Old Aug 31, 2012, 01:13 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
Originally Posted by fiugitive View Post
have you tried the same bind test procedure of the v911 on the fbl100 for turnigy 9X transmitter ?
Maybe it will works ?
It can't work because hisky use a different protocol. To use this ely on a 9X you need to buy this
ercapoccia is offline Find More Posts by ercapoccia
Old Aug 31, 2012, 11:42 AM
jcmors is offline
Find More Posts by jcmors
United States, MN, Otsego
Joined Dec 2010
And just where exactly is "this" being sold?
jcmors is offline Find More Posts by jcmors
Old Aug 31, 2012, 12:03 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
It is sold on Aliexpress, but it may not work with Turnigy 9. It is stated to the compatible with Futaba, JR and Walkera only.
http://www.aliexpress.com/store/prod...616634624.html
zadaw is offline Find More Posts by zadaw
Old Aug 31, 2012, 02:49 PM
Italy, Lazio, Rome
Joined Jun 2012
Should be compatible with any TX with a training port.
Old Aug 31, 2012, 07:42 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Yeah, $200.... yeah....
shahram72 is offline Find More Posts by shahram72
Old Sep 02, 2012, 12:10 PM
fiugitive is offline
Find More Posts by fiugitive
fiugitive's Avatar
Joined Oct 2010
My question was: have you tried to bind it ? with 9X tx. So....
fiugitive is offline Find More Posts by fiugitive
Old Sep 02, 2012, 12:16 PM
zadaw is offline
Hong Kong
Joined Jan 2010
The module is stated to be compatible with Futaba, JR, and Walkera. There is actually a button to select this. So your Turnigy 9X will have to have a trainer port output that is compatible to either of the 3 brands.
Here is a picture of the HiSky FBL80
Old Sep 02, 2012, 12:33 PM
jcmors is offline
Joined Dec 2010
I would say that if hisky can come out with a series of micro helis that can be flown with various other Tx's using this module thy will have an edge in the market.
I wonder if this HT8 module will be available separately? If so I may be tempted to buy the hobbyking fbl100 rtf knowing that I will be able to buy this module and fly it with my futaba after the modules hit the market.
The only place that currently sells this package with the module has it for almost $200 shipped to the US. Too much in my opinion but I am sure the price will come down over time.
Jim
Old Sep 02, 2012, 01:59 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The canopy looks like some chubby person with a second chin. Or a "chin-sack" that some reptiles have...
SoloProFan is online now Find More Posts by SoloProFan
Old Sep 13, 2012, 03:49 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
I busted my tail motor and took off the tail boom and I have no idea what i did with it. Now I need to buy a new motor, boom, blades, motor holder.....
Heres my question, the new tail motor http://www.hobbyking.com/hobbyking/s...dProduct=26612 is not wired to plug into the 3 in 1 I need to wire it myself.
Where can I find the connector that connects the motor to the board? Also whats the best wire to use for this? I've never used anything smaller then servo wire. Thanks guys.
airbagit13 is offline Find More Posts by airbagit13
Old Sep 13, 2012, 05:55 PM
Magnum9 is offline
Find More Posts by Magnum9
Molded Hotliner Destroyer
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
HK have the wires with connector as a spare part, pity the spares are all out of stock, I have been waiting over 5 weeks for a tail boom to come in.
Magnum9 is offline Find More Posts by Magnum9
Old Sep 14, 2012, 02:37 AM
dragonal is offline
Find More Posts by dragonal
dragonal's Avatar
Turin, Italy
Joined Jun 2003
Hello
i have a serius issue....whiy motor lock the servo answer ist corret,move and when relase stick ist return to 0 position.Whit motor active (flying...)when the servo was moved by stick input not return at 0 position when stick retun at initail position.....this made hely not flyable...
This is my problem...ist my first FBL ...i talk with HK support and told me this is "normal" bheaviour for this kind of hely...
Ist true?.......
dragonal is offline Find More Posts by dragonal
Old Sep 14, 2012, 06:10 AM
Magnum9 is offline
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
The servo should return to zero, but when flying the heli won't stop moving when you centre the stick. Have you flown collective pitch helis before?
Old Sep 14, 2012, 06:47 AM
dragonal is offline
dragonal's Avatar
Turin, Italy
Joined Jun 2003
Hi
yes, but my concern is this ,with motor is desengage the servo mouvement is "normal",when engage motor and hold hely in my hands the servo not return to initial position after tx stick was relased.This is my doubt...dont talk about hely movement,i know hely don't stop itself....
Old Sep 14, 2012, 09:14 AM
airbagit13's Avatar
Miami, FL
Joined May 2009
SWEET! Found my tail boom so I don't have to order extra parts just a new motor.
Is there a US alternative to the motor. I am thinking the HK motors are going to be forever out of stock.
Wanted Want Mini CP / Genius CP / m CP X v2 for trade / cash GrandpappyToke Aircraft - Electric - Helis (FS/W) 2 Jul 07, 2012 07:18 PM
New Product HiSky FBL100 erdnuckel2 Micro Helis 3 May 08, 2012 10:06 AM
Discussion IP, HK, Spektrum and here come the clones angelfood Electric Plane Talk 15 Sep 08, 2010 11:44 PM
Discussion post blade Cp- Blade CP Pro pix here leliommarino Micro Helis 0 Jan 22, 2008 01:33 PM
Anthony from WORLD_HOBBY (HK) Seller here.... world_hobby Vendor Talk 119 Jan 07, 2006 12:30 PM
