Old Jul 11, 2012, 09:38 PM
mini t king is offline
Find More Posts by mini t king
mini e revo basher/racer
Joined Mar 2010
Help!
how do mount a wing on the front if my merv?
I have the merv and i have an extra rear wing sitting around. How can i mount it on the front of the revo. If possible can i get pics to see the way it gets mounted also. Thanks.
mini t king is offline Find More Posts by mini t king
Old Jul 12, 2012, 07:25 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You'll need to fabricate a custom mount for it, there isn't one available to buy that I'm aware of.
wparsons is offline Find More Posts by wparsons
Old Jul 12, 2012, 09:03 AM
Joined Mar 2010
Could i use my rear wing mount? And just do some customizing.
Old Jul 12, 2012, 04:42 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
There's nothing on the front to bolt the wing mount to, and you'll need to reverse it as well unless you want your wing facing backwards.
Old Jul 12, 2012, 04:55 PM
Joined Mar 2010
I mean like could i fabricate the wing mount to be ready to do. I am also prepared to use super glue
Old Jul 12, 2012, 09:08 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
Super glue probably won't hold up to crashes very well. A metal or plastic L bracket attached to the front bumper mount would probably be the best way. Do you have a goal in mind, or is this a "because I can" project(I have lots of those ) ?
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Jul 12, 2012, 09:43 PM
Joined Mar 2010
I am hoping it will make downforce on the front and helo me steer better. I put in lipos and it just does wheelies so hopefully it will push down.
Old Jul 13, 2012, 08:55 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The wing won't help at all, it's too small to be that effective. You have two options to keep the front down. Put weight up front or run a center diff. A caution about the center diff, if you floor it you'll just see the front tires spin up like crazy and it won't go anywhere in a hurry.
The cheapest option is to just not floor it until it's moving faster.
Old Jul 14, 2012, 11:28 AM
Joined Mar 2010
Even at full speed it lifts the front end up and i have a 1/10 scale wing also
Old Jul 15, 2012, 04:52 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You can try a center diff, it'll be the most effective solution. Like I said though, if you floor it you'll just see the front tires balloon huge and not get the same acceleration as before. It's better than ending up on your roof, but you still need throttle management to accelerate nicely.
Old Jul 15, 2012, 10:49 PM
Joined Mar 2010
i have to do hard take offs as i drag race rcs down my road and i cant get a good speed up by the end and they barely beat me
Old Jul 16, 2012, 08:40 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you want to drag with a MERV, you're going to need to add weight up front and lower it way down so the CG is lower. There are much better vehicles for drag racing, but if you want to work with what you have a single wing up front isn't going to do anything much unfortunately.
Old Jul 25, 2012, 07:21 PM
Joined Mar 2010
my local track is going to a dirt drags. so i am wanting to drag it. i have wheelie bar going on and i lowered it.
Old Jul 25, 2012, 08:31 PM
Evansville, WI
Joined Dec 2006
Lower the front, raise the rear. You'll get better weight transfer and might be a bit quicker. Works with real cars anyway...
Suggestion How do I know if my warning point has been retracted AndyOne Site Suggestions / Complaints 2 Mar 05, 2012 08:21 AM
Help! How do I mount the wing on ‘MY’ Edge 540 BoboG Giant Scale Airplanes 4 Mar 27, 2008 06:29 PM
Question How do I mount a motor on the front of a wing? RobinBennett Flying Wings 4 Nov 02, 2006 06:45 PM
How do I mount Himax outrunner on front of firewall Foamaholic Power Systems 2 Dec 31, 2004 10:36 AM
