Old Oct 01, 2012, 05:03 AM
Sudan, Khartoum
Joined Aug 2012
Variations indeed, here's mine straight out of the box.
I'm still very new to the hobby.
May someone elaborate how the two above setting would differ regarding flying.
I still need to set up my New V120D02S as it drifts to the right, when trying to take off slowly.
Bean Bandit is offline Find More Posts by Bean Bandit
Old Oct 01, 2012, 10:01 AM
If it Works, You Better Fix It
VelocityRC's Avatar
North Idaho
Joined Feb 2011
Originally Posted by zadaw View Post
I know that some are complaining of excessive compensation by the 6 axis gyro, especially in FFF. I do not feel any compensation in FFF. In fact I feel that it is much more locked in throughout. It also feels a bit better doing with mild stationary 3D. The big difference is in slow moving mild continuous, especially rolling upright to inverted or vice versa. It just has a much smoother feel than the 3 axis gyro.
However, I have the problem with excessive compensation with my Master CP whereas others are happy with theirs. It seems there is a lot of variation between receivers as they leave the factory. Here is a picture of my pot settings on the 6 axis V120D02S.
I'm thinking about getting a V120D02S. I notice in the image that there is no rudder gain pot, only extent. Can any of you folks explain this to me. Is gain adjustment no longer needed on the tail ?
Bill S.
VelocityRC is offline Find More Posts by VelocityRC
Old Oct 01, 2012, 10:06 AM
Hong Kong
Joined Jan 2010
If you heli drifts, it suggests that the the ail-elev gyro gain is not enough. I suggest that you adjust your left pot up to the position shown in my picture. If your heli starts pitching up and down at a low frequenc, then you should lower the gain setting.
Bill S.
The tail gyro gain is adjusted through a channel on the transmitter. This has been the case for some time with most tail gyros.
zadaw is offline Find More Posts by zadaw
Old Oct 01, 2012, 10:17 AM
Sudan, Khartoum
Joined Aug 2012
Thanks I will try it out. As said I'm still a new and need to do a lot of reading how to set up everything properly incl. how to level the swash etc. Another thing I need to figure out is how to adjust the settings for a more scale like take off as at the moment it jumps some 2 foot into the air immediately from the ground.
Old Oct 02, 2012, 09:54 AM
VelocityRC's Avatar
North Idaho
Joined Feb 2011
OK that makes sense, thanks. That's how I do it on my 450's. I don't have a CP Walkera and obviously I did not think that through. I appreciate the reply.
Happy Flying !!!
Bill S.
Old Oct 02, 2012, 10:03 AM
Joined Oct 2010
if it drifts it could also be mechanical setup....make sure the swash is level when you have your throttle at 50%...also when you do this make sure the throttle and pitch curve are linear.
pmerritt is offline Find More Posts by pmerritt
Old Oct 09, 2012, 11:36 AM
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Originally Posted by Rafa's CB100 View Post
Thanks Tom. I hope you do get one--I'd like to get your take on this whole 'full time 6-axis' thing.
Rafa
Originally Posted by Tom Z View Post
Hi Rafa ,
Good job on your review!
I am thinking of getting one.
Tom
Hi Rafa,
I just bought the BNF V120D02S V2 (Green canopy).
I will be doing a full review on it all stock then with the Turbo Ace 915 BL
15,000kv motor using a 14T pinion and the and XP-12A-2 (VER 2) High Speed ESC.
The motor has extreme power!
I have it on my 4G6 w/RX2610V2 now and will be putting it on the V120D02S V2.
Then I will put my HP08-2 back on my 4G6.
Tom
Tom Z is offline Find More Posts by Tom Z
Latest blog entry: My RC Web Site
Old Oct 09, 2012, 06:18 PM
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Hi Rafa,
Tom
Did you get a slipper clutch for it? I would like to know if it will handle this motor..
livonia bob is offline Find More Posts by livonia bob
Old Oct 09, 2012, 06:59 PM
Tom Z's Avatar
United States
Joined Sep 2007
No but I am thinking about getting one to try out sometime.
Tom
Old Oct 10, 2012, 08:46 AM
Tom Z's Avatar
United States
Joined Sep 2007
V120D02S V2 TX Settings
My V120D02S V2 will be here tomorrow.
Can somebody with one tell me what setup guide I have will work for it?
I have the setup guide posted for it with the settings from the owner’s manual.
I was thinking I can use the Mini CP setup. The Master CP uses the Mini CP settings as a starting point
so I was thinking the V120D02S V2 can use them also.
http://www.rcgroups.com/forums/showthread.php?t=1325037
Tom
Old Oct 10, 2012, 08:55 AM
Hong Kong
Joined Jan 2010
Tom
Tom, the same settings will work for the V120D02S, Mini CP and Master CP.
Old Oct 10, 2012, 09:17 AM
Tom Z's Avatar
United States
Joined Sep 2007
Thanks zadaw!
Tom
Old Oct 15, 2012, 10:26 AM
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
Hi Tom,
Glad to hear it. I'll be interested to hear your thoughts--seems like folks either love or hate this 6 axis thing. I'm still having fun with it. Let us know when the review is ready!
Rafa
Hi Rafa,
Tom
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Oct 15, 2012, 11:43 AM
Tom Z's Avatar
United States
Joined Sep 2007
Hi Rafa,
I would have had the review posted today but the ESC burned out only after two battery packs!
So now I am waiting for a new ESC that is on the way to me.
I want to test the heli 100% stock out of the box first so I don't want to use another model ESC which I have many of them
including the XP-7A-2 and XP-12A-2.
Once I get the stock ESC I will test flight times, thrust, and headspeed.
Then install my TA915 and XP-12A-2 (VER 2) and do the same tests then post the review.
Tom
Old Oct 17, 2012, 09:03 PM
NYC
Joined Aug 2010
Max/Min Pitch for Sports flying and 3D
Wondering what is ideal Max/Min pitch for sports flying on v120 size heli? Same for 3D? I am reconfiguring my pitch settings and right now its +10/-10 in Idle-up. I don't plan to 3D yet, but would like to learn sports flying such as flips, rolls and inverts.
Torch8 is offline Find More Posts by Torch8
New Product New "Ultra Durable" 120 CP Heli from Walkera - V120D02S zadaw Micro Helis 10338 Today 12:54 AM
Discussion Walkera V120D02 - Pics & Flight Review **REVISED** dkfuji Micro Helis 3867 May 26, 2013 11:30 PM
New Product Walkera New V120D02S V2---NEW 6-Axis Gyro and Upgrade online receiver! bigflier Micro Helis 104 Feb 25, 2013 12:12 AM
Sold Like new Walkera V120D02 Daren Aircraft - Electric - Helis (FS/W) 1 Apr 08, 2012 01:29 AM
Discussion Walkera V120D02 WowHobbies.com review wowhobbies Micro Helis 107 Jan 24, 2011 02:50 PM
