Old Aug 30, 2012, 07:35 AM
richie967 is offline
Find More Posts by richie967
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Wing Covering
Originally Posted by benybee View Post
what will cover the main wing?
The Main EPS wing will not be covered. It has a thick spruce spa providing rigidity. I will maiden without covering the main wing, but may cover with varnish and Brown/packing paper if it looks like it needs more twist strength.
Currently having trouble with wing joiners at the moment...
I may glue the wings on permanently.
richie967 is offline Find More Posts by richie967
Old Aug 30, 2012, 05:12 PM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Update - some pictures
wheels are on.
Tail has been stripped back down as i had some issues with the servo placement.
Motor is being delivered tomorrow - even though it was ordered weeks ago! fingers crossed maiden one eve next week!
R
Old Sep 03, 2012, 01:07 PM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
And here is the power system.... I've never used a brushless motor even close to this size before!!
I'll be installing this tonight, I'll leave the unimportant things like 'attaching the wings' for another day!
Description:
Old Sep 04, 2012, 11:53 PM
AeroRoo is offline
Find More Posts by AeroRoo
Joined Aug 2012
Amazing thread, thanks so much for this! Seeing build logs like this has really inspired me to get into RC and scratchbuilding (well, a little, I prefer designing in 3D and sending it off to get made. I'm very lazy!)
AeroRoo is offline Find More Posts by AeroRoo
Old Sep 06, 2012, 10:19 PM
benybee is offline
Find More Posts by benybee
Indonesia, Lampung, Sukarame
Joined Dec 2009
sending it where?
benybee is offline Find More Posts by benybee
Old Sep 10, 2012, 02:29 AM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Update - In pictures...
Made a fair bit of progress yesterday, wing fasteners are in (couldn't use a pin through the CF tubes as people have suggested due to thickness. I will certainly use a pin and ticker tubes next time!)
Motor is Bolted on and ready for a test this evening. I think this will need to be run up outside due to its size!
Hot wire bow is made, just waiting for my transformer to cut the block of polystyrene. Fibreglass should be here tomorrow to cover polystyrene tail.
Going to spend a lot of time smoothing the wings tonight, They have been liberally covered with polyfilla 'onefill' super lightweight filler, for sanding. Then will cover with the Varnish brown paper method to get some twist strength as they twist quite a lot currently. A bit concerned the varnish wont stick to the polyfilla, but as long as there's a skin, i guess that doesn't matter...
The orange tail in pictures is useless, and will be replaced with the EPS, Fiberglass version for strength.
Old Sep 11, 2012, 05:20 PM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
Looks like the prop is not in the good direction, or i'm i wrong??
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Sep 12, 2012, 02:10 AM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Yeah, I just chucked it on for show... I will turn it around for maiden, haven't started the motor yet, soldering deans connectors onto chunky wires is time consuming work!!
Cheers
Old Sep 13, 2012, 03:41 AM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Wing Covering
The wing is almost ready to be covered in paper and varnish - Filling with Polyfilla onefill has helped smooth out the surface quite a lot.
Old Sep 13, 2012, 01:28 PM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Fibreglassing over the foam tail
I will be using fiberglass for the first time to fiberglass the tail.. Here is my shopping list...
Glassfibre Cloth 25g sq Mtr x 2
Glassfibre Cloth 135g sq x 2
SP 106 Multi Purpose Epoxy - Slow-1kg pack
Mixing Kit
100mm Nylon Resin roller + frame
TOTAL: 40 !!
Anyone know anything about fiberglassing... care to share any tips?!
Rich
Old Sep 13, 2012, 04:58 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
That looks like a lot of work and weight for a foam airplane. Maybe a conventional balsa, basswood, plywood airframe would be stronger and lighter and just as easy to build.
I have been thinking of designing and building a twin motor UAV this winter and I an thinking that wood is the way for a 800 sq” airplane.
RC Man is online now Find More Posts by RC Man
Old Sep 14, 2012, 05:26 AM
awmeade is online now
Find More Posts by awmeade
Registered Slopeaphile
awmeade's Avatar
S-u-A, UK.
Joined Jan 2003
Wow. Pretty rare to see the foam filled like that before glassing to be honest - If you wanted a really smooth surface it would have been easier to veneer with obechi before glassing. You could have even glassed the foam and put the obechi on with it still "wet", providing the strength and easy "finishable" surface of the veneer on the outside.
The filler I think has just added a lot of weight, and may not give a particularly stable base for the glass fibre.
awmeade is online now Find More Posts by awmeade
Old Sep 16, 2012, 04:31 PM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
Hmmm, that is not what I wanted to hear! Basically the reason for fibreglassing is because I want to add some strength in the wings. I am not that good at using wood and making built up wings. and thought foam and fibreglassing would be a easier way to make lightweight wings.
I plan on using this technique for the cathedral tail. And using brown paper to cover the main wings, and centre wing section.
how do people normally make wings and fibreglass them? Is it just the filler I should leave out?
Old Sep 16, 2012, 06:47 PM
United States
Joined Feb 2001
Fiberglass will work but it does not have a very good strength to weight ratio. It may come out a little heavy but it should work ok.
Old Sep 17, 2012, 10:54 AM
richie967's Avatar
Cardiff, UK
Joined Aug 2008
ESC location
I had planned on sticking the ESC to the external face of the rear firewall, the same piece of wood the motor mount is screwed onto. However the Wires from the esc to the motor are quite stiff and It is not possible to bend them into shape so the ESC fits on the rear board. Therefore I propose putting the esc just inside the fuselage at the rear, this will also help in keeping it dry in the rain.
The ESC is rated at 100Amps, and The motor peak amps is 55amps, with a max efficiancy of 35a, therefore I don't intend on any long bursts of more than 55amps.
With this in mind, would it be okay to mount the ESC inside the rear firewall?
I would like to shorten these wires, however I am not confident in my soldering ability to be able to shorten them and not fry the ESC in the process.
pictures attached for reference...
Build Log Raptor 2.0 A real Dyna-Soar...... 2M bagged DS'er build Log Keenan smith Dynamic Soaring 39 Oct 10, 2012 05:22 AM
Discussion Raptor 2.0 A real Dyna-Soar...... 2M bagged DS'er/Sloper build Log Keenan smith Slope 10 Jul 05, 2012 01:40 PM
Discussion X5 Build Log - FPV & AP Ready [Videos & Pics] AndresCL FPV Talk 0 Apr 20, 2012 10:35 PM
Build Log FPV/UAV/AP tricopter build log [Changed from "Got the stuff... I went all out"] slisgrinder FPV Talk 47 Jul 25, 2011 09:57 AM
