Old Aug 16, 2012, 01:37 AM
kidlat is offline
Find More Posts by kidlat
Joined Aug 2011
Originally Posted by SoloProFan View Post
Beginner in CP or beginner in helis? Makes a big difference.
Beginner in CPs.
kidlat is offline Find More Posts by kidlat
Old Aug 16, 2012, 01:42 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by kidlat View Post
Beginner in CPs.
The problem with the HK FBL 100 is that its transmitter is not programmable. This is not good for beginners as you will not be able to learn how to program and use different ptich and throttle curves. Moreover, the FBL 100 has been reported to be quite twitchy for beginners while it is better for 3D.
I would look at the MCPx with a DX6i transmitter, or the Walkera MIni CP. There is a Genius CP rebrand by Xheli called the XH100 that comes with a programmable transmitter at $140. You have to bear in mind though that you have got great support for the mCPX in the US including the ability to buy parts at your LHS.
zadaw is offline Find More Posts by zadaw
Old Aug 16, 2012, 01:57 AM
ercapoccia is offline
Find More Posts by ercapoccia
Italy, Lazio, Rome
Joined Jun 2012
There is an option for the programmable tx on banggood at 20 extra bucks.
ercapoccia is offline Find More Posts by ercapoccia
Old Aug 16, 2012, 03:33 AM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
Originally Posted by Torch8 View Post
Sounds good if FBL100 has no tail pitch loss and we use main gear and swash plate. Think I'm going to get one. So it should loop, roll and invert easier than stock mcpx v2? But you are saying the Walkera Genius and Mini still outperforms it?
Correct
achogg33 is offline Find More Posts by achogg33
Old Aug 16, 2012, 05:03 PM
papernkero is offline
Find More Posts by papernkero
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
On the other side there's a lot of RC heli pilots these days who teach themselves to fly so having a ready to fly heli takes the setup issues away that could otherwise make learning more difficult. Once they learn to fly and understand how everything works they can learn setups on their next (perhaps 450 size) heli.
papernkero is offline Find More Posts by papernkero
Old Aug 17, 2012, 04:01 PM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Is this a good beginner rc helicopter to start learning? I'm torn between this and the mcpx.
No this is not a good beginner heli. Get a blade CX2 or something as an intro heli. You will destroy this thing in a matter of minutes if you have not flown a heli before.
airbagit13 is offline Find More Posts by airbagit13
Old Aug 17, 2012, 04:08 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
He's not new to helis, just to CP:
Beginner in CPs.
So going back to a coax is not needed. But I would not advise taking a new heli which has not been proven durable yet. Better get a mCP x or MiniCP or Genius.
SoloProFan is online now Find More Posts by SoloProFan
Old Aug 17, 2012, 04:35 PM
jcmors is offline
Find More Posts by jcmors
United States, MN, Otsego
Joined Dec 2010
I needed something to get my "feet wet" (thumbs wet?) on CP and bought an exceed rebranded genius cp (the xh100) from xheli. It is great for learning the cp ropes, and at the moment there isn't a better price on a proven durable micro cp with programmable transmitter. The rebranded exceed is currently on sale for $116 including the devo 7 Tx and the original Genius (same exact heli) is 121. Also free shipping at the moment. This makes it cheaper than the FBL100 when you include shipping AND it comes with a computer tx! Granted, the devo 7 is not exactly intuitive but it is far ahead of the dx4e or the hisky non programmable.
just my humble opinion.
Jim
jcmors is offline Find More Posts by jcmors
Old Aug 17, 2012, 06:18 PM
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
I have to say I've dropped my FBL100 heavily nearly a dozen times with no physical damage. The swash plate used to separate but I've epoxied it now and it holds together perfectly. The ball joints and links are solid and even with the epoxied swash plate I've never popped a linkage or damaged a ball joint. The only issued I've had is a bit of grit got into the pitch servo gear and jammed it and the canopy has split which has been repaired using cello tape on the inside. Now it still looks like new and its less prone to splitting if I drop it. Ive not broken a tail boom or even the landing skids. Seems to be pretty robust to me - mind you I always fly on grass.
Old Aug 17, 2012, 08:28 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Well, I'm still a heli newbie. When I got my Nine Eagles solo pro 100, I could barely hover, then after getting and flying my Blade Mqx, I can fly my 100 around pretty well until I lose orientation. So I think that a micro is a better CP for a beginner than a 450, but I also think that an MQX or WL toys V929 is also a great tool to learn REAL heli controls, it made ALL the difference for me.
shahram72 is offline Find More Posts by shahram72
Old Aug 20, 2012, 04:51 PM
stonerscolony is offline
Find More Posts by stonerscolony
stonerscolony's Avatar
The Netherlands, NH, Enkhuizen
Joined Jul 2007
FaTedev Turnigy FBL100 3D tricks (5 min 55 sec)
todays fun, it was getting late on and ground mist was coming in. The top of my case was damp lol and I didn't know hehe.
stonerscolony is offline Find More Posts by stonerscolony
Old Aug 21, 2012, 01:25 AM
Magnum9 is offline
Find More Posts by Magnum9
Molded Hotliner Destroyer
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
I know the supplied blades are meant to be beginner blades, but I found it much more stable and less twitchy with the Nine Eagles solo pro 100 blades.
Magnum9 is offline Find More Posts by Magnum9
Old Aug 21, 2012, 01:29 AM
Joined Jul 2007
the supplied blades are speed blades and as the name implies there for darting around, I switched them out for mCPX blades and well look in the video above your post I can hold inverted tail down funnels fine now before I was using 100% and it would still brake out.
Old Aug 22, 2012, 04:50 PM
Joined Jul 2007
Will be posting a full project later (busy rebuilding my site) but heres a few pictures of the case I made for my FBL100. As a quick tip a friend uses a EEE laptop case for his mCPX and parts etc also a cool idea
Old Aug 30, 2012, 04:04 PM
fiugitive is offline
Find More Posts by fiugitive
fiugitive's Avatar
Joined Oct 2010
have you tried the same bind test procedure of the v911 on the fbl100 for turnigy 9X transmitter ?
Maybe it will works ?
fiugitive is offline Find More Posts by fiugitive
Wanted Want Mini CP / Genius CP / m CP X v2 for trade / cash GrandpappyToke Aircraft - Electric - Helis (FS/W) 2 Jul 07, 2012 07:18 PM
New Product HiSky FBL100 erdnuckel2 Micro Helis 3 May 08, 2012 10:06 AM
Discussion IP, HK, Spektrum and here come the clones angelfood Electric Plane Talk 15 Sep 08, 2010 11:44 PM
Discussion post blade Cp- Blade CP Pro pix here leliommarino Micro Helis 0 Jan 22, 2008 01:33 PM
Anthony from WORLD_HOBBY (HK) Seller here.... world_hobby Vendor Talk 119 Jan 07, 2006 12:30 PM
