the PPM outputs. If so, he might be able to use that 'Magic Cube' to be able to fly the V120 from his JR tx. I'll report more if I learn more . . ..
In other news, I flew a pack this weekend from inside my house, looking thru my front window. It was a slow, scale-type flight, but it was fun to try. Ha!
Rafa
Old Sep 04, 2012, 03:13 PM
Sudan, Khartoum
Joined Aug 2012
Rafa
Very much interested in that, if it works that would be awesome...
Old Sep 04, 2012, 09:38 PM
Travis MCH's Avatar
Joined May 2011
Rafa,
Those indoor/outdoor flights are nice when it's feezing outside. Bone up while it's hot and you'll be ready for winter!
Old Sep 08, 2012, 11:44 PM
RamboSmurf is offline
Find More Posts by RamboSmurf
Bring back the Huey!
RamboSmurf's Avatar
United States, NY, Kingston
Joined Mar 2007
OK, I have read all I can on the D02s and am just as confused as when I started. So, I'll just ask.
I have the genius and love it, but I can't get it to loop, flip or do other moves. Seems way underpowed. I am considering the 02 v2. Will this work for me. I own a 450fbl and I'm a big chickens*** when it comes to it, but don't care with genius because its so crash resistant. My questions are, is it strong enough for the upcoming crashes and will it do the 3d or is there one better. Thanks in advance for your help
RamboSmurf is offline Find More Posts by RamboSmurf
New Product New "Ultra Durable" 120 CP Heli from Walkera - V120D02S zadaw Micro Helis 17447 Aug 22, 2016 09:25 PM
New Product Walkera New V120D02S V2---NEW 6-Axis Gyro and Upgrade online receiver! bigflier Micro Helis 144 Feb 14, 2016 10:56 PM
Discussion Walkera V120D02 - Pics & Flight Review **REVISED** dkfuji Micro Helis 3871 Sep 29, 2013 04:08 AM
Sold Like new Walkera V120D02 Daren Aircraft - Electric - Helis (FS/W) 1 Apr 08, 2012 01:29 AM
Discussion Walkera V120D02 WowHobbies.com review wowhobbies Micro Helis 107 Jan 24, 2011 02:50 PM
