Hobbyking have a UK warehouse :
http://www.hobbyking.com/hobbyking/s...60mm_12kg.html |
Maiden flight, a success...kind of!
So the weather was perfect, and thought i'd go to the local field for a maiden flight. I had a couple of issues, one being the slow start on the motor. I thought i'd try a short hop, but the plane just lifted into the air, forcing me to do a slightly laonger flight than planned,
I'm not sure what was wrong, I think there was too much 'up' trim on the elevators, as the CG was at 33%. It was a bit difficult to control, but managed to land it, the landing was a bit heavy. And has highlighted the wek points i nthe rear of the fuselage, it is a clean break, so i will epoxy back together, add a bit more weight in the nose, and try again next weekend. Overall i'm please with the progress.
Canada, NS, Halifax
Joined Dec 2005
A check to make.
Before the next flight, try to check the angle of attck on the main wing and tail.
If the plane is zooming up it may be the difference in angle of attack between the main and tail effectively is giving a constant up elevator. If that is the reason a kludge may be to give the ailerons a bit of reflex to effectively reduce the angle of attack. To do this, with the ailerons centered and even, turn the adjustable links 4-6 times in the direction required to give both ailerons a slight amount of up. This effectively reduces the angle of attack. It does induce some drag. Try a short hop. Power up and take off and land immediately after 1 -3 seconds of straight ahead flight. Evaluate what happened. Did you have more elevator control and less pitch up? Also setup exponential on the TX for the elevator or reduce the throws by moving out a hole or two at the elevator control horn.. The video seemed to show over control, not so much tail heavy. J |
Checks before next flight...
Having already completed one flight, I am confident that moving the CG forward should help a lot, I am basically going to add a second 5000mah 4s battery up front. Based on the performance of the plane. I think it will easily handle the extra weight. If after doing that, I still experience pitch issues, I will change the angle of the ailerons. But would be hesitant doing something that is going to reduce performance at this stage... Does that sound about right? |
Canada, NS, Halifax
Joined Dec 2005
Clark-Y Angle of Attack
When a Clark-Y airfoil has the base or bottom horizontal, it has a positive angle of attack.
The reason I say this, is because the angle of attack is "usually" measured from the centre of the radius of the leading edge to the center of the trailing edge. With a Clark-Y having the bottom as a datum, you could have several degrees of angle of attack. A simple rule is 1/16th of an inch at 4 inches is 1 degree. So if the chord is 12 inches, 3/16ths of an inch is one degree. What is the height of the centre of the radius of the leading edge, above a straight edge held along the underside of the wing? See this link for a sample http://airfoiltools.com/airfoil/deta...foil=clarky-il The horizontal line is displayed at 0 deg AofA. Note the amount the lower surface extends below the centre line at 0 deg. Note in the right hand upper plot the angle of attack at 0.0 still shows positive lift, even with Reynolds number of only 50,000. When you plot the Re of 100,000 the Coefficient of Lift Cl is much greater at 0deg AofA In the bottom right graph you see the impact on drag of an increase in the AofA. It starts to increase dramatically at around 10 degrees and goes up steeply with increasing angle. Jim H |
O dear!
In that case I guess the wing position needs to change. Unsure as to the radius of the centre of the leading edge robably around 5mm Ish. So does this mean I need to give the elev some down trim to compensate? Or would it be best to give ailerons some trim instead? Cheers for the link, it helps a lot.. Even though it's not what I wanted to see! |
Canada, NS, Halifax
Joined Dec 2005
Simple method
Put a straight edge vertical against the leading edge. Where it touches the leading edge is very close to the centre of the radius. In reality the centre will be just a bit higher.
You want this straight edge to be perpendicular to a line from the contact point to the centre of the trailing edge. This contact point is the centre of the leading edge. How high is it above the straight edge along the bottom? What is the chord? I will use my calculator to find the AofA Jim H |
Hi Jim,
Cheers for the instructions, they are very clear and I think I have done the measurements correctly. The distance to Le touch point from a line that goes along base of wing is 15mm. The chord is 315mm... I won't be able to change angle of attack as wing is glued and secured into fuselage. Will elev trim be good enough, or would ail trim be better. Guessing mounting the wing properly in the first place would have been good. Does the angle of attack issue create big problems? Not sure if you saw the video of the maiden, but the plane pitched up an awful lot on take off. I could also add extra nose weight to move CG to 25%....? I'm in the process of designing a. Better fuselage... I'll definitely need to factor this into the new build... Rich |
Canada, NS, Halifax
Joined Dec 2005
Take the Easy Route
Put some weight in the nose.
Move the elevator pushrod out to a farther hole on the control horn, or move the pushrod in closer to the middle on the servo output arm. This will reduce the throw a bit. Make sure there is no up elevator at the neutral position with the trims in the exact centre. You want to have maximum trim range available. After a few flights and you get the trims set so the plane behaves similarly from one flight to the next, carefully note the deflection on the control surfaces using card stock templates. Then set the Tx trims on neutral and then adjust the pushrod ends to move the surfaces to match the templates. Now you will have full trim range available to you with the plane movable surfaces in the correct flying position. |
Going down the easy route!
During the build i didn't even think about battery position, or the method to secure the batteries in the plane. Hopefully this will do the trick. My only concern is that if the plane has a hard landing, the box could rip off, and damage both batteries... and at £40 each, i don't particularly want that to happen! It's been raining all day, so maybe try it out tomorrow... I've done the trims as well, so fingers crossed she'll lift off in a slightly less aggressive way next time! |
A couple of questions..
What is the best way to hinge control surfaces? I've been using the standard 28mm x 12mm mini nylon pinned hinges, about 3-4 per control surface, but they keep getting ripped out by accident. Therefore I my go back to simple duck tape style hinges. Is there a better way to do this? Taped hinges are quite straight forward if the top edge of the wing and aileron are flush, with each other, but I've cut A v leading edge in the control surfaces for more movement. Again, what's the best way to cut the edges between the wing and hinge. second question, how do you get a nice shiny coloured finish on fiberglass? I've seen a few different products, not sure which is the best... 1. Mix a coloured pigment into the resin, so you get a coloured finish 2. use gel coat, ths seems quite heavy per m/sq 3. Coat of primer, then spray paint Any help on the above would be great... Rich |
| Thread Tools | |
| Build Log Raptor 2.0 A real Dyna-Soar...... 2M bagged DS'er build Log | Keenan smith | Dynamic Soaring | 39 | Oct 10, 2012 05:22 AM |
| Discussion Raptor 2.0 A real Dyna-Soar...... 2M bagged DS'er/Sloper build Log | Keenan smith | Slope | 10 | Jul 05, 2012 01:40 PM |
| Discussion X5 Build Log - FPV & AP Ready [Videos & Pics] | AndresCL | Video Piloting (FPV/RPV) | 0 | Apr 20, 2012 10:35 PM |
| Build Log FPV/UAV/AP tricopter build log [Changed from "Got the stuff... I went all out"] | slisgrinder | Video Piloting (FPV/RPV) | 47 | Jul 25, 2011 09:57 AM |
