Review of the 'New V120D02S' from Walkera
INTRO/THE STORY If you don’t feel like reading my long, boring story (I’ve been told I can tell a long, tangent-filled story.), I’ll give you the CliffsNotes version, I don’t mind—This thing is awesome!! I was given the chance to fly, repair, and review this little green monster, the ‘New V120D02S’, by hobbyone.com.hk. Thanks Lena!! The model can be found here: http://www.hobbyone.com.hk/cn/product.jsp?id=11130 As a brief history, I’ve owned a few Walkera models, to include the CB100, 4F200, M120D01, Genius CP, QR Ladybird, QR Space Walker, and now this ‘New V120D02S’. My r/c experience started with an Air Hogs heli for a short time, then a CB100 shortly before joining rcg back in December of ’09. Rather than start with the technicalities of a typical review, I thought I would just tell you the long story. I figure that someone reading this as a review would appreciate the full ownership experience, not just a cut and dry review. I received this model back on June 19. It looked great coming out of the box (more on that later), and I really like the look of the green canopy. One can argue green versus any other color, but regardless of the color, the look of the canopy is easy for the eye to see and recognize at a relative distance. The ‘dot’ on the front makes it very clear when the model is pointed at you. There was an ‘unofficial fun fly’ scheduled for that next Saturday, the 23. Woo Hoo. I promised myself that I would not put power to the model until a friend had a chance to shoot some nice pictures of it—just in case. I had also planned to meet with Travis MCH the day before the fun fly. Some of you may know that he lives a few towns over, and he flies a V120D02S, amongst other 120 sized Walkera models. After it’s initial lookover and screw check, I performed the setup on my DEVO 8S, which was according to the sheet included with the model. The first time I powered the model was the 21st. On it’s maiden spool up, I was surprised, frustrated, and saddened to immediately see that the main shaft was bent. I had straightened some shafts back in my M120 days, so I took a crack at straightening this one. I had no luck with straightening this shaft. Where I did have some luck is that my friend Travis keeps a good stock of parts for his 120s. I’m also lucky that this new model uses the same main shaft as the original V120D02S. Travis and I got together that Friday afternoon at a public park in a town about half way between our houses. It was a pretty good spot, and we again got lucky by finding a decent place using nothing more than google, google maps, and our imagination. He had a new main shaft, and was even nice enough to install it for me and show me how the model is put together compared to my old M120, which seemed like years ago. The shaft was easy to replace, and it was great to be able to use an rcg contact to be able to get back in the air! Now that the spool up was smooth, I was able to ‘maiden’ the model. It flew well enough, but it did have a tendency to jump a bit in hover. I’m talking like1-2 inches of vertical ‘jump’ while trying to hold a stable hover. If the model was hovering close enough to me, I could hear a change in the sound of the motor as it jumped—as if the motor was cutting in and out. I remember having a similar issue somewhere along the journey, and it had worked out to be a bad connection somewhere between the esc and the motor. Disconnecting and reconnecting the motor didn’t change anything. Travis and I tried to fly both versions of the V120D02S, but the jumpy throttle kept any real comparison from happening. I came home and soldered the connections between the esc and the motor, hoping that it would fly smoother at the fun fly. Lo and behold, it flew great! For my personal preference, I quickly changed the pitch curves to not have that annoying jump that happens when changing from normal to idle up with the stock curves. I prefer to keep zero degrees pitch at midstick in all modes. To tangent a bit to the fun fly, I have to say that it was a lot of fun. It was put on by the guys that do the ‘RC Today Show’ podcast, and if you don’t know about this podcast, you should check out rctodayshow.com. The event was held at a small, private airstrip outside of the small town of Caldwell, TX. It seems that the nice man who owns that land has a business crop dusting, and when he isn’t using his strip, he allows the r/c fixed wing and heli guys to fly there. It was a beautiful spot with gentle rolling hills in the distance—not to mention the flying! (Thanks Chris and Bobby!) Back to the V120. I gave the green beast a pack of sport flying (no 3D), and she felt rock solid to me. At this point I should mention that I had something happen to both my Genius (with hundreds of flights on it) and this V120 that has never happened to me before. It was very hot at the fun fly, like 100* F, and the very top of both canopies melted and sagged just a bit, right at it’s rear edge, like above the motor and front servo. If it had happened to only one model, I would have written it off to a mechanical problem with that one model, but since it happened to both, I have to assume that it was due to the hottest conditions that I’ve flown in yet. Now that the model was flying as well as I thought it should, and without adjusting anything other than the pitch curve, literally, I handed the model to my friend Kenny, who is a much more experienced pilot than myself, and the guy who has helped me the most with my 450 journey. I really wanted to get the opinion of someone who is a better pilot than myself and generally flies much larger models. I also wanted to be able to watch the model fly inverted. I really wasn’t expecting Kenny to do much more than hover it inverted on his first pack, but it didn’t take long before he was throwing the model this way and that, doing hurricanes, funnels, and other 3D moves that my mind couldn’t comprehend, much less identify. The thought hadn’t even occurred to me that I should be filming all of this, and in the mad rush to grab my iPhone amidst the wildest flight I’ve ever seen put on a Walkera in person, I later learned that I had failed to start the recording. It was like running into an alien being, and your cell phone camera not working!! After what seemed like a few minutes of smooth, graceful 3D, there was a moment where the ground got a bit too close. Oh well, now we get to see how durable the model is. It survived the crash without incident, but after the second crash, it was clear that something wasn’t quite right. We looked over the model quickly and couldn’t identify the problem. We kept flying until the tail gave out completely. In my V120 rookieness, and because my M120 had a notch on the main shaft for the collar, I hadn’t noticed that the collar had slipped. If I would have caught this earlier, it wouldn’t have eaten the main gear like it did. Bummer. I had even found a second cameraman by this point, but the model was unflyable by then. By the time I got her put back together (which was just main and tail gears), Kenny was already packing up. Having seen all that he did gave me some confidence to try the little bit of 3D I’ve been working on lately with the Genius—inverted, nose-in hover. I was surprised to find that I could flip her over and hold her inverted without much problem. I was even able to flip her upright, then back over to inverted again. I suddenly felt what Zadaw has been trying to tell me for months, which is that the V120 has a lot more presence in the air than a Genius, and is therefore easier to flip and fly inverted. At this point, I’ve seen the model fly smooth 3D, and I’ve been able to hold a stable inverted hover. Is this thing in 3 or 6 axis mode? How does 6 axis work in this model? I decided that I had better try to see about this 6 axis thing. My only experience with it has been with the little Genius (Walkera’s first application of the technology, I think), and I really didn’t try the 6 axis setting more than once. I left the whole ‘vibration vs. rx-inclination’ debate to others (for those of you who may remember that!). I have to admit that the CD containing the owner’s manual that came with my model was unreadable by either my Mac or PC, but the manual is posted on the Walkera website, so no problem there. The manual mentions 6 axis, but doesn’t say that it can be switched on or off. I asked Lily at Walkera about this, and she explained to me that this is just a further development of the 6 axis technology, and that is no longer switchable like it is in the Genius. However it is that 6 axis is working in this model, I can say that I can hover with good stability, and Kenny was able to swing it around in various orientations, both upright and inverted. I’m fairly confident that the 6 axis is doing something, but I’d have a hard time trying to explain what it is. It has been suggested that this model might have a slower roll/flip rate than the original V120D02S because of it’s 6 axis, but I can’t comment on that yet. Maybe I’ll have to get a V120D02S V1 to find out. Fast forward a week or so, as other projects took my attention for a bit. Now it was time for me to take a short vacation to see family outside of Los Angeles. I took the V120, and since I woke up before everybody else, I was able to fly 3 packs each morning out in front of my family’s house. This was out in the street in a quiet neighborhood, but there was no grass to speak of. This, and the new surroundings, meant that I only flew upright while out there. Knowing that I wasn’t going to try flipping it, I was able to get very comfortable with the model in slow, small circles, figure 8s using both inbound and outbound turns, nose-in hovers and landings, and other things I’ve only been able to do well in the simulator until now. It would be hard for me to say whether this model flies that well, or if it flies very well and this has simply given me confidence to get better at new things. Either was, I’m having a blast with this new model! My next adventure with this model was filming the footage for the video shown below.
My last adventure, before sitting down to write all this, was to get together with Travis again. Now that the green monster is flying well, we were curious to see how it compared to it’s previous version. We discovered that Travis’ original V120 had a twitchy tail servo, which he quickly swapped out. Now that both were flying up to snuff, Travis and I agreed that after each of us had flown both models, the 6 axis version was somehow smoother in the general sport flying we were doing. It would be too subjective for me to try to explain it further, but I’d be curious to hear Travis’ thoughts. I hovered the green V120 inverted, but didn’t have the guts to try it with Travis’ well sorted original V120D02S (I instead crashed his M120D01 that day). The other thing of note about that day was that a storm was blowing in, and the winds were gusting 5-8 mph, I’d say—maybe a bit more at times. This only added to the test at hand, and I’d say that this newer model seemed to handle wind better as well. Thru this process, I’ve had to replace a main shaft, main and tail gears, and nothing more. Oh yeah, the slightly deformed canopy. I’ve got 35-40 packs thru it thus far, and probably 8-10 crashes, most of which have done little to no damage. I’m impressed with how durable this model has been. I’ll leave my long story here for now. Thanks to all those who managed to read all the way thru it. On with the rest of the review. WHAT’S IN THE BOX I’m fairly sure that this is similar packaging to the original V120D02S, but it came with a cardboard outer box, the typical inner protection, a USB charger, a 600mAh, 20C Lipo, spare main blades, spare tail gears, the tiny allen wrenches for the feathering shaft, the plastic screwdriver for rx adjustments, and a manual on CD. Like I said earlier, my CD was either blank or unreadable by my machines. WEIGHT AND FLIGHT TIMES I measured 101.7g AUW, which is close to the 100g listed on the Walkera website. I’ve had my timer set to 5 minutes, which leaves my packs down to 3.8V typically. This battery tray would need to be modified to accept larger packs, as it’s got a wall at it’s front end that keeps the stock battery from sliding too far forward. This ‘wall’ would have to be trimmed if one was to run larger packs, I think. For the purposes of this review, I have only flown with the stock batteries. My model was not originally equipped with the telemetry firmware update, but I updated the rx a few days ago. I don’t have a temperature sensor installed yet, but it certainly shows battery voltage. I’ll stop using my 5 minute timer to see how long a flight really lasts before I hit 3.5V loaded. I hope to find more flight time simply by monitoring the flight time by using telemetry data instead of a timer. Looking at Walkera’s website, I see a bit of info different between the new and old versions of this model. They don’t really list what servo is in the original model, but they do tell us that the new model uses the WK-02-1 cyclic servo. According to the hobbyone website, looks like both models use the same servos. Walkera lists the New V120D02S’ main rotor diameter to be 308mm instead of 302mm for the original model. Oddly, they also list the AUW to be 100g, yet they list the original version at 80g. I don’t know where the extra 20 grams are, and I expect that this is a typo somehow. The ESC gets an ‘L’ at the end of it’s model name, and I’m not sure what is different about it. The receiver goes from an RX-2622V/D to the RX-2636H-D. CREDITS I would like to thank Rhett H, Reid R, and Chris C for camera and editing work. Thanks to fellow Walkera pilot Travis MCH for the parts and for letting me fly his V120. Thanks to my friend and mentor Kenny for giving this little model a chance and a flogging. Finally, thanks to HobbyOne for the chance to review this little beast. I would appreciate any comments, and will try to answer any questions anyone might have. |
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
Joined Sep 2010
I agree that for beginner, the V2 is very very very stable and I recommend it, you can let go off the stick outdoor in some wind and it stay level no matter, of course the wind will blow it and it drift, but drift level.
The cons I find of having the self level always active, is it make the center stick some sort of death and the heli feel like a coaxial, I got bad habit of that feeling and when I take my bigger heli(450, 600 & 700) it's alway a relearn. To make it come to life a little, I put the ''ele/ail ext'' pot all the way to the full position, 110% travel ail/elev, with some 10 to 15% negative expo (expo in the way to make cyclic more reactive center stick). For beginner, no expo and the pot mid way is a very stable set-up, but do not go too low with the pot, because it induce cyclic delay, it's like self level is more active with low setting, if you get in trouble, you cannot recover fast enough. Rudder 120% travel with 30% negative expo make the tail to come to life also, but beware it's easy to blow out the tail outdoor. Piro rate are to my liking but cyclic flip/roll rate are a little low, the self level is there against faster roll/flip. For FFF outdoor I think heavier blade will be requiered, because it constantly pitch-up, so beware. All in all this is an awesome micro heli, indoor or not too much wind outdoor, very stable and/or fast if you like, once inverted, if you don't panic, it's really easy to hover inverted. |
United States, CA, Chowchilla
Joined Aug 2009
Doesn't seem much of an upgrade for the v1 lol. I'm glad they just changed the rx. not the heli so that spares can stay around longer lol. anyways, 6 axis is not good for beginners. The next thing you know is that they think they know how to fly a cap and buy a 450 and the next thing you know is them coming on here and crying about crashing their helis and that 450s are garbage because they need to learn everything all over again lol.
I'm not sure that someone with a V1 will want to run out and buy a V2 (but they might update theirs), but someone who is just looking at purchasing a V120 has some thinking to do. Rafa |
| Thread Tools | |
| New Product New "Ultra Durable" 120 CP Heli from Walkera - V120D02S | zadaw | Micro Helis | 10342 | Today 11:44 AM |
| Discussion Walkera V120D02 - Pics & Flight Review **REVISED** | dkfuji | Micro Helis | 3867 | May 26, 2013 11:30 PM |
| New Product Walkera New V120D02S V2---NEW 6-Axis Gyro and Upgrade online receiver! | bigflier | Micro Helis | 104 | Feb 25, 2013 12:12 AM |
| Sold Like new Walkera V120D02 | Daren | Aircraft - Electric - Helis (FS/W) | 1 | Apr 08, 2012 01:29 AM |
| Discussion Walkera V120D02 WowHobbies.com review | wowhobbies | Micro Helis | 107 | Jan 24, 2011 02:50 PM |
